Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-15-2014, 10:36 PM   #101
patdaly
Re: 72 K30 Build
I'm not sure how you would hide the flange without feathering a bunch of bondo over it.
If it makes you more comfortable, it probably won't hurt, but you are going to have to but some places no matter what you do, so why not measure carefully, start patch panel slightly big and trim carefully until you have it?
The only real negative on a seamed joint other than the obvious difficulty in hiding it is you generally have an open side where moisture can get to.
patdaly is offline   Reply With Quote
Old 12-16-2014, 01:16 PM   #102
7dee2
7dee2's Avatar
Re: 72 K30 Build
Originally Posted by swamp rat View Post
I just had an idea but keep in mind i'm not a body man and never used it...
When i was getting ready to do my gas door my uncle also recommended using a flanging tool, but he also recommended using automotive body adhesive like is used in the newer body repair, i don't know anything about it but think its probably a 2 part epoxy?
Maybe there is just too muck area to assemble and squeeze into place tho not sure. Then how to squeeze it all into place? Cleco's perhaps?
http://search.eastwood.com/search?p=...d&w=Cleco&rk=3
Ether way i like the flanging idea and agree i think it will be helpful to keep it ridged.
Years ago we did a 66 Impala SS (pics in the Hub Garage link below) it needed both lower rear quarters. A friend of mine used the glue on method and it turned out great. Never had any trouble with those repairs. Car scored in the mid 90's out of 100 first time out at the local Concours d'Elegance in 2004.
Cleco's are a pretty cool idea and are kinder than screws I would own a bunch if I did this kind of work for a living. We have always used screws, magnets and various welding clamps. HF sells these intergrip panel clamps also and they have worked well. http://www.eastwood.com/intergrip-pa...-set-of-4.html
Originally Posted by DWilbur View Post
I bought the same flange tool from HF as well. it worked good for punching hole to spot weld parts together. my builder trims the part about 1/2" bigger and steps a flange in it makes for a stronger joint and you don't have the warping issues from but welding sheet metal together.
I agree 100%!
I wish this tool would make a deeper flange but I'm surprised at how close to flush it is. A little butt welding but no biggie, I think we can hide most of the repairs.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 12-16-2014, 01:23 PM   #103
7dee2
7dee2's Avatar
Re: 72 K30 Build
Recently we used all butt welds on my ½ ton project and I’m really pleased with the results (we were able to hide all the many cab repairs that project required, lots of time invested but worth it to me) this truck is planned to be the looker of the current three. My K30 project is being built for another purpose more of a working, camping, parts hauling, fun type truck. Built with extra/saved parts to help keep the ½ ton cherry and to replace my sweet C30 flatbed with a heavier duty BB 4x4 version!
Decision is made we are moving forward with the flange type repair for this project. I believe it is going to make a stronger repair. The flanges will be internally hidden inside the inner and outer roof skin for the upper repair. The lower will also be hidden internally between the inner and outer back panel. The nice thing is the only place the flange repair will show is behind the seat/gas tank and this area will have a gas tank, sub box or carpet haven’t gotten that far yet. I know the misses wants a bench seat for sure, dang I already have an extra set of blazer bucket seat frames and a console we bought from board member bluek5 that I was going to use. One more thing the exterior will be hidden by the headache rack from the flatbed so it will mostly hide any body work. To help deal with rust issues we will use a weld thru primer between the flanges and a coating of rust converter/encapsulator in the internal cavity between skins.
Many years ago I drove a rollback truck hauling forklifts around the area in an old C60 that had had the back of the cab bashed in. It had been poorly repaired and used to leak, vibrate and rattle as I went about my job driving me nuts. That is not going to happen to this truck and I’ll make it look right because I’m a bit of a fuss bucket when it comes to my projects.
Brett
Old 12-17-2014, 06:10 PM   #104
7dee2
7dee2's Avatar
Re: 72 K30 Build
So rolled the inner roof back into place somewhat and really lucked out that it is far enough below the inner seam that there is something to work with.
Brett
Old 12-18-2014, 12:45 PM   #105
7dee2
7dee2's Avatar
Re: 72 K30 Build
Separated the roof skin patch panels they are going to need some work, exterior panel is the worst of the two. They have far more surface rust starting than the cab they are going into. It's interesting how it didn't rust as much behind the dome light.
