Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-04-2013, 09:07 PM   #101
Vova
Re: 71 4X4 Frame off Restoration
Originally Posted by DWilbur View Post
After fitting the cab and getting it close I noticed that the tuck roof line is very low. A lot further off than I thought it would be. I'm thing about cut below the rear window at the line marked on the back of the cab and raise it up to fit the roof line better and fill in with a patch panel. It would be about 3 1/4" fill peice. I will see if there is anything else I can do for a better fit at the top.
Can you take a side shot to see the roofline?
Vova is offline   Reply With Quote
Old 11-04-2013, 10:15 PM   #102
DWilbur
I don't want to cut the roof line down. I'm 6'-5" tall and need the extra inches the burb offers. more pictures of the difference in hieght.
DWilbur is offline   Reply With Quote
Old 11-04-2013, 10:43 PM   #103
72kool
72kool's Avatar
love what your doing and your metal work is great! just wondering bout the problem of the height difference, could you cut the back off the 'burb and customize the rear to replace the door? but your height problem wouldnt be an issue?
72kool is offline   Reply With Quote
Old 11-04-2013, 11:41 PM   #104
DWilbur
The back door of the burb is above the rain gutter not enough material to work with. I have been thinking about using the right and left corner of the burb roof. But I still have the issue with how things line up inside the cab. I leaning twards cutting below the back window and raising it up to meet the roof and add a filler peice below. I saw a picture of a quad cab that they raised the roof above the window and it looked odd.
Old 11-04-2013, 11:51 PM   #105
swamp rat
swamp rat's Avatar
I don't know if you have seen this guys thread yet but he seems to have some pretty good ideas going. This is all way over my head so i know i cant help any.. Good luck!
http://67-72chevytrucks.com/vboard/s...d.php?t=557019
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-05-2013, 07:15 PM   #106
DWilbur
I checked out some of the other quad cab build and it looks like I have taken a different path keeping the burb high roof. Most are cutting the burb behind the front door and keeping most of the truck cab for the back door.
Old 11-09-2013, 02:01 PM   #107
DWilbur
I finally recieved the replacement right side floor patch panel. I miss cut the first one couple weeks ago. My plan this week end is to finish fitting the burb and truck cab together and tack weld them. I have a lot of sand blasting to do today.
The bad news is my 2012 Dodge Ram is likely to be totaled do to the damage. the front axcel and frame are bent along with all the sheetmetal damage. the repair cost is over $25,000.00.
Old 11-09-2013, 09:00 PM   #108
swamp rat
swamp rat's Avatar
Bummer on the truck being totaled, it means buying a replacement now, i guess the good out of that would be if you weren't absolutely happy with the truck you could get a different brand/model, still a hassle and headache meaning more payments.
Can you tell me what size of compressor you use to push the sand blaster?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-10-2013, 01:31 PM   #109
DWilbur
The air compressor was my dads. The pump burned up couple months ago and I replaced it with one from Harbor Freight I think it is rated at about 4 HP. it's a 2 piston pump. Then I burned up the motor do to the wrong shiv size. Bought a motor from Harbor Freight and changed the shiv to match the correct RPM of the pump. It gets the job done but I run out of air about 4 to 5 minutes and have to let the compressor build up presher. the pump is on top of a 60 galon tank.
Old 11-10-2013, 10:25 PM   #110
DWilbur
I spent a day and half meadia blasting the back of the burb and the back of the cab so I can weld them together. There was a fare amount of rust but no rot.
Old 11-10-2013, 10:30 PM   #111
DWilbur
My brother stopped by this afternoon and he helped me fit the back of the cab to the burb and we got it tacked welded in place. the side fit good just have some smothing out to do at the bottom corners then I can finish welding it up.
Old 11-18-2013, 06:09 PM   #112
DWilbur
I spent Friday evening and Saturday Morning removing all the aftermarket part and camper shell off my 2012 Dodge the insurance co totaled it Tuesday. I spent a good portion of my day Friday trying to getit back from the POS body shop jacked me around. I started having trouble Sunday welding my Miller matic 200 mig welder is acting like there is no shielding gas and I did remove the pain from the back of the cab. I'm welding clean sheet metal. I may have to take it in and have it checked out. the bummer is I started working a job that is 58 mile one direction. most stores are closed by the time I get home at night. I might have to wait until the swing shift starts next week so I can drop it off.
