Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 04-09-2012, 10:35 AM   #101
Scottshotrods
Re: CPP Drop Spindle Special
The difference in the BJ on the
63-70 taper being the smallest
71-72 taper is bigger than the 63-70
73-70 taper being the biggest out of all of them
Justin
The tapers are different
Scottshotrods is offline   Reply With Quote
Old 04-17-2012, 01:16 PM   #102
yellowGT
yellowGT's Avatar
I know that but what do each one measure to know which spindles they are when you run into some.
yellowGT is offline   Reply With Quote
Old 04-18-2012, 08:07 AM   #103
yellowGT
yellowGT's Avatar
Reason I ask is because I have two sets of drop spindles but don't know what they fit. I was hoping maybe by determining the size of the bj I could figure that out. I know the bottom taper hole is 7/8" and then it tapers.
Old 04-18-2012, 01:09 PM   #104
CPPJEFF
We dont measure spindles like that here, we have fit parts that we measure these spindles with. If you want to determine what spindles you have i will give you all the parts numbers as followed to run down to your parts store and determine what you have. Keep in mind its not just the ball joints but the outter tie rod tapers are different also
1963-70 upper balljoint fa480 lower fa481 outer tierod es350-L
1971-72 upper balljoint fa683 lower fa1014 outer tierod es415-r
1973-88 uper balljoint fa903 lower fa1014 outer tierod es409r
Hope this helps, there is no easy way to measure these, fit parts will give you the answer. Thanks
CPPJEFF is offline   Reply With Quote
Old 04-25-2012, 12:52 PM   #105
Scottshotrods
We have cpp parts in stock and great prices and fast shipping.All the three that matter!!!!!!
Old 04-28-2012, 12:27 AM   #106
coater
Is it possible to run a wider wheel with these spindals?
coater is offline   Reply With Quote
Old 04-28-2012, 01:02 PM   #107
creep
Registered Loser
creep's Avatar
I have a 63 with a raised crossmember and DJM drop spindles SSBC 1.25" brakes for a 73-87. Will the CPP spindles bring the wheels in more for some extra fender clearance? Are they 2.5" drop?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-30-2012, 09:22 PM   #108
coater
Justin,
I sent you a PM a few days ago for some pricing on spindals and springs and shipping to 31763.
Coater
Old 04-30-2012, 09:51 PM   #109
Scottshotrods
Originally Posted by coater View Post
Justin,
Coater
I sent you a p/m earlier I am sorry on the delay here.We just got back from a Hotrod show this pass weekend.I was away from the computer for a few days.
Justin
Old 05-03-2012, 01:28 PM   #110
Scottshotrods
More Cpp parts are coming in for stock give us call to save some $$$$
(805)485-0382
Justin
Old 05-03-2012, 01:54 PM   #111
CPPJEFF
YES! This is the biggest perk of this spindle as no other spindle in the country moves the wheels inboard 3/4" of an inch per side.....
Old 05-03-2012, 01:55 PM   #112
CPPJEFF
You can as it moves the wheels in 3/4" of an inch per side against the factory drum brakes.
Old 05-03-2012, 02:17 PM   #113
Scottshotrods
This also add here that all of Cpp dropped spindals they make for these trucks will move the wheel in 3/4 per side.
Old 05-13-2012, 04:24 PM   #114
Indycar1
Indycar1's Avatar
Is this deal still available?
Indycar1 is offline   Reply With Quote
Old 05-14-2012, 10:25 AM   #115
Scottshotrods
The sale is still going on for sure.
Justin
Old 05-14-2012, 02:47 PM   #116
creep
Registered Loser
creep's Avatar
Cool. Now I just have to measure and see if my truck would still lay out with a 2.5" spindle instead of the 3" I'm using now.
Old 05-14-2012, 04:00 PM   #117
68crum
Proud owner of a P.O.S.
Just ordered a set! Can't wait to get them in!!
68crum is offline   Reply With Quote
Old 05-14-2012, 06:33 PM   #118
Scottshotrods
Packed and shipped today to you thanks for the order
Justin
Old 05-14-2012, 07:46 PM   #119
creep
Registered Loser
creep's Avatar
Looks like my truck should still lay frame with these spindles so I think I'm gonna pull the trigger and call tomorrow to order a pair.
Old 05-14-2012, 08:37 PM   #120
Scottshotrods
Sounds good we will take care of you for sure
Justin
Old 05-15-2012, 12:45 PM   #121
HotRod C/10
HotRod C/10's Avatar
I need a quote on 2 1/2" drops for a 68
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 05-15-2012, 01:00 PM   #122
Scottshotrods
P/m sent
Justin
Old 05-15-2012, 03:18 PM   #123
creep
Registered Loser
creep's Avatar
Just got my order in.
Old 05-16-2012, 10:28 AM   #124
Scottshotrods
Thanks for your order you will have your spindals very soon!!!
Justin
Old 05-18-2012, 12:28 PM   #125
68crum
Justin
Just got them in. Thanks Justin!
