Old 05-26-2012, 08:49 AM   #101
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1959 Fleetside REBORN
Awesome! I'll have to keep checking in with you to see how it's going! One tip for you, when you cut out your dash from the truck, leave a 5x5 in square in the middle. It will help to support/fill in the speaker area of the Impala dash. Good luck!
ChuckDriver is offline   Reply With Quote
Old 05-26-2012, 10:16 AM   #102
Kim57
Kim57's Avatar
I'm going to be watching this also as I think the 59 dash looks great in these trucks.
If I can find one for the right price I may do mine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-26-2012, 11:34 AM   #103
shadow1967
shadow1967's Avatar
Well chuckdriver that info is alittle late. I was excited so I went out early. Came in for breakfast. The house is up.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 05-26-2012, 04:34 PM   #104
shadow1967
shadow1967's Avatar
Well it's out! NO GOING BACK!!!!
Old 05-26-2012, 05:11 PM   #105
Kabwe
Certified Car Nut
Kabwe's Avatar
oooooo you cut that dash out of that truck. why'd you do that?
That's what my buddy's said when I cut mine out.lol
Looking good man, looking good.
Kabwe is offline   Reply With Quote
Old 05-26-2012, 06:17 PM   #106
shadow1967
shadow1967's Avatar
Calling it quits for the day! Very good day though!! Go it cut and located. I'm not going to weld it til I ge the ac. It would be easier to locate without th dash in the way.
Old 05-26-2012, 06:19 PM   #107
shadow1967
shadow1967's Avatar
part2
Old 05-26-2012, 06:30 PM   #108
Kim57
Kim57's Avatar
Sweet. Makes me want to try and find a dash at the next Pomona swap meet or maybe the L.A. roadster show.
Kim
My build thread
Old 05-26-2012, 06:33 PM   #109
_Ogre
_Ogre's Avatar
makes it easy to install the wipers?
shop air compressor timer
Old 05-26-2012, 06:44 PM   #110
shadow1967
shadow1967's Avatar
I for got about these.....
Old 05-26-2012, 08:19 PM   #111
ChuckDriver
Great work! Looks like you've got it coming together perfectly! What AC unit are you going with?
Old 05-26-2012, 08:34 PM   #112
shadow1967
shadow1967's Avatar
Would like to run a Vintage Air GenII compact but the controls are rheostat for this model not cable. The sure fits are huge and hangs low. I thinking I may have to buy some linear rheostats. Like in the old slot car controls.
Old 05-28-2012, 10:11 AM   #113
ChuckDriver
A friend of mine put the 59/60 dash in his 55 Sedan, this is what he did with his AC controls.
Old 05-28-2012, 01:12 PM   #114
shadow1967
shadow1967's Avatar
Well got side tracked do to blowing circuits with the welder. So I upgraded!!! Will be welding later today!
ChuckDriver
Can I see the whole dash....
Old 05-28-2012, 02:11 PM   #115
_Ogre
_Ogre's Avatar
nice sub-panel, but since i'm a licensed electrician, it won't pass inspection
should be 4 wire, 2 hots, ground buss and neutral buss
this in it's self isn't unsafe, just not code, would have been code pre-1992.
the wire feeding the sub-panel looks lighter than the main wire
if it's the same size, then your good, if it's smaller
this is unsafe, wire should be sized to the breaker feeding it.
and the exposed romex on top of the sheetrock is a no-no
a short nipple attaching both to the bottom of the panel would have been the way to go
but the main reason for this reply is:
for future reference and to anyone else doing this
there is a breaker that replace 2 standard single breakers
to make 4 breaker, 3 circuit, 120/240/120 circuits
and at $18 each, would have been a lot cheaper to do.
Old 05-28-2012, 02:17 PM   #116
_Ogre
_Ogre's Avatar
same with 120 circuits, to make 2 separate circuits if your panel is full of breakers
you can replace 1 20 amp breaker with a double 20 amp breaker
Old 05-29-2012, 09:38 PM   #117
shadow1967
shadow1967's Avatar
Well the 2 halves are rejoined. Waiting to hear about ac from Justin. Waiting for center vent to come from Canada, ay. 14 days for the mounty to bring by horse back.....
Old 05-29-2012, 10:07 PM   #118
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 05-30-2012, 07:01 AM   #119
ChuckDriver
Nice work, it's looking great. What style AC vents will you be using? Did you see the pics I added to my build?
Old 05-30-2012, 09:10 PM   #120
shadow1967
shadow1967's Avatar
I'm thinking this.....maybe....
Old 05-30-2012, 09:12 PM   #121
shadow1967
shadow1967's Avatar
I got the steering column area filled in and started with modifying the ash tray and lighter.....
Old 06-07-2012, 08:03 PM   #122
shadow1967
shadow1967's Avatar
Well yesterday I walked into the garage to see this note. And I assemblied the front end complete to check for clearence issues.
Old 06-07-2012, 08:07 PM   #123
Kim57
Kim57's Avatar
Cool more pictures.
Looks like a couple of Ninja weapons sitting there.
Kim
My build thread
Old 06-07-2012, 08:09 PM   #124
shadow1967
shadow1967's Avatar
The bully dog engine programmer in ash tray is done!!
Old 06-07-2012, 08:41 PM   #125
ChuckDriver
Nicely done! When will you have the dash fully installed?
