Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 11-15-2014, 11:58 AM   #101
cheyenne shortstep
cheyenne shortstep's Avatar
Re: Parting '72 Suburban. Loaded.
ajlezama- are you wanting the door latch or hinges?
cheyenne shortstep is offline   Reply With Quote
Old 11-15-2014, 01:32 PM   #102
ajlezama
Sorry the door hindges.top and bottom
ajlezama is offline   Reply With Quote
Old 11-15-2014, 02:45 PM   #103
cheyenne shortstep
I can do $50 shipped for both hinges, I have a pair already pulled in good condition from the last 'Burb I parted.
Old 11-15-2014, 03:30 PM   #104
ceribus12
You said the tilt is for sale locally, but would you be willing to ship? I'm located at 28376 in NC.
ceribus12 is offline   Reply With Quote
Old 11-16-2014, 12:12 AM   #105
cheyenne shortstep
ceribus12- the tilt sold local the first day this 'Burb showed up at my place.
Old 11-26-2014, 05:18 PM   #106
zac
zac's Avatar
Don't know if you want to go through the hassle but if you want to do a little cutting I really need the lower portion of the door pillar between the passenger door and the 3rd door all the way down to the bottom of the rocker. I can send pics to make it more clear and have no real time pressure on my end if you want to do it later in the part out. Anything you have is probably better than mine. Nothing there anymore....
zac is offline   Reply With Quote
Old 11-27-2014, 01:17 AM   #107
cheyenne shortstep
zac- I'm not cutting this one up, it's too clean and rust free. I'll keep it in mind if I cut up the next one.
Old 11-27-2014, 11:16 AM   #108
zac
zac's Avatar
I understand completely. Keep me in mind. Thanks
Old 12-28-2014, 02:26 PM   #109
Rocketman72
Rocketman72's Avatar
Firewall Forward wiring harness? Shipping to 92861?
Don aka Rocket_Man
72 K5 Blazer 454 CI
2002 Honda VTX 1800C
Rocketman72 is offline   Reply With Quote
Old 01-20-2015, 11:32 PM   #110
twistedchevy
Do you have a full lock set, also do you still have the rear as harness that the switch plugs into?
twistedchevy is offline   Reply With Quote
Old 02-11-2015, 11:16 PM   #111
1low68
Third door still available?
1low68 is offline   Reply With Quote
Old 02-12-2015, 12:30 PM   #112
cheyenne shortstep
Yes the third door is still available. $200
Old 02-13-2015, 01:05 AM   #113
twistedchevy
How's the wiring harness
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
Old 02-13-2015, 01:50 AM   #114
Madipie03
What conditions the liftgate glass and weatherstrip in if its still available? Shipiing to 83814 Thanks
Madipie03 is offline   Reply With Quote
Old 02-13-2015, 02:30 AM   #115
cheyenne shortstep
twistedchevy, are you looking for under dash harness? A.C. or non?
Madipie03, I have a nice Soft-Ray glass no gasket, $130 shipped.
Old 02-16-2015, 04:03 PM   #116
wiggins
wiggins's Avatar
front doors still available? You said the upper and lower molding hole had been bondo'd but I see the lower trim on the doors in the pic?
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 02-17-2015, 12:29 AM   #117
oneuglychevy
Hi, interested in the Lower Tailgate.
oneuglychevy is offline   Reply With Quote
Old 02-18-2015, 03:57 PM   #118
HPJUNKY
are you interested in selling this
HPJUNKY is offline   Reply With Quote
Old 02-18-2015, 08:24 PM   #119
engairuph
How about the accelerator linkage that bolts the fire in the plastic?
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 02-18-2015, 10:23 PM   #120
cheyenne shortstep
HPJUNKY, I have a nice, rust free lower piece from the last Burb I cut up, it too was a tailgate truck. $175 + shipping
Old 02-18-2015, 10:24 PM   #121
cheyenne shortstep
engairuph, do you need the complete throttle assy?
Old 02-18-2015, 10:41 PM   #122
ajlezama
Does this suburban have the pieces that hold the headliner,
Old 02-18-2015, 10:57 PM   #123
engairuph
Just the piece that bolts to the engine firewall. Plastic is broken on mine. Also looking for ignition switch bezel
Ralph L. Jasper
13 GMC Ext cab
MAI
Interior shop
Old 02-19-2015, 06:05 PM   #124
adam9496
Originally Posted by cheyeshortstep View Post
Tach dash tested and working [tach], circuit board is burnt and been repaired? With harness that has been modified for HEI. $275 shipped.
This bezel has the holes for rear A.C. and manual throttle, I will swap out for the other bezel shown in the pic. at no extra charge.
Manual throttle with dash plate and deluxe knob, bracket and kickdown switch for TH400, pedal assy and cable. $125 shipped
How did you modify the harness to make the factory tach work with HEI? Im currently having that problem. Thanks
adam9496 is offline   Reply With Quote
Old 02-25-2015, 02:35 AM   #125
bhahn70
bhahn70's Avatar
Was wondering if you have any air conditioning parts left. Mainly need the dash rear a/c switch. Thanks,Brian
bhahn70 is offline   Reply With Quote
