Old 09-20-2016, 10:17 PM   #1276
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Originally Posted by oldman3 View Post
Whoa, never seen something like that...Jim
Me neither Jim.
Originally Posted by joedoh View Post
what the heck? did he powder coat and loosen the axle joint? inquiring minds need the story!
I feel the same way about spiders. everyone freaks out and says "agggghhh burn it with fiiiyyyeeerrrr" and I just scoop them up and put them out. education is the right way to handle it, taught my girls catch and release, when my oldest was 9 she brought me a jar of bees. they werent even mad, just confused. I even stopped a guys foot from smashing a jumping spider that popped out to see what all the noise was when I was cutting some old metal. he jumped on my hand (the spider, not the guy) and walked around then popped off somewhere.
The rear was painted. Good idea on the powder and heat possibly causing the problem.
Our daughter is the same about spiders...catch and release. Wife is more the scream and stomp group.
Originally Posted by reaper71 View Post
Dang Doug!!
reminds me of "Johns" 8" ford that blew apart awhile back.
Mark...
Mark, I was thinking of your story when looking at the pics...and trying to figure out what happened.
Originally Posted by mongocanfly View Post
Wow..never seen that happen to a rearend..heard about it happening but never seen it...any idea of what caused it? That's a nice wagon btw..and congrats on the wedding..
Thanks mongo. It was a great wedding. The wagon came from Cali and is pretty solid. We have some ideas on what happened that I will speculate on below.
Originally Posted by SSABMUD View Post
Holy crap! This is why I stick with the 9". They are pretty strong.
They are...and pretty sure a 9" is going back in.
Originally Posted by lower50's View Post
Wow what happened? That's one long trail of death.
That's what we've been wondering. Friends reported it sounded like a grenade going off at a steady cruise speed. Fairly high speed though. The rear was just rebuilt with new gears, diff case, bearings by a guy who specializes in rear ends in WI. I expected something like the pinion shaft bolt broke and ran between the pinion and ring gear. Or a diff bearing cap came loose, or loose pinion nut. None of the typical contributers were noted.
Another friend with a long and strong auto service engineering background is theorizing the drive shaft (newly manufactured) failed at high speed. The length and weight caused it to begin whipping, contacting the ground leading to the failure. Driveshaft jammed to the ground, prying the pinion up and back, leading to the housing failure. He advised if the rear locked first, the driveshaft would have twisted rather than bent.
He might have a point. There are three fresh gouges in the road evident before the oil was spread over the surface. So, possible he is right...he makes a compelling case.
Advanced Design is offline   Reply With Quote
Old 09-21-2016, 09:49 AM   #1277
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
To me that sounds like a good Failure Analysis. Drive Shaft being the cause, with evidence on the road, axle and trans resulting failure. A good write up and photos sent to the driveshaft company may result in compensation.
Best of luck to your buddy, that is a killer wagon, I've always liked it.
bowtieguy79 is offline   Reply With Quote
Old 09-21-2016, 03:47 PM   #1278
RockinKees
RockinKees's Avatar
First congratz on your daughters wedding!!
Second, nice pics!!!
Third, that was quite a road rage, to damage all that!
Never seen that before...
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-21-2016, 03:48 PM   #1279
lower50's
lower50's's Avatar
That theory makes sense. Was there any other damage to the car? Glad they got pulled over safely.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-21-2016, 08:05 PM   #1280
MIKESAD50
WOW! Never seen that kind or destruction. Do you know if the driveshaft was on the edge of being to long for a one piece?
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 09-21-2016, 09:47 PM   #1281
Advanced Design
Thanks Brad, my engineer buddy is pretty precise and thorough....and it is a theory. Probably accurate though not 100% positive. A local guy with a driveshaft business made it and my car owning friend probably won't press him on it. He was dreaming of doing this build 5 years ago and being so close with the setback is a little disheartening for him.
Thanks Kees, we ended up with many nice wedding pics.
Yeah, the car seemed angry with the road for sure. Hope you finished the install on your transmission ok!
Lowers, the floor pan on the car near the trans was pretty beat up. Other than that, and broken replaceable parts, the car was ok. You are so right on them getting pulled over and stopped safely. If the left axle wasn't held in place by the rear cover, the car could have rolled.
Mike, the original driveshaft was a little longer than this one. My service engineer background friend advised the 3" shaft diameter was too small for the 55 inch length. Factory was 3 1/4". And heavy wall tubing contributed to the issue as well.
Here the rear cover is holding the axle tube in.
Old 09-21-2016, 09:49 PM   #1282
Advanced Design
Note the negative camber on left rear wheel.
Old 09-22-2016, 12:38 AM   #1283
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Hey, congrats on picking up some shop help, aka a son in law!
