Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-06-2015, 01:40 PM   #101
DLTruck1973
Re: Parting 1986 Suburban K20 4x4
Originally Posted by beamn7 View Post
Thanks Thomas! Should be metal just like the one in the 'burb and twist into the flange mount valve covers.
I have one off another engine, clean and ready for paint. I may have an oil cap for it if needed.
How does $22.50 shipped sound? Let me know,
Thank you for the interest,
Thomas
DLTruck1973 is offline   Reply With Quote
Old 02-07-2015, 11:37 PM   #102
B_derK20
Was the W shaped cross member and t-case shield spoken for? If not I'd like to be in line.
B_derK20 is offline   Reply With Quote
Old 02-08-2015, 12:05 AM   #103
DLTruck1973
"W" cross member is still available but the skid shield sold. I may have another skid shield but will have to confirm on Monday. If you can give me your zip code, I can quote you for shipping also.
Thank you,
Thomas
Old 02-08-2015, 12:35 AM   #104
B_derK20
My ZIP is 81504. If you could check on the skid plate that would be great. That's the most important part to me.
Old 02-09-2015, 05:14 PM   #105
b&a72
Active Member
b&a72's Avatar
Do you still have the cab wiring harness?
b&a72 is offline   Reply With Quote
Old 02-09-2015, 05:35 PM   #106
DLTruck1973
I am fresh out of skid shields at this time. We sold the last one I had last week.
Let me know if you are interested in the crossmember.
Thank you,
Thomas
Old 02-09-2015, 05:36 PM   #107
DLTruck1973
Not from this Suburban but I have the under dash harness for an 86 pick up for $75.00 plus shipping.
Let me know if it will work for you,
Thank you,
Thomas
Old 02-09-2015, 05:37 PM   #108
b&a72
Active Member
b&a72's Avatar
Thank you,
Thomas
I am assuming it had ac, and this would include the entire cab under dash harness. Is there any splices, or is it butchered in any way?
Old 02-09-2015, 06:59 PM   #109
DLTruck1973
The AC harness is separate and has vacuum hoses that go through the firewall. It is an additional $30.00 on top of the main under dash harness. I need to know exactly what you need. The power door / power lock has a separate harness, the cruise control has a separate harness.
You have the main under dash harness for $75.00 plus what ever add on you need. We have all of those harnesses and they will be in good condition with nothing hacked.
Let me know what you need and I can get you exact pricing.
Old 02-09-2015, 07:19 PM   #110
junkrat
junkrat's Avatar
Got my crossmember to day it's in great shape an was packaged like it was a priceless work of art , thanks again great seller!!
junkrat is offline   Reply With Quote
Old 02-09-2015, 08:53 PM   #111
DLTruck1973
Thank you for the kind words.
We appreciate the business.
Thomas
Old 02-10-2015, 11:02 PM   #112
beamn7
Thomas
Deal!
PM sent.
beamn7 is offline   Reply With Quote
Old 02-17-2015, 06:16 PM   #113
beamn7
Deal!
PM sent.
Got the parts. Thanks again Thomas!
Old 02-19-2015, 09:14 AM   #114
Littletony
Littletony's Avatar
What is the ratio of the axles and would you ship to 28555? Also what shape is the tilt column in?
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 02-19-2015, 01:34 PM   #115
DLTruck1973
The ratios on this one are 3:73 but I do have other ratios. Are you looking for completes, drum to drum, hub to hub on the front? They are not cheap to ship. Last time I checked freight to the east side of the country, it was $350.00 for a complete rear.
Steering column is available if you do not need it with pulse wipers for $225.00 plus shipping.
Let me know and thank you for the interest,
Thomas
Old 02-19-2015, 03:29 PM   #116
Littletony
Littletony's Avatar
Yes sir I would need them as complete as possible. I'm replacing the ones under my 1/2 truck. What are you asking for a set with 373 or 410 gear ratio?
Old 02-20-2015, 04:20 PM   #117
DLTruck1973
Complete hub to hub front removed from an 1987 K20 would run $450.00
On the rear, are you looking for a full floater or semi floater? $350.00 on the full floater and $300.00 on the semi floater.
These have 3:73 gear sets. Let me know. Like I mentioned, I shipped on to NY and shipping was just over $350.00 and I would be willing to bet it would be about double that for both.
Thank you again for the interest,
Thomas.
Old 02-20-2015, 04:39 PM   #118
Littletony
Littletony's Avatar
As much as i would love to have these, I'm going to pass. With shipping these are going to be in the 1 ton range for my area. I am very sorry to have wasted any of your time Sir.
Old 02-20-2015, 05:04 PM   #119
DLTruck1973
No time wasted here. More than happy to answer questions.
Yes, shipping is very pricey and I understand completely.
Thanks again,
Thomas
Old 05-25-2015, 06:32 AM   #120
gmcdeadhead
gmcdeadhead's Avatar
would you happen to have the dust shield cover off the 700r4 trans ? thanks
gmcdeadhead is offline   Reply With Quote
Old 05-25-2015, 09:18 PM   #121
junkrat
junkrat's Avatar
Do you have the sway bar brackets that attach to the frame? With bolts?
Old 05-26-2015, 03:36 AM   #122
gmcdeadhead
also would you have a 17" clutch fan?
Old 05-26-2015, 11:31 AM   #123
DLTruck1973
Do you need the sheet metal 2wd version or the cast aluminum 4x4 version?
Let me know and I will see what I can help you with.
Thank you,
Thomas
Old 05-26-2015, 11:46 AM   #124
DLTruck1973
Are you talking about the brackets that bolt to the front cross member that have the bushing inside,
I do have them. $10.00 for the pair with the bolts plus $7.00 to ship.
Let me know,
Thank you,
Thomas
Old 05-26-2015, 11:59 AM   #125
gmcdeadhead
I need the sheet metal 2wd one
