Old 04-04-2013, 10:35 PM   #101
85burb
85burb's Avatar
Re: 85 lwb turbo 5.3 build
There is no way I am putting painted headers on. One trip around the block and they will be bare. And I may be putting a turbo on it still. Not looking to spend lots of money on something I am just gonna take off.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-04-2013, 11:03 PM   #102
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my LY6 manifolds are just sitting in the storage building. a bit heavy to ship tho. I'd take a lil' trip in the old truck for fun if I had the vibration fixed (for which I have a plan)..... if you weren't so dang far.
to give you an idea of how they fit:
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-06-2013, 03:52 PM   #103
85burb
85burb's Avatar
Got some done today. Got my tps, iac, and fuel rail fittings in the mail today. Removed water pump and installed the ls1 intake.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-08-2013, 10:07 PM   #104
85burb
85burb's Avatar
I ordered some more parts to night. Ordered a throttle cable and bracket and bolts. Also ordered a throttle bracket to my suburban. Nally buick online parts is a amazing web site. Great drawings of the parts and good break downs. Also got a seat belt bracket for the wifes new gmc.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-08-2013, 10:39 PM   #105
85burb
85burb's Avatar
I was looking at the vette fuel filters and i was thinking about the way i need to run the fuel lines. One from tank to pump to filter. one from filter to tank. The one from filter to rails and a tee on the passenger side rail that a short hose goes to driver side rail. Will that work?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-08-2013, 10:44 PM   #106
85burb
85burb's Avatar
drawing.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-08-2013, 10:51 PM   #107
mooseknuckles
mooseknuckles's Avatar
I don't think you need to loop the system like that, just in the pass side fuel rail, out to drivers side rail, and a plug the end....not "tee'd" back in.
mooseknuckles is offline   Reply With Quote
Old 04-08-2013, 11:29 PM   #108
85burb
85burb's Avatar
I was thinking the same but I already have the fittings and hose. It should look cool with the extra crossover in the rear.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-09-2013, 10:10 AM   #109
Wasted Income
Boosted Member
Wasted Income's Avatar
If you're going with a turbo setup, I'd strongly consider putting together a return style system with a regulator up near/on the fuel rails. Much better setup for a turbo with the boost referenced regulator.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-09-2013, 10:13 AM   #110
85burb
85burb's Avatar
Yes if I do put a turbo on it will for sure get a return system. But I can't find a decent priced fuel pressure regulator. The lowest I found was over 100 bucks. If I can find one around 50 that is what I will use now instead of the vette fitter.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-09-2013, 10:32 AM   #111
Wasted Income
Boosted Member
The stock truck setup works great. It's not as pretty since you need to use the truck intake instead of the LS1, but it's VERY cheap, and good for around 500-550 rwhp.
Turbo diesel
Old 04-09-2013, 10:34 AM   #112
85burb
85burb's Avatar
The harness I have has car set up with wire routing and injector plugs.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-09-2013, 11:37 PM   #113
85burb
85burb's Avatar
So what pressure does the regulator need to be for. Will a 30-65 psi work? Many them things are expensive.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-10-2013, 10:30 AM   #114
Wasted Income
Boosted Member
Your fuel pressure should rise at a 1:1 ratio with boost.
Example: If your base fuel pressure is 58 psi, at 1 psi of boost, it should be 59 psi and at 10 psi boost, it should be 68 psi.
Doing it this way makes it easier to tune, since your injector flow should remain constant.
Turbo diesel
Old 04-10-2013, 09:12 PM   #115
85burb
85burb's Avatar
Ok i will order that fuel pressre reg that i seen cause it will have no boost for a while.
On a side note i got in the cold air intake kit today. Looks like a nice kit.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-11-2013, 11:39 PM   #116
85burb
85burb's Avatar
Test fitted the intake today. Also installed the egr plug. Not sure on where the intake pipe will end up after the water pump and hose is installed but this is where i want it to be so far. Need to order the rubber clamp that the maf goes in to mount the air filter. Got the part number already just have to call the local gm dealer.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-14-2013, 10:37 PM   #117
85burb
85burb's Avatar
I got the gen 4 water pump in the mail this weekend. Test fitted it and it is like it was made for the swap. Fits like a glove. Also figured out what i am going to do with the intake pipes. I put the belt on just to make sure the intake pipe will fit around everything. All i need now to test run is the fuel system.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-24-2013, 08:52 PM   #118
85burb
85burb's Avatar
I got the throttle cable and brackets i ordered the other day finally.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-25-2013, 11:06 PM   #119
85burb
85burb's Avatar
I had a slow day at work so i figured i would see if i could drop the factory tank. I am not going to use it anyways. I am going to put a cell in the rear frame area. The factory tank had way too much crap in it for me to use. I jacked the truck up to get under it and proceded to remove the pos plastic skid plate that goes over the tank. I may have found why the truck leans to the driver side. I pulled the shield down and a bout 30 pounds of crap fell on to the floor. And the bottom of the tank is rusted out i am sure. I am fully confidant i can put a screw driver smooth threw the bottom of it. It smelled like fuel and was damp. I gave up for the day due to dinner time coming up and i could not remember how to remove the tank. I now know there are 8 bolts to take out and the tank will come out with the brackets and all. May takle that this weekend. Boy am i happy i did not want to reuse that pos.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-28-2013, 08:19 PM   #120
85burb
85burb's Avatar
Made some good progress today. I removed the fuel tank then the bed. I will never know why in that order. I also figured out why i was always getting crap in my fuel filter. Fuel sock had a hole in it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-29-2013, 07:32 PM   #121
79shortbed
79shortbed's Avatar
Love the progress man! I am doing basically what you are. I may go turbo in the future, or 383 with H/C/I. What is the part number for the water pump you used? I'm going to use an LS6 intake on my 5.3 if I can get one reasonable.
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 04-29-2013, 07:34 PM   #122
85burb
85burb's Avatar
On idea on the part number. It is a 08 gmc water pump. Got it off eBay.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-30-2013, 10:21 AM   #123
Wasted Income
Boosted Member
Part number on that pump should be 19208815
Turbo diesel
Old 05-08-2013, 06:36 PM   #124
85burb
85burb's Avatar
Ordered my hole fuel system today from tank to fuel rails from summit. also ordered flywheel from advanced addapters. Hope to have it running soon.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-09-2013, 12:17 AM   #125
79shortbed
79shortbed's Avatar
What hose and fittings are you using? I need to do the same, just don't know what fittings I need to connect AN hose to the 87 sending unit
