Old 01-09-2013, 09:36 PM   #101
Xeen
Xeen's Avatar
Re: Project 69SWB
That cab is going to be like new again when you get done with it, nice work.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-10-2013, 12:55 AM   #102
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Let me know how those cab corners you get from LMC work out. I ordered one recently and it was not correct at all. Much like your front floorpan, which i also had a problem with. I think the use different suppliers from time to time, because I also have a set of corners I got from them quite a while ago. Which are Tri-Plus branded, which I have found to be pretty decent stampings. The one I got this time was some other manufacturer, and yeah, it wasn't right at all.
Nice progress btw. Lookin good!
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
Old 01-10-2013, 12:26 PM   #103
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks! That's the plan. :-)
Will do... Hopefully they'll work just fine. :-) They should be here tomorrow and I can get this side finished up and move on the the drivers side.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-11-2013, 11:41 AM   #104
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Well the cab corners are in and they seem to be well made.. nice and thick. Can't wait to get home tonight and do some fitting. Work on Friday should be outlawed. Also ordered my tires this week and dropped my wheels off this morning to have those mounted... so can't wait to pick those up either!
Jimmy
.69SWB Build.
Old 01-11-2013, 04:11 PM   #105
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Yeah, that was the same brand I got. The fittament was the issue, hopefully mine was just a bad stamp tho. But from where the corner overlaps the cab pillar to where the bend around the cab is, was way too long, like 3/4 -1", and the contour wasn't correct either. I'm crossing my fingers for ya!
Old 01-11-2013, 05:27 PM   #106
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Another cool project. Your cab sure brings back some fond memories...subscribed
mcbassin is offline   Reply With Quote
Old 01-11-2013, 08:39 PM   #107
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I got sidetracked this evening so didn't get to mess with the corners... You'll see why in then next post!
Thanks, and I know what you mean... It can be a lot of work at times, but I enjoy it. I hope to keep you entertained!
Jimmy
.69SWB Build.
Old 01-11-2013, 08:47 PM   #108
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Well I finally got my tires in. I went with Toyo Proxes ST II's. I've ran Toyo's for a long time and have never been disappointed by them and these look sick. They're a 1 directional tire so you gotta mount lefts and rights correctly. This will make rotating a little more of a hassle but I'm not worried about that at all.
On the front is 17x8 with 4"bs wrapped up with 255/60's
on the back is 17x9.5's with 5.5 bs wrapped up with 275/60's
I like a little more sidewall than the 50's have and I'm not sure yet, but I might need a spacer on the backs.
I could sit out in the garage and stare at these all night, but taking the night off for some time with my wife.
Jimmy
.69SWB Build.
Old 01-11-2013, 09:57 PM   #109
derrickmanx1
derrickmanx1's Avatar
Re: Project 69SWB
Lovin' the green. I like the rims and tires too. I had the hardest time picking the color for my project looking at pics like this. Nice project.
NAME: TRAVIS TRUCK: BRUISER
71 C/10 SWB 3.5/5" drop 4.11 GEARS.
F.A.S.T. BBC 408 496hp/479ft/lb
JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL
My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530
derrickmanx1 is offline   Reply With Quote
Old 01-12-2013, 02:47 PM   #110
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thank you. I'm really happy with everything so far. I miss driving it and can't wait to get it back on the road.
Jimmy
.69SWB Build.
Old 01-13-2013, 10:57 AM   #111
jmking9
jmking9's Avatar
Re: Project 69SWB
GREAT choice on the wheel/tire setup. Those will look awesome on that black truck. Have you tried those cab corners yet? I had the same experience as the other guy that posted earlier. I ended up cutting them up for patches on my cowl, so at least they werent a total waste of money. I ended up buying a set from GMC Pauls and they were much more like original. Hopefully yours are better. I could tell the ones I bought were junk when I took them out of the box. The pinch weld area was almost non-existant one one side, and they cups were wrinkled very badly on both. I hope they work out for you, but if they dont, I recommend GMC Pauls. Anyway, you are makin great progress on that cab.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 01-13-2013, 11:32 AM   #112
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Your doing a great job on your truck, the frame looks super nice. If your wanting some cab corners that are a better fit, try the Tabco cab corners. They cost a little more but worth it.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-13-2013, 07:17 PM   #113
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks! These are just as you described pretty much. They're nice and thick but the stamp is all wrong I'd say.
