Old 12-07-2016, 10:31 AM   #101
flashed
Re: 1970 C10 LWB "Blu"
Truck looks good .
flashed is offline   Reply With Quote
Old 12-07-2016, 10:35 AM   #102
knomadd
knomadd's Avatar
I like the new stance and wheels. Looks good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-02-2017, 06:14 PM   #103
NC_John
NC_John's Avatar
Originally Posted by flashed View Post
Truck looks good .
Thank you fellas.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-02-2017, 06:36 PM   #104
NC_John
NC_John's Avatar
So much for changing the external seals/gaskets, sticking a cam in and dropping in the LQ4. My OCD would not allow me to install the engine without making sure everything is 100% right. Stripped it to the bare block.
Dropped it off at the engine shop on Saturday (RF Engines and Development in Concord, NC)
Still not sure what all we will do. Still considering options that cover everything from a quick hone to a full stroker kit.
1970 C-10 LWB "Blu"
Old 01-02-2017, 06:41 PM   #105
NC_John
NC_John's Avatar
My Boyd's Welding tank is waiting to be installed (once the engine/trans is back in and the front clip is back on.
My vintage air kit should arrive in the next week.
1970 C-10 LWB "Blu"
Old 01-14-2017, 09:59 AM   #106
ChuckLee
See your SNS cam for sale. Haha. Keeping original plans is hard bro! I've also gone completely new direction with my motor. Details to come in a week or less. Hey, how did your cam bearings look? Could you photograph them for me?
Here was the front cam bearing on mine:
Looks fine on top,
https://flic.kr/p/Ra14V5
And here is the bottom of Same bearing. Notice babbit is gone, hello copper. SUPPOSEDLY this is totally normal and shouldn't concern me. Lol. I don't know.
https://flic.kr/p/QDaSed
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-14-2017, 11:45 AM   #107
NC_John
NC_John's Avatar
Looks fine on top,
Sorry man, like you saw, block is at the race shop getting prepped. The only cam bearing pic would be the one a few posts ago of the bare block. I had some copper showing but not quite that much. By what I've seen (and probably you too) on Ls1tech, it's pretty normal. I had 140k on mine, what was on yours?
What are you doing to yours now?
I've gone off the deep end on mine, full Callies stroker kit, all ARP fasteners throughout. I'm building the same bottom end the race shop uses on their 1,000 hp road course engines. The cam I initially spec'd (and am selling) was perfect for the stock displacement and bottom end but it too small for the stroker (and will give me way too high a dynamic compression for pump gas).
My bores are cleaning up perfectly at .005" so it looks this this time it'll be a 403 ci. I wanted to go 416 but the shop said if something goes wrong in that motor, the block will be done. With over $1,100 just in machine work on the block alone, I want to make sure I at least have a chance to do a rebuild or two, change pistons if I boost it later, whatever....
1970 C-10 LWB "Blu"
Old 01-15-2017, 03:08 PM   #108
Sicksty8
Sicksty8's Avatar
Sweet build man! I love the stance with those wheels and tires.
Sicksty8 is offline   Reply With Quote
Old 01-15-2017, 09:19 PM   #109
NC_John
NC_John's Avatar
1970 C-10 LWB "Blu"
Old 01-15-2017, 09:36 PM   #110
NC_John
NC_John's Avatar
With the engine at the shop things are a little stalled. Took advantage of some great weather and still got a little work done. Pulled the in-cab fuel tank out, removed the rest of the heater to prep for the vintage air and roughed in my fly by wire go-pedal. Then spent a couple hours scrubbing engine parts.
1970 C-10 LWB "Blu"
Old 01-18-2017, 09:54 AM   #111
NC_John
NC_John's Avatar
Big boxes of parts came in yesterday. Looks like I have some work I can do this weekend (install all the in-cab side of the Vintage Air setup).
1970 C-10 LWB "Blu"
Old 01-18-2017, 10:47 AM   #112
flashed
You are going to like that .
Old 01-18-2017, 10:52 AM   #113
GR8-68
GR8-68's Avatar
This is going to be one tough ride, I like the direction you are going with this.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-22-2017, 08:51 PM   #114
NC_John
NC_John's Avatar
Got some work done on the vintage air install today. Got the dash cutting done and vents installed. Vintage Air neglects to mention the dash pad has got to come off to cut the center vent. So with the dash pad comes out the instrument cluster. Hard to see progress when I have to keep taking stuff apart. I also painted the firewall covers. Doesn't look like like much but took a good six hours.
1970 C-10 LWB "Blu"
Old 01-22-2017, 08:57 PM   #115
NC_John
NC_John's Avatar
Yeah, it should make driving it in the summer a lot more enjoyable. Should get a lot more miles on it (when it gets "finished").
Thanks Larry.
1970 C-10 LWB "Blu"
Old 01-22-2017, 09:52 PM   #116
Batgirl
Batgirl's Avatar
Nice work! and the dash cutting looks great
Batgirl is offline   Reply With Quote
Old 01-22-2017, 10:24 PM   #117
NC_John
NC_John's Avatar
Thank you.
1970 C-10 LWB "Blu"
Old 01-22-2017, 11:08 PM   #118
dfwright
dfwright's Avatar
Dash cuts look good. I like the idea of painting the firewall cover pieces. I hadn't thought of doing that, but now that I see yours, I think I'll do the same when I get to that point.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-23-2017, 07:20 AM   #119
NC_John
NC_John's Avatar
The blue is a little off from that on the body but that's due to not having the same base coat (I sprayed the blue directly over the black primer of the parts). I think when it's enclosed under the hood though, most people won't notice and it will certainly hide a lot better than being kept black.
It's kind of temporary anyway. I reckon when I do a full frame off (someday, someday), the firewall will get smoothed and done properly. Mine is a piece of Swiss cheese with all the factory holes that are no longer needed.
1970 C-10 LWB "Blu"
Old 01-23-2017, 09:18 AM   #120
Hart_Rod
Hart_Rod's Avatar
Nice truck John.
Hart_Rod is offline   Reply With Quote
Old 01-23-2017, 10:26 AM   #121
MMcMasters
MMcMasters's Avatar
Very nice truck!!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 01-23-2017, 02:28 PM   #122
NC_John
NC_John's Avatar
Originally Posted by Hart_Rod View Post
Nice truck John.
Thanks Rob. I finalized the DBW adapter bracket yesterday as well and put a quick coat of paint on it yesterday. Had to notch it for the taillight wiring plug but looks like it should work nicely.
Originally Posted by MMcMasters View Post
Very nice truck!!
Thanks Mike.
1970 C-10 LWB "Blu"
Old 01-23-2017, 02:51 PM   #123
nastety92
Looks great John. Keep up the good work. Looking forward to seeing it all done. Do you plan on having it road worthy this year?
nastety92 is offline   Reply With Quote
Old 01-23-2017, 03:11 PM   #124
NC_John
NC_John's Avatar
Thanks. I would love to get it back on the road this year but the way the engine build keeps escalating, finances may make it difficult to finish in time. I'm paying as I'm going along and have rapidly funneled my designated radiator/steering/harness money into the engine.
1970 C-10 LWB "Blu"
Old 01-28-2017, 07:41 PM   #125
NC_John
NC_John's Avatar
Got my DBW accelerator pedal with the Hart_Rod supplied bracket mounted today. I'll have to find a good spot where I can mount the TAC module.
1970 C-10 LWB "Blu"