Brett
Old 12-22-2014, 02:10 PM   #106
7dee2
7dee2's Avatar
Re: 72 K30 Build
Started trimming and squaring up damaged areas.
Brett
Old 12-22-2014, 02:20 PM   #107
7dee2
7dee2's Avatar
Re: 72 K30 Build
And some more squaring and trimming. OK my work is done I have a much larger hole in the back!
Brett
Old 12-22-2014, 09:57 PM   #108
mjensen
mjensen's Avatar
Re: 72 K30 Build
Looking good Brett!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-24-2014, 05:11 PM   #109
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Mike.
The RV guys had moved the dome light to the left b pillar so it will get the same flange treatment. Trim, strip, flange and then fit patch panels.
Brett
Old 12-24-2014, 06:15 PM   #110
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 K30 Build
Looking good sir! I hope you and your family have a very Merry Christmas too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-25-2014, 05:47 PM   #111
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks Big D! Merry Christmas and Happy New Year to you sir!
Brett
Old 12-27-2014, 04:37 PM   #112
7dee2
7dee2's Avatar
Re: 72 K30 Build
Killed the 1st HF flanging tool big surprise, made it roughly 102” with about 60” or so to go and it won’t bend metal anymore. Ha, no biggie I’ll grab another one and hopefully it will last to finish the job. Maybe this time we’ll even make sure to keep the air pressure less than 90 psi as recommended, oops!
You may notice from the pics that we decided to stagger all the patch panel seams. Thinking this will also make for a stronger repair.
Brett
Old 12-28-2014, 01:19 PM   #113
mjensen
mjensen's Avatar
Re: 72 K30 Build
Looking good!
Mike
Old 12-28-2014, 03:11 PM   #114
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Curious if the flange is deep enough for the metal to sit flush? maybe have to go back over it again with the new flanger tool? Nice progress!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-29-2014, 11:47 PM   #115
7dee2
7dee2's Avatar
Re: 72 K30 Build
Originally Posted by mjensen View Post
Looking good!
Thanks Mike.
No it does not sit flush I wish it did but, it's pretty close. Thanks Rat.
Brett
Old 12-29-2014, 11:58 PM   #116
7dee2
7dee2's Avatar
Re: 72 K30 Build
HF flanging tool #2, roof areas are now flanged. Went back over some of the other areas to make sure the flange was as deep as the tool would go.
Brett
Old 12-30-2014, 03:24 AM   #117
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
Watching and learning!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-30-2014, 12:28 PM   #118
DWilbur
Re: 72 K30 Build
My builder screws the parts together by drilling a hole and installing screws by hand so he does not warp the metal. I asked him why by hand. he said that screw guns you don't have control how tight the screw grabs and it will warp the metal. I noticed that you are step notching the cab you are working on and the corners are not stepped do to the tool not able to reach the corners. you might try stepping the part so you can step notch all the way around. looking good
DWilbur is offline   Reply With Quote
Old 12-30-2014, 02:44 PM   #119
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks guys, we're learning also and appreciate the feedback. You can get a flange in the corner if you make the corner round instead of square.
Brett
Old 12-30-2014, 04:06 PM   #120
DWilbur
Re: 72 K30 Build
That's good that you can flange the corner and grind down the part your installing.
Old 12-30-2014, 05:18 PM   #121
7dee2
7dee2's Avatar
Re: 72 K30 Build
Or you can do it like we are and that is just cut the corner out of the patch at a 45, easy peasy! Either way it's gonna work and that's making me happy!
Brett
Old 12-30-2014, 05:28 PM   #122
7dee2
7dee2's Avatar
Re: 72 K30 Build
Fitting the separate roof patches. Both will need more work before they are ready for final install.
Brett
Old 12-31-2014, 03:10 PM   #123
DWilbur
Re: 72 K30 Build
The patch panels are looking good. lots of welding to do.
Old 01-03-2015, 04:56 PM   #124
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks, I know and I keep finding/making more stuff to weld! Ha!
Brett
Old 01-03-2015, 05:08 PM   #125
7dee2
7dee2's Avatar
Re: 72 K30 Build
Fitting the large back patch panel and decided not to separate the inner and outer panel as above. Originally thought it might be easier to install but found it wasn’t really necessary. Also this patch is in better shape than the upper.
Brett
72chevy, dually, flatbed, k30, motorhome
