Old 02-13-2015, 10:41 AM   #101
reaper71
reaper71's Avatar
Re: Blake's 67 GMC stepside build
Time to make it look pretty...
Pic #1. The first order of business was to fill the opening for the stock blower motor.
Pic #2. The two plates made to fill the next areas.
Pic #3. All welded in..
Pic #4. More factory holes to be filled..
reaper71 is offline   Reply With Quote
Old 02-13-2015, 02:43 PM   #102
Advanced Design
Advanced Design's Avatar
That will make a nice difference on the firewall. The magnets look really handy. Do you remember where you got them Mark?
Thanks!
Doug
Advanced Design is offline   Reply With Quote
Old 02-14-2015, 01:17 AM   #103
reaper71
reaper71's Avatar
Ace hardware..a couple bucs...
Thanks!
Doug
Old 02-18-2015, 11:00 AM   #104
reaper71
reaper71's Avatar
Update....
Pic #1. Holes,Holes and more holes to be filled!!!
Pic #2. After getting some welded and metal finished..
Pic #3. After doing all the work filling in the holes I didn't care for how it was coming out....So I made a flat plate to cover the entire section. I know more work but it will look much better in the end...
Pic #4. Here I bolted it to the firewall and using Clecko's to hold it in place for tacking and final weld..
Old 02-18-2015, 01:19 PM   #105
Advanced Design
The flat plate looks good!
Old 02-18-2015, 10:05 PM   #106
yj4000
yj4000's Avatar
Yea nice job. It may be more work but It does look better.
Ryan.
yj4000 is offline   Reply With Quote
Old 02-19-2015, 07:34 AM   #107
RockinKees
RockinKees's Avatar
You're making it too good
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-19-2015, 09:56 AM   #108
David121582
Looks good but where is your throttle linkage/cable and sterring column going to go?
David121582 is offline   Reply With Quote
Old 02-19-2015, 11:01 AM   #109
reaper71
reaper71's Avatar
Thank's Guy's for the compliments..
David....The column will be in the stock location I will drill out the hole later using hole saw..
Mark..
Old 02-19-2015, 11:14 AM   #110
reaper71
reaper71's Avatar
Pic #1. All welded in..
Pic #2. The template for passenger side..
Pic #3. Welded..
Pic #4. The template for the old blower motor location...(will be running a Southern Air unit under Dash)
Old 02-20-2015, 10:53 AM   #111
reaper71
reaper71's Avatar
Update...
Pic #1. The template being laid out on steel panel..
Pic #2. All welded in place..
Pic #3. Here I started to weld in the O.E. spot weld to fill them up so you don't use as much filler to smooth them out..
Pic #4. More welding..
Pic #5. All ground down...
Next up, The ugly junk collector aka wire trough...
Mark...
Old 02-20-2015, 12:57 PM   #112
Advanced Design
Wow, nice improvement!
Old 02-23-2015, 10:59 AM   #113
reaper71
reaper71's Avatar
Thank's Doug....
I always felt the firewalls in these trucks were pretty damn ugly and have a ton of potential!!!
Mark...
Old 02-23-2015, 11:12 AM   #114
reaper71
reaper71's Avatar
Pic #1. This is the start of making that junk collector go away...1st I used Eastwood encapsulator inside the trough.
Pic #2. The start of getting the strips tacked in place (using 16g because i had it )
Pic #3. Here I'm showing the angle I set it at to prevent water (if any) to roll off the ledge. It is set at 10 degrees.
Pic #4. Another look, with the transition tacked in place.
(As i worked my way to through bend the degree started to drop to 0 )
Pic #5. One more shot...
Old 02-23-2015, 11:13 AM   #115
Justin@EntropyRad
Justin@EntropyRad's Avatar
Going to be smooth
Justin@EntropyRad is offline   Reply With Quote
Old 02-24-2015, 10:01 AM   #116
reaper71
reaper71's Avatar
Thank's Justin....
Old 02-24-2015, 10:19 AM   #117
reaper71
reaper71's Avatar
Pic #1. The small pieces going in to smooth out the transition.
Pic #2. Round 1 of many...
Pic #3. Another shot of the welding process.
Pic #4. The front portion all welded.
Till next time...
Mark...
Old 02-24-2015, 10:40 AM   #118
68shortwide
68shortwide's Avatar
Lookin good, havnt checked the thread in awhile, impressive the work you've gotten done.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 02-24-2015, 11:17 AM   #119
rusty76
rusty76's Avatar
I'm not sure how I missed this build but dag gone it I'm in for the ride. Killer work dude.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-24-2015, 11:32 AM   #120
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
I love watching professionals at work, nice fab work
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 02-24-2015, 06:01 PM   #121
RockinKees
RockinKees's Avatar
That's a pretty firewall in the making Mark!
Cheers!! Kees.
Kool Guyz CC
Old 02-24-2015, 08:22 PM   #122
yj4000
yj4000's Avatar
Nice progress. Very time consuming. But will definitely clean up the look of the firewall. Look'n forward to more.
Ryan.
Old 02-25-2015, 10:44 AM   #123
reaper71
reaper71's Avatar
68shotwide,Rusty76,Mr chevorlet,rockinkees,and yj4000 Thanks a bunch guys for checking out the build and the kind words!!!
Old 02-25-2015, 10:57 AM   #124
reaper71
reaper71's Avatar
Pic #1. The front edge all ground and smoothed out.
Pic #2. Here I'm showing the process I used...After 1st round of welding I would grind down the main portion of the weld then start the next round of welds to help prevent holes in between your welds..
Pic #3. This was after all welding was done and the grinding as well.
Pic #4. 2nd view up close..
Pic #5. After all metal finish was done for a better overall look..
Till next time..
Mark...
Old 02-25-2015, 08:17 PM   #125
Advanced Design
Nice process on the back weld Mark. Looks good!