Thanks for the compliment. You guys are right... These LMC cab corners aren't the best fit... I messed around with them a bit earlier but didn't have a lot of time. It just seems like the are too wide and once attached to the pillar they won't attached to the rear floor without some serious bending and pounding. It's like they need about a 1/4 inch cut out of them. Ill mess with them a bit more tonight or tomorrow and if they're not gonna work ill look at some of the other you all mentioned. I don't know why I don't look through the vendor board more often... Might have save me the time and trouble with these.
Do you have a link for the Tabco corners?
Jimmy
.69SWB Build.
Old 01-13-2013, 08:30 PM   #114
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Here's a few pics. You can see what I'm dealing with on these LMC cab corners. I don't want that large gap where it meets the floor. The previous repair was done that way and then filled in with seam sealer. It made the back corners of the cab flare out and looked terrible. I guess I'm gonna try some different corners from whoever is closest to me so hopefully I'll get them this week.
Jimmy
.69SWB Build.
Old 01-13-2013, 09:34 PM   #115
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
These corners from LMC are not gonna work out. I mean I could slap them on there but they will be bowed out in the back that's not acceptable to me.
Ordered a set from GMC Pauls could not find anything for Tabco other than inner corners ?? .. We'll see how long it takes the GMCPauls to get here. Price was reasonable, shipping is alittle steep. Hope the extra $$$ is worth it. stay tuned on that.
UPDATE: Asked GMCPauls about the shipping cause it seemed a little high. Apparently I was charged double by accident and they have made it right. Great customer service.
Jimmy
.69SWB Build.
Old 01-13-2013, 10:13 PM   #116
Xeen
Xeen's Avatar
Re: Project 69SWB
Ya know its possible those are the slip on version and LMC doesnt know the difference and sells them as the direct fit replacement, I wouldnt put it past them.
Old 01-13-2013, 10:42 PM   #117
sduckworth13
Re: Project 69SWB
http://tabcobodyparts.com/ here is the link for Tabco sheetmetal
Just looked at the price, it looks like they are $14.50. Thought they cost more than that when I bought them. They are USA made.
Scott
Old 01-14-2013, 12:08 AM   #118
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Since they're wider I bet you're right.
Thanks Scott. I had found that site but couldn't never add anything to my cart and checkout, kept getting errors. I wanted to get those because they're made in USA but needed to get something ordered quick so went ahead and got GMC Paul's. I sure hope they fit. Fingers crossed.
Jimmy
.69SWB Build.
Old 01-14-2013, 12:13 AM   #119
Xeen
Xeen's Avatar
Re: Project 69SWB
Oh well you can use the poor fitting cab corners for scrap metal to fill holes, gaps etc, so you can put them to good use reguardless.
Old 01-14-2013, 12:30 AM   #120
sduckworth13
Re: Project 69SWB
Thats what I did, I bought several right hand cab corners till I went with the Tabco. I now have a cab corner stash that I use for my misc
patches.
Scott
Old 01-14-2013, 09:37 AM   #121
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
I used Tabco corners on my cab and they were the best fitting replacement panels I bought. Mine were pretty old though. Not sure on the vintage.
They were the correct thickness and close enough on the shape to make fit pretty easy. Good luck with any of the sheepmetal available for these trucks.
Old 01-14-2013, 10:34 AM   #122
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Damn! I've always been skeptical of LMC's quality, even though i buy quite a bit from them, but with every piece I see or hear about, I just don't think parts like sheetmetal can be trusted form them. I think Xeen nailed it, they're probably slip on replacements, and they have no idea... Tabco looks good, and Everything I've seen from GMC Paul looks pretty good. Pretty sure I'll be switching to them as my source.
Old 01-14-2013, 11:38 AM   #123
Bennett68C10
Bennett68C10's Avatar
Re: Project 69SWB
Tires & wheels look great
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-14-2013, 02:10 PM   #124
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I know I am too.. I'm still learning where the good places to get things for our trucks are. LMC has a great website and their stuff ships super fast and gets here quick since I'm only a couple hours aways from them. But I figure most of their stuff is gonna be made overseas. I would much rather buy from a company that has American made goods if I'm able and they're competitive in pricing.. I'll pay a little more USA stuff since I understand our government makes it harder on them to produce stuff here.
Thanks Keith!
Jimmy
.69SWB Build.
Old 01-14-2013, 03:10 PM   #125
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
little update. Emailed with Sky @ GMCPauls and apparently I was charged double for shipping and they are making it right. Very fast and courteous on the customer service, which means a ton to me. I'll definitely be ordering more from them in the future.
Jimmy
.69SWB Build.
1969, black, custom 10, fleetside, shortbed
