Old 06-26-2023, 10:47 PM   #101
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Here goes the cab...
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 06-26-2023, 10:53 PM   #102
derotoreut
derotoreut's Avatar
After about one month, Jesse was able to fit it in and get going on the blasting.
Cab turned out pretty good. I was pleased.
Doors and hood turned out good too!!!
~ Dan
Old 06-26-2023, 10:56 PM   #103
derotoreut
derotoreut's Avatar
Both original fenders turned out nice. No rot or holes. Nice to have a truck that came from Arizona.
~ Dan
Old 06-26-2023, 11:00 PM   #104
derotoreut
derotoreut's Avatar
Get the parts coated before work begins on the body and panels.
~ Dan
Old 06-26-2023, 11:03 PM   #105
derotoreut
derotoreut's Avatar
Some rot was found, but not too bad.
~ Dan
Old 06-26-2023, 11:05 PM   #106
derotoreut
derotoreut's Avatar
Time to get the bad passenger side rocker fixed.
~ Dan
Old 06-26-2023, 11:08 PM   #107
derotoreut
derotoreut's Avatar
Bought some Slosh Tubz sheet metal for the firewall. Ended up not using the side filler panels.
~ Dan
Old 06-26-2023, 11:11 PM   #108
derotoreut
derotoreut's Avatar
Work gets underway smoothing out the firewall...
~ Dan
Old 06-27-2023, 07:49 AM   #109
zicc1835
zicc1835's Avatar
:Nice work …. Great progress …. ….now we can’t wait 4 years for what’s next
zicc1835 is offline   Reply With Quote
Old 06-27-2023, 03:37 PM   #110
nicklear36
nicklear36's Avatar
Subscribed!
nicklear36 is offline   Reply With Quote
Old 07-01-2023, 09:16 PM   #111
derotoreut
derotoreut's Avatar
Nope... I'm on it.
~ Dan
Old 07-01-2023, 09:20 PM   #112
derotoreut
derotoreut's Avatar
I wanted to try to use One Piece Products rear window, but it wouldn't fit right. When compared to my stock glass I could see that it was off slightly on the driver side. In order to use it I would have to tweak the window opening slightly. I'm debating.
~ Dan
Old 07-01-2023, 09:26 PM   #113
derotoreut
derotoreut's Avatar
Got the body work going on the firewall.
Closed off and welded the channel, all the way around.
~ Dan
Old 07-01-2023, 09:32 PM   #114
derotoreut
derotoreut's Avatar
Time to start shaving the drip rail. The plan is weld in a 1/4" dia piece of rod around the door.
~ Dan
Old 07-01-2023, 09:39 PM   #115
derotoreut
derotoreut's Avatar
More body work on the passenger side rocker.
~ Dan
Old 07-01-2023, 09:42 PM   #116
derotoreut
derotoreut's Avatar
Body work on the fuel filler hole.
Before....
After...
~ Dan
Old 07-01-2023, 09:48 PM   #117
derotoreut
derotoreut's Avatar
The only major rust on the truck was the rear window channel. Really lucked out with this original sheet metal. This will need some repair.
~ Dan
Old 07-01-2023, 09:53 PM   #118
derotoreut
derotoreut's Avatar
Needed to make a patch panel for the rear window channel. This was how it was done.
Finished piece. Just needed to cut out the old section and weld this in.
Here we go...
~ Dan
Old 07-02-2023, 05:40 PM   #119
derotoreut
derotoreut's Avatar
Shaved the dash by removing the radio speaker hole and defroster vents.
Also more work on the shaved drip rails.
~ Dan
Old 07-02-2023, 05:43 PM   #120
derotoreut
derotoreut's Avatar
Some inside work to remove the radio and center vent. Making room for a double-din head unit.
~ Dan
Old 07-02-2023, 05:47 PM   #121
derotoreut
derotoreut's Avatar
Work on getting the cab into primer.
~ Dan
Old 07-02-2023, 05:48 PM   #122
derotoreut
derotoreut's Avatar
More work on the cab.
~ Dan
Old 07-02-2023, 05:55 PM   #123
derotoreut
derotoreut's Avatar
Put front end back together.
~ Dan
Old 07-28-2023, 10:09 PM   #124
derotoreut
derotoreut's Avatar
Drilled some holes in the firewall for my master cylinder and steering column. If you notice there's only two holes for the master and they're not studs. I drilled the stock pedal mount and installed rivet nuts in two holes for the master. This way I can use button head screws for a cleaner mount. The other holes have studs on the back of the firewall for mounting into the bracket.
~ Dan
Old 07-28-2023, 10:18 PM   #125
derotoreut
derotoreut's Avatar
I decided to install some Trique Altman Easy Latches for my doors. I'm also going to try the Honda door seals. Hopefully, I have some nice closing doors.
~ Dan
