Old 08-03-2022, 09:21 AM   #101
KyleSeal
KyleSeal's Avatar
Re: My 1967 Build (Finally)
Flattened out the blower motor 'face' for looks. Getting the final touches on this box this weekend. Also added a picture of a stock box so you can see exactly what is different.
Size:  55.4 KB Name:  IMG_0822.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 08-05-2022, 08:33 AM   #102
KyleSeal
KyleSeal's Avatar
Passenger side firewall is just about all done, pretty satisfied with the end result. After / before for comparison.
Size:  51.7 KB Name:  IMG_0889.jpg
Old 08-17-2022, 10:23 AM   #103
KyleSeal
KyleSeal's Avatar
While I work on the cowl section more, here's a mock up photo.
Old 08-18-2022, 08:37 AM   #104
KyleSeal
KyleSeal's Avatar
Well finally back to getting things where I want them, I had to re-do the outer cowl patch, the metal was just so thin I kept blowing through. Also went through and blasted a bunch of parts, back side of inner cowl, brackets and the L shaped brackets for the rear cab.
Size:  107.7 KB Name:  IMG_1050.jpg
Old 08-18-2022, 08:38 AM   #105
KyleSeal
KyleSeal's Avatar
Some pics of the inner cowl patches through the outer cowl... and one more mock up photo..
Size:  40.8 KB Name:  IMG_1052.jpg
Old 08-22-2022, 09:39 AM   #106
KyleSeal
KyleSeal's Avatar
Finishing the inner cowl, being it is now symmetrical I just copied the other side and welded in a new support bracket for the fender.
Size:  52.1 KB Name:  IMG_1089.jpg
Size:  57.1 KB Name:  IMG_1076.jpg
Old 08-24-2022, 08:14 AM   #107
KyleSeal
KyleSeal's Avatar
Phosphoric acid treatment on the cab side of the cowl, hopefully into paint tonight.
Size:  102.3 KB Name:  IMG_1105.jpg
Old 08-24-2022, 08:17 AM   #108
KyleSeal
KyleSeal's Avatar
Inner cowl I had painted the day before, installed on the mock up front end to make sure nothing wild has happened, gaps look good!
Size:  56.8 KB Name:  IMG_1111.jpg
Size:  57.0 KB Name:  IMG_1112.jpg
Old 08-26-2022, 11:20 AM   #109
KyleSeal
KyleSeal's Avatar
Waiting on paint from Eastwood to be delivered to finish the cowl.... heres some photos of the bumperettes I installed the other night.
Size:  65.7 KB Name:  IMG_1138.jpg
Old 08-29-2022, 08:26 AM   #110
KyleSeal
KyleSeal's Avatar
Rust encapsulator on the inner cowl, this stuff sprays really nice and event, worked really well.
Size:  80.3 KB Name:  IMG_1160.jpg
Old 08-29-2022, 08:38 AM   #111
KyleSeal
KyleSeal's Avatar
Holy seam sealer Batman - but it needed it, the driver side was a cluster of patches and rough edges. Plus I have too much seam sealer on hand. This SEM 2in1 seam sealer does a great job, sticks well, can be direct to metal (I like getting a primer down first) and is smooth going down, flows well into cracks and seams.
Size:  53.6 KB Name:  IMG_1175.jpg
Size:  77.5 KB Name:  IMG_1174.jpg
Old 08-30-2022, 03:04 PM   #112
Akleypas
Good looking truck! I like how meticulous you are with the build👍 Keep the progress and momentum going strong.
Akleypas is offline   Reply With Quote
Old 09-01-2022, 08:28 AM   #113
KyleSeal
KyleSeal's Avatar
Thank you! Your build is coming along really nicely. Great work!
Old 09-09-2022, 10:13 AM   #114
KyleSeal
KyleSeal's Avatar
Reattaching the cowl. Boy is it not fun filling up all those big spot weld holes. but its on, and ground down. Went through and put rust encapsulator on all the exposed areas after sanding. Next is seam sealer, and matched paint.
