Old 11-10-2012, 02:34 AM   #101
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: D60 Front Brake Upgrade
Nothing big... The axles are under the truck now, but only partially assembled. Hope to have it running in a couple weekends from now. I got the CaptainFab bracket powdercoated and received the flex lines from Kore3. Need to run new hardline as I removed all the old stuff.
Rich
1972 K5 Blazer CST Click HERE
Old 11-10-2012, 04:33 PM   #102
ryanroo
ryanroo's Avatar
ill be excited to find out how it works! itll be a while before i get to the drive test on mine
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-13-2012, 10:21 PM   #103
Last_Paladin
Ryan
Heh, I am ready to test em out... just don't have anyone to cut nice clean brackets.
Chevy 60, with 39" Pitbull rockers on 'em.
Last_Paladin is offline   Reply With Quote
Old 12-02-2012, 10:52 AM   #104
freexj
Any up date on how these work?
freexj is offline   Reply With Quote
Old 12-03-2012, 03:54 PM   #105
72BBCK20
Great work, can't wait to see it all assembled!
72BBCK20 is offline   Reply With Quote
Old 12-04-2012, 01:56 AM   #106
mcmlxix
mcmlxix's Avatar
Ryan
Me too.. It's been a long while coming... hopefully I'm rounding the bend and I can see the light at the end of the tunnel...
Here are two pics of the big brake upgrade on the Dana 60.... Sorry I dont have the calipers installed yet, but you can the rotor fills up the 17" Hummer H2 wheel...
Rich
Old 12-08-2012, 06:27 PM   #107
Luba
Luba's Avatar
nice work. subscribed.
Luba is offline   Reply With Quote
Old 12-08-2012, 08:44 PM   #108
Last_Paladin
nice!
Old 12-11-2012, 03:39 AM   #109
mcmlxix
mcmlxix's Avatar
ok.. some not so good news.. the H2 hummer wheels don't clear the Dodge 3500 calipers. Its only a fraction off but it rubs... I could grind the edge of the caliper, but mine are already powder coated. I wanted aftermarket wheels, but just not yet. I wanted to stay with 17" rims but may need to go to 18" for clearance...
Rich
Old 12-11-2012, 04:05 AM   #110
mcmlxix
mcmlxix's Avatar
here is the wheel I want to go with in 17"....
Rich
Old 12-12-2012, 01:27 PM   #111
Last_Paladin
How much? Like 1/10" or 9/10"?
I am still very interested and I am keeping the H2 rims.
Old 12-13-2012, 03:18 AM   #112
mcmlxix
mcmlxix's Avatar
It would only need some smoothing of the outer edge of the caliper.... maybe an 1/8 inch. If I didnt already powdercoat my calipers, I would have just ground them down for clearance. I wish I had a Dodge rim to test fit, but they still want big money on CL for them....
Rich
Old 12-13-2012, 10:10 AM   #113
Last_Paladin
Want a Dodge rim? I have aluminum 17" here.
Old 12-14-2012, 01:48 AM   #114
Mr. 250r
Mr. 250r's Avatar
Not to take this off subject but is that a nwf steering setup or just the arms if its the whole thing how do you like it cause i almost bought it
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 12-14-2012, 02:27 AM   #115
mcmlxix
mcmlxix's Avatar
It was the kit. Its only cross over, not high steer. I was originally just going to use the 4" block on the steering arm so I built my own lower tie bar. The arms are really nice pieces and I like the springless design. The crossover steering bar has a bend and I'm not sure why, but I'm still assembling.
Rich
Old 12-14-2012, 02:36 AM   #116
mcmlxix
mcmlxix's Avatar
Appreciate the offer, but the expense is not worth it. Once the truck is runnig and driving, I can take it and test fit a Dodge rim.... just to see if it makes a difference.
Rich
Old 12-14-2012, 02:44 AM   #117
1malo68
1malo68's Avatar
How much lift is on your rig? I want to go with crossover but I only have 2" of lift. ORD says a minimum of 4". It looks like it will work to me but I'd like to be sure. They say the bend is put in for '73 and up trucks to clear the engine crossmember. It looks like it wouldn't be an issue with 67-72s but I don't want to waste the $$$. What do you think?
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 12-14-2012, 03:22 AM   #118
mcmlxix
mcmlxix's Avatar
I have a 4" lift that was installed prior to me owning the truck. The arm is still close to the spring pack... The truck is in Henderson if you want to stop by and take a look on Sunday... PM me ...
Rich
Old 12-15-2012, 02:32 AM   #119
mcmlxix
mcmlxix's Avatar
OK. I ordered ONE 17x9 Raceline Clutch 922 rim for a test fit... comes in on Tuesday/Wednesday... so I dont get to test it till NEXT Saturday....
Rich
Old 12-24-2012, 03:53 PM   #120
mcmlxix
mcmlxix's Avatar
OK. Well I feel a little silly....
I went to test the Raceline wheel on the passenger side and it fit, but barely. So close that I went and assembled the driver side (I hadn't tried this before.) I tride to mount the Raceline wheel and it wouldn't fit over the wheel studs. The problem was I upgraded to 5/8" wheel studs and holes in the rim was too small. It had no allowance for being 27+ years old and slightly off center. So I grabbed the Hummer rim and .. TA DA... it fit the driver side, no problem.... 1/16" celarance between the caliper and rim.... So now I was thinking, what the hell is wrong with the other side....
I disassembled the passenger side brakes, then re-assembled making sure everything was aligned. There is a small amount of adjustment/play in the hole that the caliper mounting bolt goes through. I test the Hummer wheel again, and IT FIT.... again only 1/16" clearance, but it clears... as long as there is no deflection in my braket, I should be fine...
Another note about the Raceline wheels. You have to use aftermarket slpined lug nuts. The fit was so tight that you couldn't even get a thin wall socket on the lugnut. Now that may be beacuse I upgraded to 5/8 wheel studs and the OD of the larger lugnut take up more space, but just and FYI.
Rich
Old 12-24-2012, 04:43 PM   #121
plummen
Id be concerned about the expansion of the aluminum rim and the caliper myself anyway
plummen is offline   Reply With Quote
Old 12-24-2012, 06:01 PM   #122
ryanroo
ryanroo's Avatar
Sounds like winner! i wouldn't worry about deflection. the action of the caliper is strait horizontal, so there is no force at angle to deflect the bracket. if there is, it would indicate a frozen caliper slide.
72 K20 12v build
Old 12-24-2012, 07:24 PM   #123
plummen
I build enough old Kawasaki motorcycles to know how much aluminum will expand/contract in different temps,Id be really carefull about having enough clearance to allow for it.
Old 01-01-2013, 11:48 AM   #124
WillemV8
Mcmlxix, did you happen to have measured the inside of the wheel? I'd also like to go to bigger front brakes on my D60, but I have 16.5" H1 wheels. They're actually pretty big inside, something like 15 3/4".
Now that I'm taking a closer look at the inside of your wheels, I see they are pretty big, too....
WillemV8 is offline   Reply With Quote
Old 01-02-2013, 06:58 AM   #125
mcmlxix
mcmlxix's Avatar
I did not measure the inside of the wheel. I know it tapers, gets smaller closer to the mounting pad. I seriously doubt it will fit in a 16.5" rim. It barely fits the 17" rim.... I may end up with 18's later...
Rich
calipers, d60, hydroboost
