Old 06-17-2021, 09:39 PM   #101
mobileortho
mobileortho's Avatar
Re: '50 3600 re-do. Shortening things up!
Originally Posted by joedoh View Post
man that is a nice score.
I really like how you stick with your project without meandering on goals. if it hasnt been mentioned before, you get a lot of my respect for that.
Wow, thanks.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 06-19-2021, 01:44 AM   #102
mobileortho
The sway bar is 4” too long. Thinking about shortening it. I’ve heard both sides of those for and against it but figure I may as well give it a shot. Here’s a couple of vids that seem promising:
https://youtu.be/ECiJB3CtLyc
https://youtube.com/watch?v=ZCUF-LfxYLo&feature=share
When I had the 1/2 ton IFS in it previously, I had the crossmember and center link shortened. The link was sleeved using a similar process.
Robert C.
1950 3600
Old 07-23-2021, 11:14 AM   #103
mobileortho
Found the correct length sway bay, 39.5". I had the option but declined ordering the complete kit which included the installation components because I already had the ones from the other bar and as luck would have it , the heim joints are different sizes...sigh.
Robert C.
1950 3600
Old 07-23-2021, 11:18 AM   #104
mobileortho
Working on a cold air intake.
Robert C.
1950 3600
Old 07-27-2021, 07:31 AM   #105
6DoF
6DoF's Avatar
i really like the intake! i used that same can on my Jeep to do something similar.
6DoF is offline   Reply With Quote
Old 07-27-2021, 08:04 AM   #106
Father&son56project
Nice job snaking that intake tube around some pretty confined spaces!
Father&son56project is offline   Reply With Quote
Old 09-07-2021, 11:06 AM   #107
mobileortho
Getting the firewall smoothed out & trying to decide where to run the wires. Thinking about using the hole on the passenger side below the hinge bolt.
Robert C.
1950 3600
Old 09-19-2021, 10:51 PM   #108
mobileortho
Not perfect but much better than what I started with.
Robert C.
1950 3600
Old 09-19-2021, 11:12 PM   #109
dsraven
Looks great.
Old 09-20-2021, 08:47 AM   #110
8man
It does look good. What master cylinder is that?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 09-20-2021, 09:10 AM   #111
mobileortho
I don't recall, but I bought it on Ebay a few years back. Gotta replace the booster though. I stripped a couple of the bolts mounting it back up.
One thing I don't like about the LSFAB firewall inserts is that they're cut exactly the same so the drivers side doesn't match up very well.
Robert C.
1950 3600
Old 09-20-2021, 09:12 AM   #112
8man
Ouch! I like the look.
8man-aka Robert
Old 09-29-2021, 01:14 PM   #113
rnrdthefox
I like the cold air intake idea. I assume it's a kit? Where did you get it from? Thx.
rnrdthefox is offline   Reply With Quote
Old 09-30-2021, 09:00 AM   #114
mobileortho
No, it was trial & error but I pieced it together with assorted components from Amazon & EBay plus a few odds & ends I had laying around.
1. 90 deg elbow
2. 45 deg coupler
3. 4" coupler
4. Spectre Air Box
5. 4" air filter Adaptor
Robert C.
1950 3600
Old 09-30-2021, 12:08 PM   #115
rnrdthefox
1. 90 deg elbow
2. 45 deg coupler
3. 4" coupler
4. Spectre Air Box
Understood. Thanks for the links.
Old 10-07-2021, 04:22 PM   #116
mobileortho
I find myself going back to fix stuff I did the 1st time around. I had a "just get it done by what ever means necessary" mentality then. One of those things was hiding the louvers on to give the truck a smooth appearance. I really had no tools, no knowledge on what or how to do it so I took a hammer and beat them down, then filled it in with bondo. (DON'T JUDGE ME!! LOL!) I bought a new set of cowls to do it right, or to the best of my ability this time. Gonna cut out out the louvers and weld in a patch.
Robert C.
1950 3600
Old 12-19-2021, 09:51 PM   #117
mobileortho
Progress has slowed dramatically but I’m still chipping away at it. Revisited the door handles & decided to go with the 52-59 push button with the Altman latches. Still figuring it out as I go.
Robert C.
1950 3600
Old 12-24-2021, 07:51 PM   #118
mobileortho
Anyone know where l can find a set of these mounting plates?
Robert C.
1950 3600
Old 12-25-2021, 10:38 AM   #119
8man
I got mine from some junk doors after a lot of looking. Good luck finding some.
8man-aka Robert
Old 12-25-2021, 11:04 AM   #120
dsraven
Maybe have to make some. Form sheet around an MDF pattern. You can do it.
Old 01-07-2022, 07:14 PM   #121
mobileortho
Lol! Thanks for your confidence in my beginner fabrication skills. I don’t even know what MDF is!!
Robert C.
1950 3600
Old 01-07-2022, 08:06 PM   #122
Rickysnickers
Medium density fiberboard. You can find it in just about any hardware store or Home Depot type store. If there is a woodworking store near you, you might be able to buy smaller pieces.
Old 01-07-2022, 08:58 PM   #123
mobileortho
Thanks! I’ll check that out!
Robert C.
1950 3600
Old 01-07-2022, 11:36 PM   #124
dsraven
or if you have steel, that works. more farting around though.
Old 01-24-2022, 10:09 AM   #125
mobileortho
Still working on the doors & cowl panels. The drivers door works perfectly, the passenger side...not so much. still need to fine tune it a bit as it takes a fair amount of force to depress the button. Also looks as though there's no way to unlock the doors with the key if it was locked from the inside?? As luck would have it, I found one of the door handle plates I was looking for.
Robert C.
1950 3600
