Old 01-05-2014, 11:43 PM   #101
59stepside
59stepside's Avatar
Re: 1959 Chevy Truck
Originally I made the cardboard cut out for moving centerline 1 " forward. But later decided to go 1 1/2" so that's why there is a half inch gap in front of cab mount. And it worked out because that's where I welded earlier anyways.
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 01-05-2014, 11:46 PM   #102
59stepside
59stepside's Avatar
Ff
USCG Aviator
C-130
Old 01-05-2014, 11:48 PM   #103
59stepside
59stepside's Avatar
Ll
USCG Aviator
C-130
Old 01-05-2014, 11:50 PM   #104
59stepside
59stepside's Avatar
Tt
USCG Aviator
C-130
Old 01-06-2014, 12:41 AM   #105
Kim57
Kim57's Avatar
Nice progress.
I like the engine color.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-06-2014, 08:21 AM   #106
59stepside
59stepside's Avatar
Thanks Kim!
USCG Aviator
C-130
Old 01-09-2014, 12:17 AM   #107
bigtim44
bigtim44's Avatar
Great build,I used the same approach fitting the Camaro clip aswell from the HAMB , works great.I think it drops the truck about 7 inches from stock and the Camaro suspension is still at oem ride height.
bigtim44 is offline   Reply With Quote
Old 01-09-2014, 09:50 AM   #108
59stepside
59stepside's Avatar
Thanks! It seems like a dumb proof way to do it. I am looking forward to welding it all up. How far did you move your centerline forward?
USCG Aviator
C-130
Old 01-09-2014, 10:45 AM   #109
bigtim44
bigtim44's Avatar
Thumbs up Re: 1959 Chevy Truck
I moved the centerline forward about the same as you. Test fit your cab and front clip, with the radiator support bolted in between the fenders,the radiator support will just miss the steering box if its on the money.
Old 01-09-2014, 11:32 PM   #110
59stepside
59stepside's Avatar
Thanks. That's the plan I'm shooting for right now. I hope to get some work done on it this weekend.
USCG Aviator
C-130
Old 01-11-2014, 09:44 PM   #111
59stepside
59stepside's Avatar
I have gotten the camaro clip all lined up and frame trimmed for final fitment. I have measured this thing so much I prob have them all memorized!
USCG Aviator
C-130
Old 01-11-2014, 09:45 PM   #112
59stepside
59stepside's Avatar
C-clamped
USCG Aviator
C-130
Old 01-11-2014, 09:47 PM   #113
59stepside
59stepside's Avatar
I made sure to use weld through primer in the areas where I will never see again after welding. Top of camaro frame and bottom of truck frame.
USCG Aviator
C-130
Old 01-11-2014, 09:49 PM   #114
59stepside
59stepside's Avatar
I have been welding all evening. No pics yet, but soon.
USCG Aviator
C-130
Old 01-11-2014, 11:22 PM   #115
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looking good!
ChuckDriver is offline   Reply With Quote
Old 01-11-2014, 11:39 PM   #116
59stepside
59stepside's Avatar
Thanks Chuck!! Hopefully I can finish up the welding by tomorrow. So happy it's going to be a rolling chassis again.
USCG Aviator
C-130
Old 01-12-2014, 12:06 PM   #117
Kim57
Kim57's Avatar
Looks like a real nice fit.
Kim
My build thread
Old 01-13-2014, 11:05 PM   #118
59stepside
59stepside's Avatar
Getting it welded up
USCG Aviator
C-130
Old 01-13-2014, 11:06 PM   #119
59stepside
59stepside's Avatar
Welded up
USCG Aviator
C-130
Old 01-13-2014, 11:11 PM   #120
59stepside
59stepside's Avatar
The welding never ends!! There is a substantial amount of linear ft of weld with this swap! I have no doubt this thing will hold up. And boxing plates after this seem like overkill almost but what the heck, why not...
-----Q: did everyone just box the frame all the way back to that first crossmember?
USCG Aviator
C-130
Old 01-13-2014, 11:17 PM   #121
59stepside
59stepside's Avatar
Since I ran out of wire for the welder, me and my three year old tore apart the camaro front end tonight. And last night ordered the whole front super whatever kit from p-s-t.com. They had a great deal going, saved $60 off the kit. Ended up being $330 for everything. Ball joints, control arm bushings all tie rod ends, idler arm, bump stops, sway bar bushings and endlinks, control arm shafts, and adjustment sleeves. Couldn't find a better deal anywhere else and this was for the really good polygraphite bushings.
USCG Aviator
C-130
Old 01-14-2014, 12:00 AM   #122
bigtim44
bigtim44's Avatar
Looks great,thats a sweet deal on the rebuild parts for the clip.
In my opinion theres no need to box the frame putting the clip in this way.If you think about the 4 bolts holding the subframe onto the bottom of a Camaro, the welding will be a much stronger attachment.
If your going with an underfloor mounted brake booster and pedal setup the boxing plates will screw up the mounting location.
Old 01-14-2014, 12:07 AM   #123
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 01-15-2014, 10:47 AM   #124
59stepside
59stepside's Avatar
Thanks guys. I'm going with a firewall mount brake booster from the camaro so I will prob just add some boxing plates to clean it up a bit. I got some parts sandblasted and painted last night. Going with the hammered finish silver/grey for the frame and some suspension parts.
USCG Aviator
C-130
Old 01-15-2014, 10:51 AM   #125
59stepside
59stepside's Avatar
Hammered finish.
USCG Aviator
C-130
