Old 03-16-2020, 08:28 AM   #101
G8rN@te61
Re: 62 Front SwayBar Installation
Understood. I thought you also lowered yours via the torsion bolts and wanted to know what you achieved. I only want to lower my truck 3'-4" max without spending $1k on front end.
G8rN@te61 is offline   Reply With Quote
Old 03-16-2020, 10:57 AM   #102
Joe Pass
Joe Pass's Avatar
My 62 has 2.5" drop spindles and I used the torsion adjustment to gain more,,,,Then had it aligned at the ride height I settled on,,,About 6" total front a stock height. Any lower the A frames scrape on roads with dips or the T keys/bolts will drag over a speed bumps....It's a balancing act on getting the sweet spot. Tire size will play a role in ride Height..My fronts are 225/65/15 and the rear are 255/70/15,,,,Hope this helps
Joe
Joe Pass is offline   Reply With Quote
Old 03-16-2020, 11:46 AM   #103
G8rN@te61
It does and thanks for the quick response sir!
Old 03-23-2020, 10:52 AM   #104
G8rN@te61
Joe,
When I go to remove that part from the torsion key and insert the bushing, do I need to do anything specific with the torsion end like clamp it or anything? I plan on raising the truck and putting on jack stands. any other pointers would be great sir.
-Nate
Old 03-23-2020, 07:07 PM   #105
Joe Pass
Joe Pass's Avatar
With the front suspension jacked up and hanging with no weight on it, I was able to remove the torsion adjustment bolt one side at a time....I counted the turns out so I would have a starting point when I resembled the parts....On mine the bolts were long enough and not under any pressure/load at last few turns out...then with suspension now hanging I reassembled everything eliminating that block under the head of the bolt. The block that is used has a larger ID than the one removed and the bushing reduces the hole in it so the block stays centered on the bolt....This just raises the the bolt heads up the thickness of that removed block, giving more clearance between the bolt head and the ground....You will have to turn the bolt in more to make up the block's thickness.....The bolts have a large amount of thread to do this....This is a guess on how much more turns in the bolt will need to go in to get your original ride height....you will have to play with the adjustment to get the ride height where you want it.....Remember this modification is just a way of raising the bolts so they aren't as vulnerable to scraping on speed bumps or crowned roads.....Also the bolts have been in there many years so I would soak then down with penetrant ahead of time to ease the removal and use an anti-seize paste when you reassemble the threaded portion of the bolt.....I think that's about it but please be safe working under your truck and support it well with good jack stands.... be safe...
Joe
Old 03-23-2020, 07:26 PM   #106
Joe Pass
Joe Pass's Avatar
Current ride height.....
Old 03-23-2020, 07:43 PM   #107
G8rN@te61
Thanks!!!
Old 03-23-2020, 10:00 PM   #108
Joe Pass
Joe Pass's Avatar
Your Welcome
