Old 12-31-2014, 12:27 PM   #101
texasld
texasld's Avatar
Re: Project "Leon "
Stumbled across a guy at HF this past weekend, started chatting, and sure enough he is working on a 72 GMC C20 with is 15 year old son. Talked him into becoming a member of the board. (FwEwForney). He showed me a picture of his truck and he had a 71/72 grill and core support. If you remember back to my first post, I had a GMC grill and CS. Did a little trading and BAM! Now I have a CS, grill, trim, headlight and all the other goodies. Although I can't use some of it, it's a step in the right direction. Pretty clean. I'm going to take it over to my friend and let him blast and coat it for me. Should turn out nice. I just saw a picture of a CS that had the "humps" on the top cleaned up. I think I'll do the same.
Really crummy picture, but I was giddy and had to set it on the frame for a shot.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 01-05-2015, 09:34 AM   #102
texasld
texasld's Avatar
Re: Project "Leon "
More garage time over the long weekend!
Got the passenger side rocker all put in. Hanging the door all by yourself is a real pain, but I got it. I dont know about everyone else's cabs, but my top edge of the door isnt quite even across the length. I'll be replacing the drip rail, I'll work on it then I suppose.
Name:  Rocker installed.jpg
1999 Jeep TJ
Old 01-08-2015, 12:37 PM   #103
texasld
texasld's Avatar
Re: Project "Leon "
Getting cold here in Texas, (18 degrees this morning) My garage isn't insulated, so its chilly, but I have still been toodling.
I got my Flowmaster U-Fit kit in this week and started playing with that. Tacked my flanged to my header collectors and started trying to lay it all out. Didn't snap any pictures... story of my life.
Also drilled a hole and brazed a 3/16 inch barb into my radiator for my steam port on the LS. I have seen the Jags that run stuff, but not a big fan of those. My Radiator was about the only thing I had on my truck that was new and not in bad shape, so i'm going to reuse it. Need to clean it up and repaint it but that's easy.
Picked up a "splicer" barb from lowes for $2.79, threw it in the vice and cut about half of it off of one half. (I guess that would be 1/4...)
Then pulled out the step bit and drilled a hole in the rad. I used the shop vac on the fill neck to suck any shaving out. I cleaned up the area really well, but guess what, didn't get that picture either.
Then just applied flux and solder and heated with my propane torch and stuck it like chuck. filed down any extra solder and then shot it with some black paint for giggles.
Name:  Barb installed.jpg
Waalaa, a 20 minute and $2.79 since later... I have a steam port. This is the highest point I could get it in the system. I didn't want to drill and tap the thermostat housing because when I have to replace my stat i'll have to do it again.
1999 Jeep TJ
Old 01-08-2015, 02:22 PM   #104
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project "Leon "
Nice work. Awsome and getting the grill and stuff in trade...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-12-2015, 10:07 AM   #105
texasld
texasld's Avatar
Re: Project "Leon "
Originally Posted by aggie91 View Post
Nice work. Awesome and getting the grill and stuff in trade...
Thank you, Sir!
Spent some time refinishing a table this weekend, so that ate up a full day, but I did get the send lines for the fuel system in for the most part. Still need some more -an fitting... those things get pricy quickly. Fabbed a bracket and drilled and tapped some holes for some really slick aluminum line clamps I ordered from scamazon. Really happy with the way they turned out. I'll get more shots of that once i get all the lines finished. but here is a shot thus far.
Name:  Send Fuel Line.jpg
1999 Jeep TJ
Old 01-22-2015, 05:04 PM   #106
texasld
texasld's Avatar
Re: Project "Leon "
I have been on the road all week and I am currently stuck in the Atlanta Airport, so I figured I would do a little update. I'l take a ton more pictures this weekend once I finish up a few things that I started last weekend. This is what I did get finished last weekend, though.
Got the fuel lines from the fuel tank all the way to the intake. Both send and return. Ordered some heat sleeve to cover the lines when they run over the headers. I also had some heat shields made to cover the fuel pump and help cut down on the heat on the hard to soft line connection. I'll install those this weekend.
