Old 04-30-2014, 11:31 PM   #101
AGearHead4Life
AGearHead4Life's Avatar
Re: Finally starting my 5.3 swap!!
Originally Posted by ivorton74 View Post
oh ok that's good then cuz we got so far already to pull that motor out again. we should have the cab back on tomorrow hopefully...keep checking my posts..ill probably have more questions for u
Cool! I'll be watching when I get breaks.
AGearHead4Life is offline   Reply With Quote
Old 04-30-2014, 11:39 PM   #102
ivorton74
ivorton74's Avatar
Originally Posted by AGearHead4Life View Post
Ivorton, I dont mean this to be rude, Im just curious. Do you read back to see if you've missed any posts? It seems like you've missed some of the comments.
yea I just went back and read some...seems I missed one or two posts...sorry about that. im back and forth between this page n youtube on ur channel
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 04-30-2014, 11:49 PM   #103
ivorton74
ivorton74's Avatar
hey do long bed and short bed truck have different drive shaft lengths?
Old 04-30-2014, 11:55 PM   #104
AGearHead4Life
No problem man. Just wanted to make sure you saw that post #72.
Old 04-30-2014, 11:56 PM   #105
AGearHead4Life
[QUOTdifferenton74;6654325]hey do long bed and short bed truck have different drive shaft lengths?[/QUOTE]
Yea, different lengths.
Old 05-01-2014, 12:05 AM   #106
ivorton74
ivorton74's Avatar
Yea, different lengths.[/QUOTE]
oh ok...
just got done watching the torque sequence video. I actually wanted to take the heads off to do the head gaskets since the motor has over 240k miles on it but the guys said its very rare for an ls motor to need head gaskets and the guy who owned the truck it came out of did lots on maintenance work on it...changed oil on time and everything. the truck it came out of was t boned by a semi but the engine still ran great.
Old 05-01-2014, 12:09 AM   #107
AGearHead4Life
oh ok...
just got done watching the torque sequence video. I actually wanted to take the heads off to do the head gaskets since the motor has over 240k miles on it but the guys said its very rare for an ls motor to need head gaskets and the guy who owned the truck it came out of did lots on maintenance work on it...changed oil on time and everything. the truck it came out of was t boned by a semi but the engine still ran great.[/QUOTE]
Nah, no need to pull them. It just cost money to put back on. Those gaskets don't go bad very often at all. I only did it because I ported the heads and installed 4.8 flat top pistons.
Old 05-01-2014, 12:16 AM   #108
ivorton74
ivorton74's Avatar
ok...are u gonna go turbo down the road or u gonna keep it n/a?
Old 05-01-2014, 12:18 AM   #109
ivorton74
ivorton74's Avatar
another question about the video of the 84...u said u tapped a port for a gauge...what port was it and what gauge was it for?
and speakin of gauges I still have to buy that cable x thing for my speedometer. was gonna go with the later electronic gauge cluster but I want to keep my 100mph speedometer.
Old 05-01-2014, 12:23 AM   #110
AGearHead4Life
The truck will more then likely stay NA. That's why I bumped the compression up so much.
Old 05-01-2014, 12:25 AM   #111
AGearHead4Life
another question about the video of the 84..u said u tapped a port for a gauge...what port was it and what gauge was it for?
That is the piece on the side of the oil pan above the oil filter. I threaded my stock oil sending unit there for the oil pressure gauge to work.
Old 05-01-2014, 12:33 AM   #112
ivorton74
ivorton74's Avatar
ok kool ill check that out tomorrow too.
Old 05-01-2014, 12:43 AM   #113
ivorton74
ivorton74's Avatar
I looked into the cts-v oil pan like u suggested...ill get that and swap it out after I get it running. im thinking we could change the pan with the engine in the truck. I want to drop the front another inch or so...so the truck pan has to go.
Old 05-01-2014, 08:38 AM   #114
AGearHead4Life
I ran the truck pan on my last truck and it worked fine. Just hung WAY below the crossmemeber as you've probably seen with yours now. This time I'll be running the CTSV pan. If you're going that low with the suspension, you may need to consicer the f-body pan. Here is a picture comparing the depth of the LS1 pan vs the CTSV pan. Mearure from you block down to see how low this CTSV pan will hang.
Old 05-01-2014, 06:33 PM   #115
ivorton74
ivorton74's Avatar
a poster suggested an LH8 oil pan a few pages back...whats the difference between that and an f-body pan?
Old 05-01-2014, 06:35 PM   #116
ivorton74
ivorton74's Avatar
didn't get to work on the truck today....couldn't get the time off work...will check out the mounts tomorrow hopefully.
Old 05-01-2014, 06:53 PM   #117
wgeyer88
See this link for all the oil pan dimensions:
http://ls1tech.com/forums/conversion...-oil-pans.html
The LH8 pan is the hummer H3 pan.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 05-01-2014, 10:31 PM   #118
ivorton74
ivorton74's Avatar
damn didnt realize there were so many different pans for these motors.
Old 05-02-2014, 09:02 PM   #119
ivorton74
ivorton74's Avatar
Update...we got the motor to turn over today!! Unfortunately it didnt fire up cuz the tank pretty much empty. Ill get some gas n try it again when i get the chance. I still have to get the radiator and driveshaft and turns out the starter is not aligned to the flywheel properly so when u crank the motor u can hear metal scraping....gotta take care of that for sure. Ill try n post the vids of it.
Btw what do u guys do about the throttle cable and lower rad hose?
Old 05-02-2014, 10:02 PM   #120
ivorton74
ivorton74's Avatar
cab is back on...
Old 05-02-2014, 10:25 PM   #121
ivorton74
ivorton74's Avatar
cant remember how to embed the video on here but there's the link...
https://www.youtube.com/watch?v=XGUmroZK3Dw
Old 05-03-2014, 11:11 PM   #122
ivorton74
ivorton74's Avatar
any ideas for a throttle cable?
Old 05-06-2014, 10:42 AM   #123
wgeyer88
http://ls1tech.com/forums/16783919-post34.html
Check out LS1Nova's thread over on LS1Tech. He has a cheap solution that I used, works perfect.
Will
Old 05-06-2014, 02:46 PM   #124
ivorton74
ivorton74's Avatar
kool thanx man...im gonna be using one of a 99 Silverado though
Old 05-06-2014, 02:47 PM   #125
dman1982
dman1982's Avatar
I out those pics up
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
