Closed Thread
Old 09-25-2012, 11:57 AM   #1301
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
Got some woodworking projects out of the way. Determined that the fill tube from the wrecking yard probably will not work without modification and it has a lot of plastic parts that may not stand up to cutting and welding.
OrrieG is offline
Old 09-25-2012, 08:40 PM   #1302
mknittle
mknittle's Avatar
I finished adding stiffeners to my floor and welded a small section in the middle of the toe board to the floor. i added stiffeners for the stock e-brake mount because it cracked the stock floor. and made one for the passenger side because i removed the lip where the stock toe board meets the floor.The rest will come off when I get some room.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 09-25-2012, 10:06 PM   #1303
Wheelie
Got these 17" offsets!
My '59 Build Thread
Wheelie is offline
Old 09-26-2012, 07:14 PM   #1304
handyhands
started welding in my floor panels and still working on the fire wall. 53/s10
handyhands is offline
Old 09-26-2012, 07:28 PM   #1305
crossfire84
crossfire84's Avatar
put the other side of exhaust system on.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 09-26-2012, 09:57 PM   #1306
Wheelie
Scrapped the 4 link for now. Went ahead and flipped the axle. I got all the rear suspension hung tonight minus the axle u bolts and lower plate which I am still looking for (my axle is just under 3". My engine is almost out of the machine shop and Im ready to have a roller again!
My '59 Build Thread
Wheelie is offline
Old 09-26-2012, 10:35 PM   #1307
mknittle
mknittle's Avatar
I think i got my clutch linkage worked out.
Mark
My GMC build.
mknittle is offline
Old 09-27-2012, 04:27 PM   #1308
Nordic
Nordic's Avatar
Got it registered!!!!!! Now to see how it drives!
Nordic is offline
Old 09-27-2012, 06:59 PM   #1309
mknittle
mknittle's Avatar
WOOOHOOOO
Mark
My GMC build.
mknittle is offline
Old 09-27-2012, 07:13 PM   #1310
mknittle
mknittle's Avatar
I took two clutch bell cranks and made one. but it came out crooked!
Must have been that wooden Smokey the bear ruler. I knew I should have throwen it away after it caught fire!
Mark
My GMC build.
mknittle is offline
Old 09-27-2012, 07:52 PM   #1311
crossfire84
put new rotors on the back.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-28-2012, 03:40 AM   #1312
Hot Rod Todd
I drove mine home - I keep it in my warehouse at work as the home garage isnt really big enough to spread out in.
Have a supply of poormans dynamat and will start putting that in the truck tonight, and will try to sort out some issues with my "Chinese River" steering column while Im working in there.
Hot Rod Todd is offline
Old 09-28-2012, 03:44 AM   #1313
RINC
RINC's Avatar
I drooled over new pics my buddy sent me from his shop ....
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 09-28-2012, 03:24 PM   #1314
crossfire84
test fit the box and fenders.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 09-28-2012, 03:41 PM   #1315
Russell Ashley
Russell Ashley's Avatar
I got my condenser mounted and my X brace back in. I put the condenser as far in toward the radiator as the hard lines would allow, and made some one inch spacers for the top of the X brace and 3/4 inch spacers for the bottom, and bolted it back in. I'll have to move the radiator back slightly to clear the condenser but I have plenty of room since my truck was originally a six.
If you are installing a vintage Air setup like this don't go by the template that they supply to cut the holes for the lines. Get the condenser mounted first and then see where the holes need to be. Mine don't match the template.
Russell Ashley is offline
Old 09-28-2012, 04:53 PM   #1316
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work Russell!
ChuckDriver is offline
Old 09-28-2012, 07:25 PM   #1317
Russell Ashley
Thanks, Chuck. It took me a lot longer than it should have because I got disgusted with it a couple of times and quit on it for a while. I thought it should have fit up better than it did since it's all Vintage Air stuff. They are sending me some rubber grommets to go in the holes so I can't do anything more until I get those. Their tech support folks are friendly and nice to deal with though.
Old 09-28-2012, 09:14 PM   #1318
la hi
Wraped my headers, put boots on the plug wires, made new metal bases for the electric bucket seats, did a test drive to see if the new u-joints would vibrate, the engine temp went down from 215 to 185/190, and all is well.
la hi is offline
Old 09-29-2012, 09:06 PM   #1319
OrrieG
OrrieG's Avatar
Committed to the gas door. Details in the build thread.
OrrieG is offline
Old 09-30-2012, 04:32 AM   #1320
arturo7
arturo7's Avatar
Bought a crate 350.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 09-30-2012, 07:20 AM   #1321
Johnny49
Last coat of urethane on the last four pieces of the original bed wood... Here's a little sample of what the whole thing will look like:
Johnny49 is offline
Old 09-30-2012, 03:30 PM   #1322
pvienneau
pvienneau's Avatar
Cleaned the Bell housing on my 49
pvienneau is offline
Old 09-30-2012, 05:11 PM   #1323
mknittle
mknittle's Avatar
I discovered that the bell housing I was going to use is a buick(starter on the right) i need one with the starter on the left. So it looks like i get to swap it for the one in my jeep.
Mark
My GMC build.
mknittle is offline
Old 09-30-2012, 06:20 PM   #1324
Dan in Pasadena
Dan in Pasadena's Avatar
Amazing that the original wood is in one piece and reuseable at all!
Dan in Pasadena is offline
Old 09-30-2012, 06:40 PM   #1325
Rude Dude
Rude Dude's Avatar
Angry Re: What Did You Do With Your Truck Today ?
Installed the front sheet metal, a word of advice do not buy off shore chrome grills. I spent two days trying to alin the grille area finally figured out the grill was the culprit I put painted one back on and everyhing lined up perfect. I will body work the front sheet metal and have my grill rechromed no more fighting that made in tawain or china garbage!!!!!!
Rude Dude is offline
Closed Thread
