Old 12-13-2017, 06:26 PM   #101
joedoh
joedoh's Avatar
Re: slammed 57
cool inners!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-08-2018, 02:04 PM   #102
slammed57
slammed57's Avatar
Re: slammed 57
cleaned up the front grill a bit. just about ready to be sent over to the chrome shop.
will be working on the reverse flip hood next week. Thanks for tuning in.
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 05-11-2018, 04:37 PM   #103
my56chevytruck
my56chevytruck's Avatar
Re: slammed 57
Originally Posted by slammed57 View Post
Thank you jim, my appreciated
You're doing amazing body work Mike, gaps look great
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-13-2018, 02:30 PM   #104
slammed57
slammed57's Avatar
Re: slammed 57
Finally found a good hood , so after I got it on, here is the issue I had and after talking with other forum members heres what i came up to fix it, so I will share in case any others run into this situation thanks to mp&C ,big glass and others for I used a combination of everyones ideas
after putting it on the truck I noticed the outer round edge meets the cowl on the cab would not match up. after talkng with other we all agreed that the hood brace/hood settled int the middle... you can see here
heres what i fabricated to help me reshape the hood brace a bit. it bolts to where the factory hinge would be
after ,I placed a floor jack with a piece of 2x4 to prevent metal to metal contact and marring the hood brace , starting in the center and every 6" or so move out towards the passenger side . return to the center and then move out
toward the driver side
I measured before and after to prevent of over stretching and it also prevents of taking the hood on and of several times down to maybe 2-3 times. For my application it needed to be moved up about a 1/4" or so. at the ends where the hood ends meet the fenders , you can put them outwards by hand to match the cab cowl gaps
and the end result
My 57 current build
Old 06-14-2018, 03:58 AM   #105
Nut Case
Nut Case's Avatar
Re: slammed 57
Wow great work. I'm putting this in my build book just in case.
What's the plan for stopping this from happening over time?
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-16-2018, 11:10 AM   #106
slammed57
slammed57's Avatar
Re: slammed 57
not sure what caused it.... so it would be hard to figure out how to keep it from happening again.. not really sure.... the hood was in perfect shape... do dings or dents
My 57 current build
Old 06-18-2018, 11:01 AM   #107
BigDaddyV
BigDaddyV's Avatar
Re: slammed 57
Count me in! Love the truck and amount of detail you are adding!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 06-23-2018, 08:22 PM   #108
slammed57
slammed57's Avatar
Re: slammed 57
working on the hood gaps
as you can see the aftermarket front fenders gaps are not even close to the originals... even though the originals are not the greatest either....so lets see what we can do bout getting them up to todays standards
about 1/2" gap here
and here you can see how they raise more than they should
and now the gap is where it should be. as you can see I split the fender , pushed the gap where they should be, I also had to split the side flange where the hood sits down in the fender to bring down the hieght... finish tacking it up, a bit more grinding down the welds , some hammer and dolly... and one less thing to cross off the to do list
My 57 current build
Old 06-23-2018, 11:18 PM   #109
oldman3
oldman3's Avatar
Re: slammed 57
Nice work...Jim
oldman3 is offline   Reply With Quote
Old 06-24-2018, 03:20 AM   #110
Nut Case
Nut Case's Avatar
Re: slammed 57
Dude
Strong work!
nc
Old 07-07-2018, 06:31 PM   #111
slammed57
slammed57's Avatar
Re: slammed 57
reverse hood done and working smooth
My 57 current build
Old 07-08-2018, 07:32 AM   #112
Kim57
Kim57's Avatar
Re: slammed 57
Very cool.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-08-2018, 11:02 PM   #113
joedoh
joedoh's Avatar
Re: slammed 57
clever fix on the hood being out of shape!
I love reverse tilt hoods too, I had one once. many people dont know how much work it is to get it to drop in front of the grille like yours does, but I do! great job!
Old 07-09-2018, 09:21 AM   #114
lower50's
lower50's's Avatar
Re: slammed 57
Cool
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-05-2018, 04:58 PM   #115
Scottish58chev
Re: slammed 57
Awesome work, love the inner fenders and the fix for the hood and props for making the chassis. really nice work.
Scottish58chev is offline   Reply With Quote
Old 08-05-2018, 08:39 PM   #116
l78vetteman
l78vetteman's Avatar
Re: slammed 57
Slammed,
I have been following your build. You do awesome fabrication work and the truck is looking good. I am working on a 56 and have a few questions. That size wheels and tires are you running. What the the ground clearance at the lower lip of the front fender behind the tire. I am at about 4" and wondering if that is going to be too low for a truck without airbags.
l78vetteman is offline   Reply With Quote
Old 08-06-2018, 09:03 AM   #117
slammed57
slammed57's Avatar
Re: slammed 57
thanks, bud I appreciate it
My 57 current build
Old 08-06-2018, 09:28 AM   #118
slammed57
slammed57's Avatar
Re: slammed 57
Originally Posted by l78vetteman View Post
Slammed,
thanks so much for the kind words, Iam rite at 3 1/2" at ride height . 4" should be good for I had my last 57 chevy truck with a static drop like yours right around 4" ( maybe a tad bit lower) and never had a problem. you just have to be on the watch for extra large speed bumps or steep entrances goin into a gas station or something like that. the issues i did have was trying to get it up on a single car trailer( have to have a lower than normal trailer or extra long ramps) or when needed to get a jack to lift it so i can work on it... i would have to get a 2 small blocks of a 2x4 to drive the front wheels on to get a jack up underneath. heres a pic of my last truck , the drive way dips a little where the front wheels are at ,so it may seem a little lower than what the truck was
My 57 current build
Old 08-07-2018, 07:45 PM   #119
ptc
ptc's Avatar
Re: slammed 57
Mike - WOW! really coming along nicely there! you are really kickin it now. Keep up the good work.
Been puttin some miles on my rig. Just playin around with it mostly.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 08-07-2018, 09:38 PM   #120
slammed57
slammed57's Avatar
Re: slammed 57
HEY ptc, how you been? sorry I had to go back and edit that post... that blue truck was my old one that I was shown with a static drop not air ride.... LOL I wish i was that far along... Hows your truck been doin? any bugs you had to work out? or had it been all good?
My 57 current build
Old 08-09-2018, 10:01 PM   #121
l78vetteman
Re: slammed 57
Very nice. Thanks for the info.
What size are those rear wheels and tires?
Old 08-10-2018, 12:54 PM   #122
slammed57
slammed57's Avatar
Re: slammed 57
same exact set up I have now, 20x15 wheels with mickey thomsons .. Off the top of my head the tires are 29x17x20
My 57 current build
Old 08-10-2018, 01:56 PM   #123
ptc
ptc's Avatar
Re: slammed 57
Trucks doing good, engine is great, just little things -changed out alternator already, got the heating problem that wasnt really a problem fixed, have some other gauge issues, fixed the fuel tank sender, cant get the electric speedo to work with my TH400, so still messing with it. but the truck RIPS!!! really fun.
The body work may not get done for another year or so, so Im just gonna play.
Old 08-11-2018, 09:35 AM   #124
62 Barnfind
62 Barnfind's Avatar
Re: slammed 57
What did you use to have that floating grill? I like it!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 08-11-2018, 09:40 AM   #125
slammed57
slammed57's Avatar
I’ll be working on the truck today and will take some pictures and post for you later this evening
