Old 12-30-2013, 05:31 PM   #1451
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by knomadd View Post
I see the cowl is on in the pictures, but have you checked the gaps for the cowl vs the fender & cab? I ask because I understand your pain with doing body work first, then checking gaps and want to save you some effort if you haven't checked your cowl too. I hope you have already checked this and there isn't a problem. *fingers crossed*
If you move the door out to line up with the fender, would a new seal fix the gap for the door seal? I assume you haven't installed new seals since it's not painted yet.
I think the cowl will gap out good from what I have checked. The bolts look like they will fall right in and yes there will be some shims required.
Yes, I did try my new seal on the driver side. It's the push on type so no worries with glue. I can get the door to fit pretty good with the seal but if I adjust it out to match closer to the fender it has a gap at the top between the door and seal.
mcbassin is offline   Reply With Quote
Old 12-30-2013, 05:36 PM   #1452
Low Elco
Re: 1969 Short Wide
Can you sneak the door out a bit to match? I had to on Yeller. You think this is bad, try an aftermarket door! Never. Again. You could maybe mill the slots in the upper hinge to get you a little more "out". I had to do quite a bit of completely painted juggling on Yeller, and it's still not quite right. Check your cowl, as well. They can be waaaaay outta whack. Mine was. Good luck!
Low Elco is offline   Reply With Quote
Old 12-30-2013, 09:06 PM   #1453
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I could adjust the door out enough to match the top of the fender but then the seal won't touch. I'm more than likely just going to have to live with some mismatch.
Old 12-30-2013, 09:13 PM   #1454
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
So as I thought these panels didn't fit too good from the factory. Here is a pic of the same cab, fender and door before and after.
Bottom gap reworked
Old 12-30-2013, 10:24 PM   #1455
AJohn6
Knuckle head
AJohn6's Avatar
Re: 1969 Short Wide
Trucks coming along nicely, I liked one of your patches using what looked like shelving; I nearly did the same thing today.
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 12-30-2013, 10:37 PM   #1456
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks for checking out my build. Sorry the thread is so long. I am slow....
I assume you are talking about THIS patch panel? I used some sheet metal from the scrap yard that is used to make HVAC cabinets. It was the same thickness as the original floor metal. I used it for several patches, worked great. I also is galvenized so it should resist rust better.
Old 12-31-2013, 01:51 AM   #1457
nasqar
Here kitty kitty kitty
Re: 1969 Short Wide
Nice progress brother! Be patient and dont rush it because you will hate it for years until you fix it "again", lol...
nasqar is offline   Reply With Quote
Old 12-31-2013, 02:43 AM   #1458
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: 1969 Short Wide
WOW!! Just read the entire thread and I am very impressed. You are on the down hill roll of a very nice truck build! Keep up the good work, I'll be watching for updates.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-31-2013, 10:30 AM   #1459
AJohn6
Knuckle head
AJohn6's Avatar
Re: 1969 Short Wide
Yep thats it. I think it was a pretty smart thing to do. I went and got a sheet of 18ga and half of it is rusting away in my garage.
Adam
Old 01-02-2014, 11:34 AM   #1460
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Eddie. I haven't rushed anything too much yet. This is my 4th winter on this one.....
Thanks Buck. I am trying to build as nice of a truck as I can for the cheapest price. At times it's tough but I have done pretty good up to this point. I will have to go back and upgrade things at some point, but I want to drive this thing.
Thanks. I hate rust as much as the next guy. I'm thinking this truck should last another 40 years.....
Old 01-03-2014, 03:19 PM   #1461
shearjs
shearjs's Avatar
Re: 1969 Short Wide
You're going to be driving this thing in no time! You've done a kick ass job with all your repair work.
shearjs is offline   Reply With Quote
Old 01-07-2014, 03:41 PM   #1462
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Jason. I want to be driving it as soon as I can. Winter needs to give us a break!
Old 01-07-2014, 03:47 PM   #1463
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Not much new here I have been doing some busy work. Blasting parts to put this thing together one of these days.
More:
I have been helping a little on this too:
I'm proud of my son Landen (eightiesonly) he completely rewired the harness and did most of the install by himself.
THREAD HERE
Can't wait till the day we are both cruising in our old Chevys!
Old 01-07-2014, 04:18 PM   #1464
Crash_OK
Crash_OK's Avatar
Re: 1969 Short Wide
More:
THREAD HERE
Landen did a great job... Looking forward to see more progress on yours...
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 01-07-2014, 05:49 PM   #1465
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Mark. He has learned a bunch from the swap. We are going to try to button his up today if possible. I'll be back on mine soon. Well, if it warms up a little
Old 01-07-2014, 06:30 PM   #1466
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
What is your plan for the blasted parts, powder or paint? Your son did a rally good job on the engine swap. I'll have to check out the thread.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-07-2014, 11:16 PM   #1467
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks the 5.3 swap turned out great we just drove it about 20 miles.
Runs drives and sounds like a new truck.
I have been epoxy primering all my parts. These I will paint with a semigloss single stage enamel. That is if I can get one that I like. If not I will use black base coat and a flattened clear. I'm sure a spray can would be sufficient though.
Old 01-07-2014, 11:45 PM   #1468
C10_ustacould
Re: 1969 Short Wide
How about the flat black that STP67-72 and n2billet use? It's Medallion Hot Rod Black made by Rubber Seal and every truck they have used it on looks amazing.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-08-2014, 12:25 AM   #1469
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Those are some of the first parts I sprayed. I went down to the Napa Paint store and got some "basic" reduced gloss black, single stage urethane. I only bought small amounts at a time but later figgerd it was about $400 a gallon! YIKES! That was on top of the pricey epoxy primer too. Since then I've found Van Sickle at our local tractor supply / buckaroo feed store. More like $10/qt plus some basic naptha thinner. They offer a "hardener" too, which about doubles the price but it's still a bargain. From what I can tell it's a pretty sturdy finish, perfect I think for "chassis black". I'm glad I used the spendy urethane for my wheels and rad support I guess but I'll use the tractor paint for stuff like that from here on out.
You're getting close man! I'm red with envy over here.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-08-2014, 09:28 AM   #1470
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I've seen their projects and I like that look. I think THIS is what you are talking about. I haven't found pricing for it yet.
Right now, my plan is to get all the bare metal parts epoxy primered. That will give me some time to purchase the paint. I really like the idea of a single stage 2k product. Thanks
Thanks, I will check into that stuff too. I have Tractor supply close. They have good prices on grade "8" bolts in bulk.
Old 01-16-2014, 12:16 AM   #1471
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I epoxy primered all the bare blasted parts then I ended up going with the Medallion Hot rod black that Buck recommended above.
I really like the way it sprays and it has a nice finish. I will more than likely use it for all my under hood panels too. Sorry for the crappy pics, I only had my cell camera. You get the picture
I like it
More easy work updates soon then Back to dreaded body work.
Old 01-16-2014, 12:37 AM   #1472
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
Those did turn out nice. I like the sheen they have.
Zoomin is offline   Reply With Quote
Old 01-16-2014, 12:52 AM   #1473
sduckworth13
sduckworth13's Avatar
Re: 1969 Short Wide
Sandblasted and painted parts look great Mike.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-16-2014, 02:15 AM   #1474
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1969 Short Wide
Great work Mike! Colors mean progress. Great work on your son's truck too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-16-2014, 06:43 AM   #1475
Bennett68C10
Re: 1969 Short Wide
Nice work Mike, where did you pick the Medallion Hot Rod Black up at and what did it cost you if you don't mind me asking.
Keith
66 Suburban
IG: bennett68c10