Name:  Full Lines.jpg
Name:  Line Clamps.jpg
Name:  Hard to Soft.jpg
I used 1" line clamps for the hoses when I bolted it to the back of the head. Had to drill the bolt hole in the clamp out to make the bolt fit, but It's stuck like chuck now.
1999 Jeep TJ
Old 01-22-2015, 05:27 PM   #107
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Project "Leon "
Cool fuel lines!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 01-22-2015, 06:05 PM   #108
KMC3420
KMC3420's Avatar
Re: Project "Leon "
What filter did you use for your feed line, from what I understand, no filter is needed on the return line. I am planning on using an in tank pump as you have done with the blazer tank, nice progress. I am still up in the air on the boyd's tank or the tank you have used. Plenty of money could be saved by going your route.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-22-2015, 07:15 PM   #109
texasld
texasld's Avatar
Re: Project "Leon "
I have nothing against the Boyd tank, I just don't have any experiance with them due to cost. I have heard many good things about them. You are correct, no filter for the return. I think the filter is one from a 2001 suburban from the parts store. The fittings I used 3/8 tube nuts, and they threaded right in. Haven't pressure tested it yet, but I plan on trying it out this weekend. If you are running an LS with a returnless style intake, PM me and I'll be happy to send you my Regulator/Filter and the -an fittings to go with it. I ordered it not thinking that my fuel rail is a return style. I'll give it to you for a great deal to help a fellow board member.
But I have to let you know I'm actually running an external pump. If you look forward of the center cross member, you will see the walbro pump hiding in there. Don't make fun of my rubber hose barb to bubble flared steel lines, I got lazy and cheap! I think I got my tank on sale from brothers. Don't remember the price, but I'm leaning towards $230. Even comes with sending unit. I got the top fill. I'm going with the wood bed so the filler neck will be in the bed slats. Nice and easy.... I hope.
1999 Jeep TJ
Old 01-22-2015, 08:24 PM   #110
KMC3420
KMC3420's Avatar
Re: Project "Leon "
Mine is an 02 return style. So I appreciate the offer on the pump and filter but I can't use it either. I will look into the tank from brothers. Your setup looks good to me.
Keagan
Old 01-22-2015, 08:28 PM   #111
texasld
texasld's Avatar
Re: Project "Leon "
Thanks man. If it works, I'll let you know.
1999 Jeep TJ
Old 01-26-2015, 12:15 PM   #112
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Project "Leon "
I just read through your entire build thread. Nice work. I can't wait to watch the progress. Keep up the good work. Definitely subscribed!
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-26-2015, 02:52 PM   #113
Vic1947
Vic1947's Avatar
Re: Project "Leon "
Everything is looking great, Mike. I know how travel can put a damper on things, but you're making good progress in spite of it. Keep it up!
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 01-26-2015, 05:58 PM   #114
texasld
texasld's Avatar
Re: Project "Leon "
Thank you, Gents!
More of this and that. So many things to do, I guess that's good because I get to bounce around and don't get to board on one thing. Like rust repair. I'm burnt on that for the moment. So, I got my core support back from my PC buddy. $50 turn key deal on that. I went ahead and hung it to get all my hoses straightened out and mount my rad. I'll have to pull it back off to clean it up. Does anyone have any upper rad brackets they would sell me. I need a set. (see the zip ties?)
Name:  Core Support Front.jpg
Also mounted a universal overflow bottle. I want to relocate the battery, but I'm not sure where to put it yet.
Pulled my headers off to weld my flanges on. Only have a MIG welder, so the welds aren't super pretty, ground those down a bit and hit the ends with a high temp paint to make them all pretty. Also took care of the O2 sensors while i had the paint out.
Name:  Header Paint w exhaust.jpg
Here is as far as I have gotten with the Exhaust. I need to order some v-band clamps so I can pull the exhaust out if I need to. I have had to cut one to many tail pipes while doing a transmission swap in my small number of days, I just don't want to hack up mine after spending time on it. It took a bit of time to figure out all the curves for the "jog" over the tranny x-member. I think it coming out nicely. I ordered the Flowmaster u-fit kit, I recommend it. It's basically a box full of bends and straight pieces that you fit together how you want... Duh, U-Fit... once I get the v-band clamps in, I'll cut the longer of the two pipes to the same lengths.
