Old 04-02-2016, 02:04 AM   #101
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Project Orange Crush (57 3100)
Cam bearing installation went better then expected
I will insure correct tolerances on the crank after my file fit rings are done for now lets just get it off the floor
I can't get over the level of precision on the weight balancing of these things just bare with me I'm a little excited
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 04-02-2016, 02:06 AM   #102
Valarius_Starchaser
And now I pass out gentleman up at 6 down at 1 nothing like a hard days work
"Orange Crush"
Old 04-02-2016, 07:13 AM   #103
Advanced Design
Advanced Design's Avatar
That was a fun evening. Coming together nicely! Oh, the hunk of junk you moved out looked pretty nice too.
Advanced Design is offline   Reply With Quote
Old 04-02-2016, 10:37 AM   #104
Valarius_Starchaser
Thanks AD that's my stepfathers and its caused more then its fair share of blood sweet and tears in the last year so I'm still "mad at it"
But on to the task at hand I'm full of eggs bacon and coffee lets get this show on the road!
"Orange Crush"
Old 04-02-2016, 11:52 AM   #105
Kim57
Kim57's Avatar
Looks like fun.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-03-2016, 12:55 PM   #106
Valarius_Starchaser
The insanity continues!
making good progress only had to move around a few bearings due to clearance issues so all in all these SCAT rods are a high quality piece with precision machining
I spent about 3 hours file fitting piston rings which was oddly therapeutic and maddening at the same time
Look at all that material!
Be sure to take notes as we go along
"Orange Crush"
Old 04-03-2016, 12:57 PM   #107
Valarius_Starchaser
Several hours later I have the view that I have been dreaming of for oh so long
"Orange Crush"
Old 04-03-2016, 07:44 PM   #108
Advanced Design
Eye candy...lotta ring filing!
Old 04-03-2016, 10:22 PM   #109
Kim57
Kim57's Avatar
Real nice.
Kim
My build thread
Old 04-04-2016, 01:13 PM   #110
ptc
ptc's Avatar
Motor Build 101! -- you got it down....
what heads you going with? any trade secrets you gonna show us on them????
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 04-04-2016, 01:41 PM   #111
Valarius_Starchaser
I am running 119cc cast 781 heads that I extensively ported and polished/ gasket matched on the intake side and ported on the exhaust side I chose these heads for one reason affordability and the only gain I get with aluminum a is weight reduction and more chamber selection on a "nice head" they are in the future but for now it's a "budget build"
Today my new valve guide cutting bit came in so can run positive seals and double springs with 115 seat pressure and 325 open (if I remember correct) gotta give that .540 lift cam something to fight against now don't we?
Other then that no real "trade secrets" this is my first "high performance" build
"Orange Crush"
Old 04-04-2016, 06:02 PM   #112
lower50's
lower50's's Avatar
MMM them are some sexy looking pistons.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-05-2016, 02:39 PM   #113
Valarius_Starchaser
Progress progress progress blah blah blah
I spent last night cutting the valve guide down for positive seals and double springs took about 45 minutes to cut all 16 guides and an hour to clean one head out. But then I found a problem with my head gaskets.... info to follow
My weapon of choice
Before
After
Voila its magic!
"Orange Crush"
Old 04-05-2016, 02:41 PM   #114
Valarius_Starchaser
Always use lubricant
One head done
Dual springs
For those that have good attention to detail you will see that I took the second spring out of the center to not wipe the cam on initial break in its cheap insurance
"Orange Crush"
Old 04-05-2016, 02:57 PM   #115
Valarius_Starchaser
Then things got interesting the instruction on these 1407 felpro gasket said to add coolant holes if they aren't present so here goes nothing I said
This all took me until about 11:30 to get done so then I said "I can but one head on I'm not that tired
"Orange Crush"
Old 04-05-2016, 03:15 PM   #116
lower50's
lower50's's Avatar
It may have taken a long time to do, but you must be so happy with the outcome!!!
1951 MG TD
Old 04-05-2016, 03:36 PM   #117
Valarius_Starchaser
Boom
And when all this was done I looked at the clock and it said 1:00
So that's how she sits today waiting for 5 o'clock
"Orange Crush"
Old 04-07-2016, 01:00 PM   #118
Valarius_Starchaser
The following night I got the other head and intake on torqued and DONE so happy to check that off the list
Now I need to find a power steering bracket I have three pumps laying around but no side mount brackets
other than that shes off my mind for now on to the next battle
"Orange Crush"
Old 04-07-2016, 01:03 PM   #119
Valarius_Starchaser
Also figured I would share a bit of horsepower numbers the build was based on a Super Chevy budget 454 build so this will give me an indication of power numbers
Here's the article in full http://www.superchevy.com/how-to/eng...-engine-build/
So we will see where I fall one day but I can't be that far off right?
"Orange Crush"
Old 04-07-2016, 03:35 PM   #120
lower50's
lower50's's Avatar
Lookin good. I'm guessing about 10-15 hp difference? Fingers crossed it's the same.
1951 MG TD
Old 04-07-2016, 03:41 PM   #121
Valarius_Starchaser
Yah I figure a lot will be based on my non aluminum heads and the stock 1.5 rockers someday though
"Orange Crush"
Old 04-08-2016, 12:16 AM   #122
Valarius_Starchaser
Tore into the 4L80e tonight anyone that has ever been inside on of them will know how brutally simple they are.
My unit was a good running one out of a 2000 Express 2500 van so plenty of heavy loads in its life only 110k on it though everything looked good, after further researching the HD2 Transgo kit I decided it wasn't for me and so I will piece out some stuff for my application
What I will do to it is:
- Dual feed mod
- New seals as required
- New snap rings
- Filter (Duh)
- New thrust washer
- New Bands (both looked like they got hot a time or two)
- Sonnax boost valve
- Half a set of piston return springs
All to produce some faster shifts I see no reason to touch anything else such as higher quality clutches and steels or the addition of one set to make it "stronger" because with the total weight and power number of my truck I feel like it will hold fine behind my engine we shall wait and see if this school of thought will pay off.
Anyone with other thoughts/experience? I know these things aren't heavily used at least not in these trucks so maybe I'm talking to myself right now?
"Orange Crush"
Old 04-08-2016, 08:21 AM   #123
Kim57
Kim57's Avatar
Engine looks good.
I had to change the pump in my trans so I did new upgraded frictions at that time.
Kim
My build thread
Old 04-09-2016, 06:44 PM   #124
Valarius_Starchaser
Finally got around to wire wheeling/grinding down that axle housing I think I got gun-shy from having it fracture my finger (that nails looking pretty nasty right now defanitly only going to have 4 nails on my left hand for my wedding )
Here's a few pictures of the trans tear down and the axle before and after
"Orange Crush"
Old 04-09-2016, 08:12 PM   #125
Advanced Design
Looks good Valarious . Wire wheels are sure hazardous. Never had one break a finger though they are wicked at impaling me with wires.
1957, 3100, 454, 4l80e, drag truck