Old 11-18-2013, 10:40 PM   #113
JJH Jimmy
JJH Jimmy's Avatar
Sorry to hear about your truck. At least you were not in it. You may want to check that the mig gun hose is fully inserted into the welding machine. I have had mine come out a bit by dragging it around my shop by the hose and it acted like yours.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 11-19-2013, 02:36 AM   #114
DWilbur
Thanks for the heads up I will check out the liner to if I'm having a simular issue.
Old 11-25-2013, 10:39 AM   #115
DWilbur
It would be great if I could win the loto then work would not get in the way of building my truck. I bought another 2012 Dodge truck that almost matches the one I lost last Wednesday. I still have to work on the issue with my mig welder working so I can weld up the cab. I spent the week end helping my brothers do some work on my mother place up north this week end. so No work was done on the truck.
Old 11-25-2013, 08:03 PM   #116
swamp rat
swamp rat's Avatar
On the 2nd picture of this thread you stated you got a new 6" lift kit on the truck, was the kit new and did it include shocks? just wondering what kit and shocks, if you can did up the info i'd be appreciative.
Also wishing you the best with the new truck, may it be a good and dependable one!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-26-2013, 11:19 AM   #117
DWilbur
Hello Swamp Rat
Yes the 6" lift is a Supper Lift kit I bought from 4 Wheel parts. it came with shocks I added drop drag link and drop pitman arm for the D60 I will be installing.
Old 11-26-2013, 10:01 PM   #118
swamp rat
swamp rat's Avatar
I went to 4wheel, I'll assume it was a skyjacker, Thanks!
I'm still finding it strange that your 6" and my 4" from BDS appear to be almost identical in lift.. I have 12" from my 33"BFG to the top of the fender well in the front.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-27-2013, 10:34 AM   #119
DWilbur
That's right it was Skyjacker lift kit. I would check the 12" dimension but my truck is in pieces. I could measure from the frame to the ground front and back. the only thing is no engine in front and cab is cut up no bed.
Old 11-27-2013, 01:27 PM   #120
swamp rat
swamp rat's Avatar
Naw don't sweat it, its just my mind spinning looking for info to crunch, were in different stages so nothing to compare.
Have a great Thanksgiving!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-02-2013, 10:01 PM   #121
DWilbur
I stopped by the welding shop this morning and checked out my mig welder. I hope to get it back by Friday. I also had an issue with PG&E in my area they replaced a transformer. It could be possible the the failing transformer could have an effect to my mig welder. I did cut the back of the suburban off Saturday so I can fit it with the back of the truck cab. no pictures this week.
Old 12-05-2013, 06:17 PM   #122
DWilbur
The welding shop called and there is nothing wrong with my mig welder. I'm picking it up Friday morning and getting the bottle filled. I think the nabor hood transformer seams to be the issue. I will check voltage on the 220 outlet see what the voltage is. I hope to be welding on the cab this week end.
Old 12-05-2013, 11:40 PM   #123
swamp rat
swamp rat's Avatar
Just a thought, could it be an amperage issue? Check that out too cause i think most houses are 20A and welders seem to say 25A. Don't know how much that would make a difference if any.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-09-2013, 10:29 PM   #124
DWilbur
I talked to my neighbor Saturday he said PG&E used a sub-contractor to repair the transformer and they wired 1 hot lead to neutral wire at the power poll and damaged 19 house hold items. But my welder was unplugged when this happened. The circuit is a 30amp breaker the welder can push 50 amps cranked up all the way.
Old 12-09-2013, 11:57 PM   #125
AirSpeed
AirSpeed's Avatar
Our cloths dryer motor burned up twice and fridge compressor died in one month, couldn't understand why. One day i was standing near where the wires enter my house and could hear a sizzling sound, touched the splice and it was hot as hell, turns out it was barely connected and those motors were fried trying to start with limited amperage.
AirSpeed is offline   Reply With Quote