Name:  Exhaust In 2.jpg
Here is the heat shield I had bent-up for my fuel pump. I used aluminum rivets for the top "holders".... BAD IDEA. I should have known. The ole steel against aluminum battle. I drilled and tapped the holes for some bolts to hold the shield in the bottom. I guess I'll do the same for the top and buy some threaded tube to protect the threads. Once I get it all sorted out, I'll pull it back of, blast and coat with high temp red paint.
1999 Jeep TJ
Old 01-26-2015, 06:05 PM   #115
texasld
texasld's Avatar
Re: Project "Leon "
But before my pipes got to where they are now, I (like a fool) welded the H-pipe in before I finished the rest of the build. Learn from my mistakes, weld it on after you finish.
The other problem this caused was a bit of warping of the tubes. Ended up not lining up with the headers and the tail end didn't go straight out the back, but some what wonky so I had to "adjust" them. Using a few blocks of wood and my 3 ton jack, I commenced.
Name:  H-pipe adjustment.jpg
Doing this, of course crushed the ends of my pipes, so, I just hacked them off and welded new ones on.... problem solved. everything lines up nicely and we are back in business.
1999 Jeep TJ
Old 01-27-2015, 09:03 AM   #116
mcbassin
Still Learning
mcbassin's Avatar
Re: Project "Leon "
Nice progress on the truck. Bummer about the H-pipe. I got one of those with my kit, I opted to leave it out. I'm sure it would be better with it, but I really didn't want to fight with it. Nice fix with the jack idea.
mcbassin is offline   Reply With Quote
Old 01-27-2015, 09:19 AM   #117
texasld
texasld's Avatar
Re: Project "Leon "
Thanks, Mike!
I have cut up and rewelded 8 pieces so far. It's just a manley jigsaw puzzle.
1999 Jeep TJ
Old 01-28-2015, 12:04 AM   #118
Bennett68C10
Bennett68C10's Avatar
Re: Project "Leon "
Just read through your build, nice looking project. Love those valve covers on your LS.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-28-2015, 12:15 AM   #119
texasld
texasld's Avatar
Re: Project "Leon "
Thanks, man. Trying to go with a "traditional modern" style. Saw those covers, had to have em.
1999 Jeep TJ
Old 01-28-2015, 12:19 AM   #120
Bennett68C10
Re: Project "Leon "
Yeah I'm had similar thoughts for mine, I have the same ones sitting in a box right now, just they are the cast gray version. I plan on painting them along with the engine the same color as the body.
Keith
66 Suburban
IG: bennett68c10
Old 01-28-2015, 08:33 AM   #121
calvin78612
calvin78612's Avatar
Re: Project "Leon "
I may have some rad supports. It will be tomorrow before I can look. Working a double today.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 01-28-2015, 09:39 AM   #122
texasld
texasld's Avatar
Re: Project "Leon "
Calvin, That would be awesome! LMK!
1999 Jeep TJ
Old 01-29-2015, 11:20 PM   #123
calvin78612
Re: Project "Leon "
Mike, i sand blasted them at work this evening. I'm of fri,sat, & sunday. Let me know.
84 step side
87 swb
Old 02-02-2015, 09:56 AM   #124
texasld
texasld's Avatar
Re: Project "Leon "
Got absolutely nothing done on the truck this weekend.... But I did get my new toolbox. It's definitely an upgrade from my old one. My old box was my great grandfathers at one point in time. I have a serious problem though. I was overflowing and not i have empty drawers. I need more tools!!!!
Excuse the finger prints, I was so happy to ge the thing loaded up with all my new tools I forgot to wipe it down... Oh well, just another reason for me to stay in the garage just a bit longer.
1999 Jeep TJ
Old 02-02-2015, 03:58 PM   #125
KMC3420
KMC3420's Avatar
Re: Project "Leon "
Nice toolbox. It looks like a very nice upgrade.
Keagan
