Old 05-25-2020, 10:06 AM   #101
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
Then the buckets were checked for a perfect fit
skymangs is offline   Reply With Quote
Old 05-25-2020, 10:13 AM   #102
skymangs
skymangs's Avatar
Then finally they were welded and ground. Next we’ll use all metal filler to smooth the transition.
Old 05-28-2020, 10:16 AM   #103
skymangs
skymangs's Avatar
Alex obviously has much to learn about the art of body fller. But it’ll turn out.
Old 05-28-2020, 10:35 AM   #104
skymangs
skymangs's Avatar
we did the initial fill with All Metal and then finished in Evercoat
Old 05-30-2020, 12:14 AM   #105
joedoh
joedoh's Avatar
looking great!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 05-30-2020, 08:44 AM   #106
skymangs
skymangs's Avatar
Thanks joedoh
Old 06-11-2020, 01:10 PM   #107
skymangs
skymangs's Avatar
Alex has finished the frenched headlights
Old 06-11-2020, 01:17 PM   #108
skymangs
skymangs's Avatar
more pics
Old 06-11-2020, 02:08 PM   #109
youngrodder
youngrodder's Avatar
They look great. Having used this kit in the past the the adjusters for the headlights suck (at best). You might consider reworking that so you can adjust your headlights.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-11-2020, 02:20 PM   #110
skymangs
skymangs's Avatar
Good point
Old 06-11-2020, 03:11 PM   #111
youngrodder
Originally Posted by skymangs View Post
Good point
The problem is the plastic rings that hold the headlights. When you screw in the adjuster it simply warps/flexes the plastic ring so the headlight doesn't really adjust. Don't get me wrong I love the way they make the front ends look on AD trucks but the functionality aspect killed it for me.
Marc
Old 06-12-2020, 08:25 AM   #112
gigamanx
DAng guys, I'm gone for a month and come back to an almost finished project. Really makes me look lazy when I took 2 years to do mine haha.
Just a thought on the welding....looks like the welder is maybe set too cold? I'm no expert, just saw similar welds when I started out with my MIG140 before upgrading to a 220v mig welder.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 06-13-2020, 07:34 PM   #113
skymangs
skymangs's Avatar
yeah Alex is still learning to weld. You should have seen when he first started out!
Old 06-13-2020, 07:41 PM   #114
skymangs
skymangs's Avatar
This is the sunroof it started with. The issue was that weight of the glass caved the whole roof flat, so we had to replace the whole thing.
Old 06-13-2020, 07:48 PM   #115
skymangs
skymangs's Avatar
After tracing the patch then accounting for the 1” flange we were going to utilize. The roof was cut away.
Old 06-13-2020, 08:02 PM   #116
skymangs
skymangs's Avatar
The patch was fitted into place, then Cleco's were used to hold it in place for welding. Notice, no 90* corners. They are prone to cracking so near to a compound curve in such an expanse of sheetmetal.
Old 06-13-2020, 08:15 PM   #117
skymangs
skymangs's Avatar
Then we welded 2” at time, moving 2'. So as not to warp the sheetmetal. The result? A nice curved factory looking roofline.
Old 06-15-2020, 09:10 PM   #118
skymangs
skymangs's Avatar
Roof patch is all welded in. Started grinding. There is some heat warpage in the rear, so I ordered a shrinking disk. $120, but I’ve been looking for an excuse to buy one. One can never have too many tools!
Old 06-15-2020, 10:44 PM   #119
youngrodder
The sunroof delete looks great...nicely done.
Marc
Old 06-15-2020, 10:46 PM   #120
joedoh
joedoh's Avatar
great work! big panel replacement like that is no joke
Old 06-16-2020, 08:59 AM   #121
skymangs
skymangs's Avatar
No doubt! Thank you!
Old 06-18-2020, 11:26 AM   #122
skymangs
skymangs's Avatar
This is what we started with. I have circles cut from 18ga in serval key sizes for patch work. The circle is then shaped to match the curvature of the surrounding pastel and welded into place.
Old 06-18-2020, 11:35 AM   #123
skymangs
skymangs's Avatar
Then it is ground down and finally bodyworked. Remember, the more time you spend on panel fitment, the less you’ll spend on bodywork.
Old 06-19-2020, 08:26 AM   #124
skymangs
skymangs's Avatar
The floors required a lot of attention, I put Michael on this
Old 06-19-2020, 08:35 AM   #125
skymangs
skymangs's Avatar
Alex is installing the new 4x4 diff, flipping the springs, drop blocks, new shocks, and wheels.
