07-19-2012, 01:28 PM | #101 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1958 LS2 with C4 front and rear
I am not very versed in LS setups but give me a couple of weeks.......lol
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
07-20-2012, 08:54 AM | #102 |
I sent you a PM regarding some of your "Take Off" parts from this project.
07-25-2012, 10:20 AM | #103 |
Anyone know where to get the aftermarket carpet piece that trims the carpet along the top of the inside step. I saw a truck with one on it and really liked it and would like to find them.....it's some kind of hard plastic trim that rings the edge of the step and carpet...
09-01-2012, 10:07 AM | #104 |
Well....
I haven't done many updates lately but i sure have done a ton of work ....I have 3 full truck builds in progress....but updates as follows...
09-01-2012, 02:03 PM | #105 |
Well I got all the parts for the bed at long last.....it wasn't pretty tey shipped a short box step side instead of the fleetside....Apparently if you need afleetside kit they have to be made the manfacturer doesn't stock them....anyway I got it and stained.....
09-01-2012, 02:05 PM | #106 |
It was the stainless strips that took so long to get....but it managed to work it's way into the truck....
09-01-2012, 02:08 PM | #107 |
Well the gas tank filler was a .....expierence....When e welded the filler tube section in place it moved from the heat and made things really difficult. But with some time and a good game plan we managed to get it finished and it really looks clean.
09-01-2012, 02:10 PM | #108 |
Drive shaft has been shortened and is in....Fuel lines are in...tranny lines are in....shifter is hooked up....brakes are bled....air system is pretty much buttoned up...battery wire set up is done......it's getting closer every day
09-01-2012, 02:12 PM | #109 |
swapped out the intake for the corvette intake....not a huge job went easy once i could find some itake bolts fr the intake. After looking everywhere after markey ARP and whamo.....
09-01-2012, 02:13 PM | #110 |
Oh and but the way the trailblazer intake bolts not even close.....and the injectors don't swap over either.....
09-01-2012, 02:16 PM | #111 |
Well....
Started opening up the harness and taking out what we don't need...For a old school guy like me this LS stuff sure has alot of wires. But hey it's sink or swim time so we dove right into it....
09-01-2012, 02:20 PM | #112 |
The main harness is on the engine....still have some change to make yet...One section of harness left to take apart but i am hopefull that we have it all figure out. I am nervous don't get me wrong but we are a couple of days working on it away from trying to fire it for the first time.....crosses my fingers.
09-01-2012, 02:21 PM | #113 |
Oh and some kind of spacer on the front of the intake to bolt on the air flow......yea i know but how hard can that be right ?
09-01-2012, 04:25 PM | #114 |
Looks like you're getting real close. The bed looks great.
Kim |
09-02-2012, 12:05 PM | #115 |
Great build and lots of info did you use stainless to make the top radiator hose connector,on my project I had a stand alone harness made,the EFI is all new to me,keep up the good work.
09-03-2012, 12:01 AM | #116 |
Looking great, now hurry up and get it running. Gonna be sweet!!!!
09-03-2012, 08:59 AM | #117 |
Hey thanks... It's the first kit I have ever used, usually I would start with rough oak and run and make it ll custom.....this way sure was faster but it comes with it's own issues.
09-03-2012, 09:01 AM | #118 |
Yea both the upper and lower rad hoses are stainless and custom fit. There is a small piece of rubber hose at each end that is basically heat shrinked onto finish it off. It was just too tight for a rubber rad hose.
09-03-2012, 09:03 AM | #119 |
I am trying........I am tryinggggggggggggggggg......This build has certainly not been the easiest. It's just a fight the entire way but am in the home stretch now.
09-03-2012, 11:58 AM | #120 |
dang, your truck is looking good
wiring looks scary enough
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-03-2012, 01:59 PM | #121 |
Ogre
Thanks man...yea there is some wire there for sure
09-04-2012, 03:00 PM | #122 |
6>8 Plugless........
Hey buddy, it's looking great! Shouldn't be long now. Good luck!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-04-2012, 08:17 PM | #123 |
looks great, have fun with the wiring. I'd def go with an expensive aftermarket harness. I was thinking of this route for a future project, def not looking forward to the wiring on it though, sensor this, sensor that. luv the truck though
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
09-05-2012, 09:25 AM | #124 | |
I sure hope so....this build was way bigger then it was going to be when it started...
09-05-2012, 09:34 AM | #125 | |
Well i guess we will see....I should be turning the key soon...We found a guy who is going to tune the computer and set it up. Just waiting on him at this point