Zoomin is offline   Reply With Quote
Old 09-22-2016, 08:05 PM   #1284
Advanced Design
Thanks Zoomin! Good part is he is a certified aircraft mechanic and inspector. Really good with his hands. Bad news is he lives 12 hours away!
Old 09-24-2016, 07:35 AM   #1285
rkn463
rkn463's Avatar
Back when I was about 13 (a long time ago indeed) I was riding home with my brother one night in his 68 Camaro that he had "built". I love all of my brothers but like all human beings they each have their quirks. This particular brother always had a few "spare" nuts and bolts left over anytime he worked on his car. So anyway, there we are on a two lane blacktop in the middle of the night when suddenly the car starts shaking really bad. Not knowing what it is he gives it some gas and then backs off and suddenly there is the loudest bang I've ever heard in a car that wasn't just hit by another car, followed by a terrible thrashing and banging. We get the car over to the side of the road only to find that the driveshaft had come loose at the differential where he had forgotten to tighten the clamps. This was back in the mid 70's long before cell phones and we were miles and miles from the nearest pay phone or even a house for that matter. Anyway, in the end the car had a huge dent in the floor and we had a very late night. Back in those days a replacing drive shaft for a 68 Camaro was just a quick trip to the wrecking yard.
I think experiences like that are why I have over think and overdo everything now.
From the looks of the picture his wagon survived pretty well, I'm glad your friend is ok and the car is fixable.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 10-11-2016, 10:09 PM   #1286
Advanced Design
Richard, the driveshaft incident in your brothers car was sure one to remember.
So I've left this fuel tank and filler pipe sitting right here for a couple weeks ....no minions have showed up to do the install.
Old 10-11-2016, 10:13 PM   #1287
Advanced Design
And this week we've set up for and started Metal Meet 2016.
Peter's English wheel is like the Rolex of wheels....very nice.
Old 10-11-2016, 10:16 PM   #1288
Advanced Design
TIG welding seminar taking place here. Great learning opportunity. Oh, and BlueJeep from Des Moines, IA. is attending too.
We started today and the event will run through Saturday.
Old 10-12-2016, 08:24 AM   #1289
RockinKees
RockinKees's Avatar
Are the seminars at your place Doug?
Do you organize these?
I never worked with an English wheel, looks like great fun to make things on that!
Tig welds very nice, I have a small tig machine, I love it!
Cheers!! Kees.
Kool Guyz CC
Old 10-12-2016, 01:57 PM   #1290
GAc10boy
GAc10boy's Avatar
Tough to see that kind of damage to the rearend on the wagon but glad it's fixable. Can't wait to see more progress on the burb.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 10-12-2016, 09:09 PM   #1291
Advanced Design
Hi Kees, the event is held at the fairgrounds in Oblong and I am one of the organizers. We have folks from around the US and one Australian attending with a focus on metal shaping.
Hey Robbie, appreciate you checking in. Yard work is slowing down so shop time and Burb progress should increase soon. At least I hope so....
Old 10-13-2016, 06:41 PM   #1292
lower50's
lower50's's Avatar
How often are the Metal Meets? That would make for a great weekend trip.
1951 MG TD
Old 10-13-2016, 09:47 PM   #1293
Advanced Design
Hey Lower, this one takes place once annually in October. Really great people and lots of learning...
Old 10-13-2016, 09:49 PM   #1294
Advanced Design
Here is the panel that was being made in the pic above....
Old 10-13-2016, 10:10 PM   #1295
lower50's
lower50's's Avatar
Thanks Doug I'll put it on my list for next year.
1951 MG TD
Old 10-14-2016, 01:09 AM   #1296
joedoh
joedoh's Avatar
look like fun times, I remember seeing a metalshapers meetup years ago where they all brought their english wheels and shot bags and built a 33 willys coupe. from scratch. in aluminum. I realized that the sparky life was for me.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-16-2016, 08:45 PM   #1297
youngrodder
youngrodder's Avatar
Looks like a fun get together. Don't feel bad about your lack of Suburban time, I have not touched mine in months...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-28-2016, 09:28 PM   #1298
rkn463
rkn463's Avatar
Wow, what a great learning opportunity!
-Richard
Old 11-26-2016, 08:20 PM   #1299
Advanced Design
Ok, in between working on the Gator, the Grasshopper, and doing the final yard work of the season I was able to get in a little shop time. Emphasis on little....
Wife arranged a very comfortable shop seating area for the winter, complete with salted peanuts in the shell and cold beverages....nice though it doesn't contribute to getting up and getting to work.
Old 11-26-2016, 08:23 PM   #1300
Advanced Design
In earlier posts I mentioned the new floor was media blasted and coated with Lizard Skin. It looks pretty good from the bottom.
