Old 04-19-2020, 02:18 PM   #101
slimjim66
Re: Slammed 1966 GMCummins 12v
Trans cooler with fan, I’ll use a manual toggle to keep the trans temp in line. I don’t like relying on those crappy expensive boxes to control the temp of your stuff. They always seem to fail just after your put all your trust in them
slimjim66 is offline   Reply With Quote
Old 04-19-2020, 11:08 PM   #102
0ldSoul
0ldSoul's Avatar
Just found your build and read through it. Very cool truck!! Chassis looks awesome, and the engine work, kick a$$!
I have to say, seeing it laid out on transits is something else.
Looking forward to the updates.
My '63 Restomod Build
283/4 speed, 4.5/7 static c-notched drop, disc brakes, power steering
Instagram: in2engines
0ldSoul is offline   Reply With Quote
Old 04-20-2020, 07:05 AM   #103
slimjim66
thanks man, im happy with it so far.
Old 04-25-2020, 08:43 AM   #104
slimjim66
I got my batteries hooked up, I’ve never ran two before so this was a first for me. They are hooked in parallel so positive to positive and negative to negative will give me a 12 Volt system with double the amps. Used mainly for starting the old Cummins. In reality I don’t think I needed the two since I won’t be doing any winter driving with it. I got these terminal clamps from summit and turns out I was able to run a 3/8” all thread through one to the other. Worked out great I think, I am missing the main cable to starter in the picture. I’m keeping it off until I wire the truck.
Old 04-25-2020, 08:49 AM   #105
slimjim66
I needed to run a return line to my tank, I was scratching my head for a few weeks on this one but ended up drilling a hole beside the main fuel line and put in a NPT bulk head fitting with a 90 then a NPT-Inverted flare fitting. Bent up some lines and boom it looks almost like GM did it 60 yeas ago, also I forgot to order fuel tank straps and with the shipping delays today I had to get crafty so I used my seat belts I had ordered for my bench seat. I must say they do look pretty decent back there
Old 04-25-2020, 08:57 AM   #106
slimjim66
Now I’m working on the gauges. I cut out the middle of my old cluster but left enough meat to drill a few holes and use screws to hold on a plate with my gauges in them. I was going to order a few more gauges to fill up the space but buying gauges for no reason is expensive. I think I’ll run a couple toggle switches I’ll need to fill up space. This is by no means a show truck so little chrome toggle switches on the dash won’t bug me. I like to watch the gauges and control the fans and temp myself.
Old 04-25-2020, 09:00 AM   #107
slimjim66
Also been tinkering with the cooling system, made my own rad hoses out of exhaust pipe and silicone couplers. Looks good and should be fairly durable. I’m going to powder coat them the same colour as my valve covers and turbo and such after I work the bugs out of it.
Old 04-25-2020, 09:05 AM   #108
slimjim66
I’m going to get the truck running and driving hopefully next week or two then take a small break from it. I’ve been “working from home” for the past 6 weeks with this virus crap and I’m kinda getting burnt out form the truck. I’d like to bring my Lincoln home and drive it a bit.
I have new black carpet for the truck, it’s laying out in my basement trying to get the creases out, does the carpet lay in pretty good with these trucks? Or is it a pain in the arse like any other carpet I’ve done before?
Old 05-12-2020, 08:20 PM   #109
slimjim66
Gettin there, rads in and hooked up, trans is filled up with oil, brake lines are fully complete, throttle linkage and on and working good and my mechanical fuel shut off is in. I was able to retro fit the original choke cable from the OG motor into the shut off. Works amazing.
Old 05-12-2020, 08:21 PM   #110
slimjim66
Gauges are cut out and in, ready for the full wire
Old 05-12-2020, 08:27 PM   #111
slimjim66
And she runs... black smoke everywhere. Hopefully I can run it down the road a mile or two this weekend.
Old 08-19-2020, 08:01 PM   #112
slimjim66
Haven’t been doing much cause of the heat but I’m back at it now, I got some old barn board from a neighbour, it’s just sitting in there but looks like it will match fairly well. and installed the roll pan
Old 08-20-2020, 10:10 AM   #113
88Stanger
88Stanger's Avatar
Ya, ok i just found this build, DAMN nice work! I love the Lincoln!!!! read thru the entire build, keep up the great work! We are watching.....
88Stanger is offline   Reply With Quote
Old 08-20-2020, 03:49 PM   #114
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice build on the truck. It's looking sweet!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-20-2020, 06:11 PM   #115
Wizit247
Wizit247's Avatar
This is so sick! I don't know how I hadn't found this until now.
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901
Wizit247 is offline   Reply With Quote
Old 01-10-2021, 12:31 PM   #116
slimjim66
Been a bit since I’ve posted, getting lots done on the truck. Interior is in, new carpet, sill plates and kick panel carpet.
Old 01-10-2021, 12:37 PM   #117
slimjim66
Bed is all done
Old 01-10-2021, 12:42 PM   #118
slimjim66
Wiring is complete as well, easiest wire job I’ve ever done. Gotta love the simplicity of the Cummins 12 valve.
Old 01-10-2021, 12:46 PM   #119
slimjim66
Gonna send some parts off to powder coat this week, all these in satin black to match the willwood master cyl
Old 01-10-2021, 09:27 PM   #120
53Sparky
53Sparky's Avatar
First time I've seen this thread - cool project! I'll be following along!
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 01-15-2021, 12:27 PM   #121
Dieselwrencher
Very nice work. The only thing I think you may have issues with is that short exhaust. Your bed is going to be black and nasty in the very near future.
Ryan
Old 01-17-2021, 10:19 AM   #122
slimjim66
for sure it will be, i saved a few extra boards for the bed so i can run the exhaust out the back, when i get sick of being covered in soot.
Old 04-03-2022, 08:46 AM   #123
slimjim66
Been a bit since I’ve given an update. Got parts back from powder coating.
Old 04-03-2022, 08:57 AM   #124
slimjim66
Because I can’t leave well enough alone I decided to compound turbo the Cummins. It’s a Borg S475 over the stock holset. Along with the fun comes valve springs, head studs and a new head gasket. The rocker pedestal needed .200” taken off for rocker cover clearance.
Old 04-03-2022, 09:09 AM   #125
slimjim66
Got everything back from powder coating again, I built the hot and cold side myself from 3” tubing. It was a tedious job but I got it done. Stuffed a intercooler in the front as well. With little grille modifications it fits perfectly behind there. I needed an external wastegate to give the little turbo a break at high RPM’s. It’s a 60mm precision gate that blows into the big turbo exhaust inlet. I’ve got no way of controlling max boost so a blow off valve or another wastegate might be in my future shopping cart at Summit. We will see…
