Old 01-19-2013, 04:19 PM   #1351
ryanroo
ryanroo's Avatar
Re: Finally starting my Longhorn 4x4 conversion
What is the difference in the drw vs the srw? is the housing different, or is it just the WMS of the hub located farther in? i know a dually has more hub sticking out but ive never been able to find out if it has a different housing as well. or really any definitive WMS-WMS dimension. i know my RC60F is somewhere around 69.5-70" and i think the 80 is 70"
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-19-2013, 04:34 PM   #1352
ryanroo
ryanroo's Avatar
Originally Posted by Dieselwrencher View Post
I have a 2002 Dodge at the shop that I put a Kelderman kit on last fall. It will take some time to make the brackets, but it's well worth it in the end. I can post pics of that set up. it utilizes the spring and shackle hangers too. The shackle hangers were a mount for each air bags's ping tank. The front spring hangers are where the top link hooked in, and then you add a lower link bracket ahead of the spring hanger. I have wanted to do this for a while and now might just be the time. That dodge rides so nice it isn't believable.
i'd look at pictures! ill have to use all custom bracketry but i like to see where i can rob ideas. personally i think they use too short of links, but i suppose that is the rock buggy stuff coming out in me. i am also curious how you determine the size need for the ping tanks. also i wonder if they are neccesary for a lighter truck with large bags. it would seem that most regular road bumps wouldnt move the axle enough to make it matter with a larger bag.
Ryan
72 K20 12v build
Old 01-19-2013, 05:06 PM   #1353
watahyahknow
watahyahknow's Avatar
Ryan
the flange on the drw hub sits farther in compared to the srw so it moves the wheel closer to the diff
there 4 different widths for the chevy 14 bolt those can be made by 2 different axlewidths and the 2 different types hubs , to make a chassis cab dually axle for instance you need a single wheel axle with dually hubs
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-19-2013, 06:24 PM   #1354
ryanroo
ryanroo's Avatar
I am pretty familiar with the GM 14 bolt stuff. ive been bleeding GM since i was old enough to walk . Ryan and i both have dodge dana 80s in our trucks, and the information is not nearly as easy to find on these weirdo axles and usually seems to be in conflict from one source to the next.
Ryan
72 K20 12v build
Old 01-19-2013, 09:17 PM   #1355
watahyahknow
wherent the newer dodge axles allready fitted with diskbrakes ?
if so it shouldnt be too hard to upgrade the older style ....... just googled it they do and they started in 2001 .......
googled some more the hubs for the newer axles seem to be different , maibe the disks and calipers fit though
Old 01-19-2013, 09:26 PM   #1356
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
The only thing about those is the parking brakes always suck.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-19-2013, 10:50 PM   #1357
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That and the super duty d80s are a metric bolt pattern so these rotors won't swap over. And they had a lot of problems with these calipers sticking.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-20-2013, 05:01 AM   #1358
watahyahknow
hmmmmm oh whell looks like its going to cost yah then , i wonder if those aftermarket brakes are any better if it comes to sticking , theres a LOT of water being sucked in back there when its raining
Old 01-20-2013, 11:46 AM   #1359
ryanroo
ryanroo's Avatar
Gm's were sticky too. and the pbrake sucked. my HD was always eating rear pads. every time i pulled the calipers i cleaned the slides and doped them generously with copper anti-sieze and they still always sucked. i was on my 3rd or 4th set of rear pads to my 1st set on the front. rear disks are just tempermental.
72 K20 12v build
Old 01-20-2013, 11:57 AM   #1360
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
We've never had a problem with the '01 or '04 HD GM rears or fronts and most of our miles were loaded or towing. 110,000 miles on the 04 duramax and original pads all around
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-20-2013, 12:09 PM   #1361
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Hey there buddy
Don't get me wrong buddy because i don't want to give you the impression I bang out trucks......lol....rolls my eyes...( because nothing happens over night at my shop )..But man I can't wait to see you driving and ripping around in it....it's bad a$$....and I wish it was in my shop...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 01-20-2013, 04:10 PM   #1362
watahyahknow
maibe use stock brakedisks and aftermarket calipers like brembo or sumtin like that
i just googled rear brakecallipers and there where a lot of links to frosen calipers problems on all sorts of cars and trucks , guess there just a little more maintanance involved in them
strainge thing is i have reardisks on a mercedes 190 (ok its a real lichtweight compared to a truck ) but no problems with brakepads wearing irregulair or callipers seizing up , maibe dust sand mud and stuff like that has some to do with it as we only have asphalt roads and green country where i drive
these mercs have a mecanical drumbrake inside the disk for the emergencybrake btw
Old 01-21-2013, 01:23 AM   #1363
Dieselwrencher
Maybe AAM rear disc brakes from the 3rd gen doxdges is the way to go. But cost is the issue. Maybe I need to look into using a pinion brake. Air ride on the rear, boxing the frame, and getting my gooseneck installed are more important.
Ryan
Old 01-26-2013, 12:08 AM   #1364
Dieselwrencher
Here's my gooseneck. It's a B&W that the ball was stuck in. I have been soaking the snot out of it for a month, and today I knocked the ball out with a 12lb hammer.
These pics and measurements are for Mattman2010.
The center section of the hitch is 26" wide.
In between the 2 cross members is 7 3/4".
The angles the center is attatched to are 41 5/8".
The receiver for the ball is 2 1/2".
Ryan
Old 01-26-2013, 12:24 AM   #1365
Mattman2010
Mattman2010's Avatar
Thanks bud!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-26-2013, 12:52 AM   #1366
ryanroo
ryanroo's Avatar
did you dredge that thing off the north atlantic floor?
Matt, i didnt realize you needed all those measurements. i guess i didnt even think about a length.... sorry man
72 K20 12v build
Old 01-26-2013, 01:03 AM   #1367
Mattman2010
Ryanroo no problem man. Now it looks like ill be building my own hitch. It should be pretty simple to make the hitch from scratch.
Build Thread
Build Thread
Thread
Old 01-26-2013, 07:20 PM   #1368
Dieselwrencher
Dude, welcome back to Iowa my friend.
Ryan
Old 01-26-2013, 08:25 PM   #1369
ryanroo
ryanroo's Avatar
how old is that thing? there is 35 year old bare steel here with less rust...
72 K20 12v build
Old 01-29-2013, 12:27 AM   #1370
Dieselwrencher
LMAO! Like I said, welcome to Iowa son! It came from a 02 Dodge. The crap they put on the roads here in the past 10 years is liquid rust man..................
Ryan
Old 01-29-2013, 12:28 AM   #1371
Dieselwrencher
Originally Posted by wutnxt View Post
Hey there buddy
Hey man, we can swap for a while I'm sure.
Ryan
Old 02-01-2013, 10:09 PM   #1372
ryanroo
ryanroo's Avatar
back in the shop?
72 K20 12v build
Old 02-01-2013, 10:21 PM   #1373
wutnxt
Hey which one of mine are you thinking?......lol...Dude you come up here and your welcome to take my 58 for a blast...
Old 02-05-2013, 02:54 PM   #1374
Beat68CST
Beat68CST's Avatar
Any progress on that hood latch yet?
I've been playing the "Spend a life savings on building a 47RH" game lately! lol
Beat68CST is offline   Reply With Quote
Old 02-05-2013, 07:15 PM   #1375
wutnxt
Dude you sleeping over there ?
