Old 03-13-2013, 06:10 PM   #101
Square_78
Square_78's Avatar
Re: Baby blue 1970 GMC LWB resto-mod
Pulling out the long tube headers tomorrow. Flowtech 1969 Camaro shorty headers and Remflex header gaskets going in. USing the existing mufflers and remounting them under the cab to make room for trailing arm movement. Not sure exactly what they are but they are loud and throaty and sound way too good to replace.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 03-13-2013, 09:41 PM   #102
jkeating1
jkeating1's Avatar
Hit the spot on both items! I'll be watching to see how the headers fit. I like your mid-length (or whatever the term is for that) better than the real short ones I've been shopping (like Sanderson's block huggers, that point more-or-less straight down).
And I can't stand oil leaks, Bro! I'll give $75 for a gasket that works. What does that gasket call for as far as bolt torque, if you know? I mean---as thick as it looks, I just wondered if it has a real narrow allowable torque range to keep from deforming. Looks high tech!
JK
jkeating1 is offline   Reply With Quote
Old 03-13-2013, 09:57 PM   #103
Square_78
Square_78's Avatar
The headers I have I guess are technically mid length. As long as they don't hang down below the frame then I will be happy. The gasket has metal inserts where the bolts go through that only allow it to deform a certain amount. I honestly didn't look at the instructions. My friend (mechanic) installed it for me.
#teamlongbed
Old 03-14-2013, 12:25 AM   #104
jkeating1
jkeating1's Avatar
That IS a far cry from the cork gasket that truck had new! What brand?
JK
Old 03-14-2013, 06:57 AM   #105
Square_78
Square_78's Avatar
Its the Fel-Pro one piece silicone neoprene gasket with metal core. Its pretty much the best one you can get. You dont need to silicone 4 pieces of gasket together around the main-seals and pray it doesnt leak. Its expensive, but its worth it to not have to worry about pulling the pan again anytime soon. Summit racing has them cheap. Im in canada and they seem to retail for around $100. I got mine for $70 or so. I dont mind spending the extra to not have to worry about it. It was a couple hour job to swap the gasket out. Dont want to have to do that again.
#teamlongbed
Old 03-14-2013, 04:51 PM   #106
Square_78
Square_78's Avatar
Update: couldn't build a better fitting header if I tried. Absolutely perfect clearance around the frame and motor mounts. Please ignore my ugly motor. It's next on the list for attention and custom work.
Flow tech shorty (mid length) 1967-69 camaro / chevelle. Paid $140 new from Lordco auto parts.
#teamlongbed
Old 03-14-2013, 06:29 PM   #107
shawno72
C/10 junkie
shawno72's Avatar
What kind of engine mount set up do you have?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-14-2013, 07:11 PM   #108
Square_78
Square_78's Avatar
No idea. Whatever the truck came with when i bought it. Looks like factory mounts to me.
#teamlongbed
Old 03-14-2013, 08:11 PM   #109
Square_78
Square_78's Avatar
Holy crap it's LOUD hahaha. Exhaust dumps down just after the cab. I'm not running it out the back until I get my bed floor cut out and get the truck bagged so I know where the axel is going to sit. Sounds amazing, but it's loud lol
#teamlongbed
Old 03-15-2013, 12:13 PM   #110
rusty_67
rusty_67's Avatar
Looks like the 73 and newer mounts (also used on 72 big blocks), same ones I'm using on mine.
Who is doing your exhaust? kit or custom? material? mufflers? Sorry for 20 questions, its something I need to start thinking about.
rusty_67 is offline   Reply With Quote
Old 03-15-2013, 04:37 PM   #111
Square_78
Square_78's Avatar
My buddy and I are doing it at his shop. He does exhaust. I reused all the existing tube and mufflers. It was a fairly new 3" dual exhaust setup that we cut out and rebuilt. Coyne automotive downtown. 991 Ellis st. Ask for Gil tell him Lonnie sent you.
Lonnie.
#teamlongbed
Old 03-19-2013, 08:11 PM   #112
Square_78
Square_78's Avatar
Got my bags and plates in the mail today! Went and bought all my hardware to bolt it up and some good bits to drill the holes. Wow all the little things add up. $50 for grade 5 hardware, $100 for drill bits... I'm frightened to see what the total cost of this suspension is going to be when it's done.
My little dog has never seen an air bag before. He's so cute.
