Old 12-25-2013, 12:56 PM   #1426
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Merry christmas!
mcbassin is offline   Reply With Quote
Old 12-25-2013, 12:59 PM   #1427
Crash_OK
Crash_OK's Avatar
Re: 1969 Short Wide
Merry Christmas to you Mike.. The truck is looking incredible....
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 12-25-2013, 01:28 PM   #1428
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Merry Christmas Mike,
Scott
93 crew cab build
Project 62
Old 12-26-2013, 01:39 AM   #1429
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Merry Christmas! Can't wait to see some red on there!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 12-26-2013, 06:57 AM   #1430
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
X2 Merry Christmas Mike
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-28-2013, 04:06 PM   #1431
68 Four on the Floor
68 Four on the Floor's Avatar
Re: 1969 Short Wide
How's the gaps looking Mike? Have good holidays
68 Four on the Floor is offline   Reply With Quote
Old 12-28-2013, 11:48 PM   #1432
Bhelton
Bhelton's Avatar
Re: 1969 Short Wide
Very nice work
Bhelton is offline   Reply With Quote
Old 12-29-2013, 01:05 AM   #1433
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1969 Short Wide
Looking incredible Mike!
--Josh
Old 12-29-2013, 01:18 AM   #1434
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks guys. I had a good Christmas.
It has been slow going on the truck. I had to totally work over the bottom of the driver side door. The gaps weren't even close. I had preset them but never had the fender to check it before bodywork. So there was a bunch of wasted time.
Old 12-29-2013, 01:46 AM   #1435
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
More pictures:
Old 12-29-2013, 09:46 AM   #1436
Re: 1969 Short Wide
Looking good!
Old 12-29-2013, 12:38 PM   #1437
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by 68 Four on the Floor View Post
Looking good!
Thanks, I'm still waiting on your build thread
Old 12-29-2013, 12:44 PM   #1438
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Looking great McB! Happy with the results?
Old 12-29-2013, 12:57 PM   #1439
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks. I'm happy with the passenger side over all but the driver side is never going to be as good as I want it. The contour/shape of the door and fender are just a little different. So they won't match up very good. Both pieces are GM original sheetmetal but from two different trucks/years so, I'm wondering if the tooling wore and they just fit the best pieces together at the assembly line?
In any case, I am stuck with what I have. I'll try to get some more pics when I get the final gaps set.
Old 12-29-2013, 01:51 PM   #1440
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Awesome!! Looking good Mike and nice work!
Scott
93 crew cab build
Project 62
Old 12-29-2013, 08:15 PM   #1441
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
Well, the Oklahoma weather was awesome Friday and Saturday. Did you confine yourself to the shop or did you sneak away to the course?
Zoomin is offline   Reply With Quote
Old 12-29-2013, 08:58 PM   #1442
Low Elco
Re: 1969 Short Wide
Ooh, golf addiction rears its ugly head. Work looks good!
Low Elco is offline   Reply With Quote
Old 12-29-2013, 10:54 PM   #1443
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Scott.
No I worked on my project and helped Landen with his. No golf in a long time. Back to winter today.... Ready for spring.
No golf in the game plan. Thanks
Old 12-30-2013, 12:40 PM   #1444
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I was looking at some old photos and I just noticed my original paint factory fender I'm using had a gap issue straight from GM:
It's like the profile of the back of the fender is different than the door. These are the same cab, fender and door I'm using.
This might explain some of my gap issues.
Old 12-30-2013, 02:21 PM   #1445
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
The trim appears to be farther off than the body lines, but you're right -
Old 12-30-2013, 03:32 PM   #1446
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
The trim is off bad too but the fender sits out past the edge of the door, which means to make it even I would have to shim the hinges to make it match. I have adjusted the door outward on the hinge and the gap at the top inside (where the seal hits) has a gap. Basically, I'm stuck unless I change the door, the fender or both.
I'm going to see if I have any more pictures of the donor truck from the side or looking toward the front.
Old 12-30-2013, 03:38 PM   #1447
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
What about going the other way and taking a cut off wheel gap out of where the fender bolts up and welding it back together? Im not sure what those year fenders look like as far as bolting up to know for sure..
Scott
93 crew cab build
Project 62
Old 12-30-2013, 04:19 PM   #1448
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
The problem with doing this, the hood has to have a gap to open properly. If I did this, I would have to cut the hood down too. I really don't want to do that. I cut down the bottom of the door where the yellow tap was the other day and it was major pain. I still have to re do the bodywork on the bottom of the door now.
NOTE TO SELF. Set all gaps on the truck before beginning any body work! I did the door gaps with my cab on the dolly but not with the fenders.
Lesson learned
Old 12-30-2013, 04:20 PM   #1449
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Lesson learned
Ah yeah i didnt even think about that...
Scott
93 crew cab build
Project 62
Old 12-30-2013, 05:10 PM   #1450
knomadd
knomadd's Avatar
Re: 1969 Short Wide
I see the cowl is on in the pictures, but have you checked the gaps for the cowl vs the fender & cab? I ask because I understand your pain with doing body work first, then checking gaps and want to save you some effort if you haven't checked your cowl too. I hope you have already checked this and there isn't a problem. *fingers crossed*
If you move the door out to line up with the fender, would a new seal fix the gap for the door seal? I assume you haven't installed new seals since it's not painted yet.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