Size:  86.2 KB Name:  IMG_1228.jpg
Size:  57.3 KB Name:  IMG_1264.jpg
Old 09-12-2022, 09:28 AM   #115
KyleSeal
KyleSeal's Avatar
Tested out some of the paint match stuff I got from a local supplier and it matches pretty darn'd close. Honestly on an old truck like this its beyond close enough! Now to make it less pretty with some scotch brite.
After spraying, I made the trek to Concord (Charlotte), North Carolina and went to the Truck and Car Shop (about 4.5 hours away) to get some much needed parts and to check quality on some new door bottoms (yes, they have been retooled) and other things.
Size:  45.0 KB Name:  IMG_1274.jpg
Old 09-12-2022, 09:35 AM   #116
KyleSeal
KyleSeal's Avatar
A bit of some non truck related stuff.. the reason I went to North Carolina was to see Alan Jackson in Greensboro on his farewell tour, what an amazing show. Then I made my way back to Virginia Beach on Sunday to see Willie, which was his farewell tour as well I hear. Glad I got to see Willie, I jokingly call my truck Willie because of its shade of green and the fact it smoked like no tomorrow when I got it.
Size:  43.7 KB Name:  IMG_1402.jpg
Old 09-19-2022, 11:16 AM   #117
KyleSeal
KyleSeal's Avatar
Back onto the drivers side repairs - a-pillar is solid and now I move onto the rocker repair.
Size:  67.8 KB Name:  IMG_1491.jpg
Old 09-22-2022, 08:23 AM   #118
KyleSeal
KyleSeal's Avatar
Found the front of the rocker on the driver's side was pulled in on the front quite a bit, as you can see. And the inside of the rocker that joints the a-pillar was way off. Ended up cutting that front portion off and doing a lot of small adjustments. Welded it all back up...
Size:  95.6 KB Name:  IMG_1519.jpg
Size:  50.1 KB Name:  IMG_1521.jpg
Old 09-22-2022, 08:24 AM   #119
KyleSeal
KyleSeal's Avatar
.... and ground it flat. Seems to be in good order now, on the front that is.
Size:  80.7 KB Name:  IMG_1537.jpg
Size:  48.6 KB Name:  IMG_1536.jpg
Old 09-22-2022, 08:26 AM   #120
KyleSeal
KyleSeal's Avatar
The rear of the rocker always had this weird slant to it, so I just made a small piece to fill it. Not super straight, but this area will be covered with seam sealer. This just helps me sleep better at night.
Size:  91.0 KB Name:  IMG_1540.jpg
Old 09-23-2022, 08:27 AM   #121
KyleSeal
KyleSeal's Avatar
Rocker panel is welded in.. and man am I happy to remove that equalizer bar from the door jamb.
Old 09-23-2022, 11:42 AM   #122
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Truck is really coming along keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-27-2022, 02:06 PM   #123
KyleSeal
KyleSeal's Avatar
Thank you! Finally getting to some cooler weather so hoping to up the efficiency!
Old 10-10-2022, 10:13 AM   #124
KyleSeal
KyleSeal's Avatar
Flipped the cab on its back, and began cleaning for the undercoating. I found that different solvents and aircraft stripper did absolutely nothing to clean it. The best piece of equipment I used was a paint and rust striping disk for a drill, it made quick, extremely dirty work of it.
Size:  56.1 KB Name:  IMG_1642.jpg
Old 10-10-2022, 10:16 AM   #125
KyleSeal
KyleSeal's Avatar
And then it was off to the hills of Lansing, West VA! Company whitewater rafting trip, I hung out at the pub . Also took a stop at JL Fab in Harrisonburg on the way out west.
Size:  53.4 KB Name:  IMG_1658.jpg
Size:  103.2 KB Name:  IMG_1725.jpg
1967, custom, dropped, lowered