#teamlongbed
Old 03-26-2013, 08:42 PM   #113
Square_78
Square_78's Avatar
Well I FINALLY got all my CPP parts this week. Jeff from CPP was awesome and it was no fault of theirs. My parts were actually held up in Canada Customs for months due to an unpaid Brokerage bill owed by my parts retailer stores head-office in Vancouver. Thanks to Randy from KMS in Kelowna for making it all right in the end.
I got:
CPP gold power booster and master cyl with adjustable proportioning valve
71-87 CPP modular 2" drop spindles with 12" rotors and black powder coated calipers.
New 73-87 upper and lower ball joints and inner and outer tie rod ends.
CPP deluxe adjustable track bar for the rear axle.
MIght be a month or two before I get it all installed. Need to save up a couple bucks to get my buddys shop to install it all. Since they are brakes and installing them properly is a big safety concern, I am going to get it all professionally installed. In the meantime, now that the weather is nice, I am going to get my Accuair EXO mount bolted up and wired. Then i am going to pull out the wood bed floor and get my c-notch and rear bags installed and plumbed, 2" lowering blocks installed and adjustable track bar installed. Then the rear is pretty much done. The front end is going to be a lot more work and $$$ so I am doing it last.
#teamlongbed
Old 03-26-2013, 08:47 PM   #114
Square_78
Square_78's Avatar
Truck load of parts!
#teamlongbed
Old 03-26-2013, 10:05 PM   #115
HotRod C/10
HotRod C/10's Avatar
Had the truck in my buddy's shop today. Oil change, filter and new oil pan gasket. I went with the Fel Pro one piece silicone rubber gasket. It cost me $75 but I think it's worth it not to have to worry about it leaking again. Sure is a nice looking gasket. Appointment booked for tomorrow AM to do my exhaust and shorty headers. Going to tuck the exhaust up and cut holes through the trailing arm crossmember. I'll post more pics tomorrow of that.
I just bought that very gasket at oreilleys for $39.00!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-26-2013, 10:44 PM   #116
Square_78
Square_78's Avatar
Everything costs a little more up here in Canada
#teamlongbed
Old 03-27-2013, 01:56 PM   #117
rusty_67
rusty_67's Avatar
Gotta love bringing home the boxes of parts, its like christmas... until you look at your credit card statement that is.
I stopped in to see Randy the other day, but he was holed up in the office on the phone with Vancouver. What do you wanna bet your parts were the subject of that call.
Glad you finally got them.
Old 03-27-2013, 06:28 PM   #118
Square_78
Square_78's Avatar
Yeah I ended up buying a lot more than I had originally ordered. That's why I have to wait a little longer to install it all now. Ran out of funds
#teamlongbed
Old 03-30-2013, 11:07 PM   #119
Square_78
Square_78's Avatar
Got my EXO mounted to the frame with the tank and compressors. All wired up and solenoid installed. Power cables and everything. Fired it up and it works like a dream. The dual compressors fill the tank in 1min 40seconds from empty. No leaks that I can see. Everything works like it should. Pulling out the bed floor and rear wheel tubs tomorrow. Shop time is booked all day next wednesday to do the c-notch, lowering blocks and bolt in the rear bags. Might even do the fronts if time allows. I have access to a plasma cutter so hopefully it wont take too long.
#teamlongbed
Old 03-31-2013, 07:24 AM   #120
jkeating1
jkeating1's Avatar
take your camera!
JK
Old 03-31-2013, 07:56 AM   #121
Square_78
Square_78's Avatar
I know... i get so excited when Im working on it, that i forget to take any pics! I'll do my best to get some.
#teamlongbed
Old 04-01-2013, 11:42 PM   #122
Square_78
Square_78's Avatar
-Bed floor section cut out and ready for the notches.
-marked out frame for cutting
-chiseled out the old drip rail caulking, primered and put on new seam sealer and its curing right now.
Going to paint the roof satin white tomorrow. I will post some pics when its done.
#teamlongbed
Old 04-02-2013, 08:43 PM   #123
Square_78
Square_78's Avatar
Finished the roof today...
Classy & waterproof.
#teamlongbed
Old 04-04-2013, 06:22 AM   #124
Square_78
Square_78's Avatar
10 hours under the truck today... Got the back finished.
c-notches done
CPP 5" drop shocks
Air bags mounted on trailing arms
2" lowering blocks
CPP deluxe track bar
It sits 1" lower than this in the back when aired out. This is just lifted up a bit so I could pull it out on the street and forgot to drop it before snapping some quick pics.
Front end is getting done on Saturday.
#teamlongbed
Old 04-06-2013, 02:42 PM   #125
Cameron 1137
Cameron 1137's Avatar
looks awesome! great job.
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
