Old 11-14-2006, 10:10 PM   #126
Hart_Rod
Hart_Rod's Avatar
Re: Project Lemon Drop: anything but stock!
Rok,
I've had the rubber o-rings on mine for 3 years and never had a problem with them. Here's what I did on my tailgate.
Hart_Rod is offline   Reply With Quote
Old 11-15-2006, 12:44 AM   #127
Rokcrln
Rokcrln's Avatar
Very nice! Give some more info on your gate holder open thingy's The owner wants rods like that but I have not even looked into it yet. Are they just fleet side bars that you installed and notched out the inner gate edge? Thanks for any info you might be willing to part with.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-15-2006, 02:19 PM   #128
Rokcrln
Rokcrln's Avatar
Now the fun begins. Roll pan does not fit as is due to the lic. plate holder and the lights are also not going to clear due to the rear bed mount as well. Then is the common problem of a rear tank in a pickup and the second to rear mount (masking tape) hitting. So once I get the steps and start on the rear tail gate openers I will start to slice and dice this bed apart and make it all fit
I am also thinking about welding up the bed so it does not need the bolts to hold it together. I think this will make the paint stage and reassembly alot easier with les chances of damage. And since this bed is electro coated rust should not be a problem. What do you step side guys have to say about this? Good/Bad or what, this is the first step bed I have delt with from this point of being brand new.
Kevin
LFD Inc.
Old 11-15-2006, 03:15 PM   #129
jugernot
Life, Be In It.....
jugernot's Avatar
Angry Re: Project Lemon Drop: anything but stock!
I will called Mar K about the license plate box problem. They said the according to the instructions for the roll pan the rear cross sill has to be modified so the license box will fit.
Note. Kevin they said the instruction for the roll pan should be taped behind a piece of foam inside the roll pan box?
These tail lights are looking like they may be a better option.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-15-2006, 04:37 PM   #130
jugernot
Life, Be In It.....
jugernot's Avatar
Here are some other pics of the tail gate support hinge thingy. I can't remember where I got them or who they belong too.
Old 11-15-2006, 04:58 PM   #131
67ChevyRedneck
67ChevyRedneck's Avatar
They belong to Putter. I "stole" his idea too....
I used the same latches too....
Lookin great so far....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-15-2006, 05:20 PM   #132
jugernot
Life, Be In It.....
jugernot's Avatar
What Truck did you get yours from?
Old 11-15-2006, 05:30 PM   #133
67ChevyRedneck
Putter actually sent me the set off of his truck! So not really sure, all I can recall is something about a late model nissan truck (the smaller ones).
I really like how they clean up the back of the truck!
Jesse James
Project "On a Dime"
Old 11-15-2006, 05:31 PM   #134
67ChevyRedneck
You also have to notch out the tailgate.... also, measure TWICE drill ONCE (It took me some time to fill that extra hole back in!)
Jesse James
Project "On a Dime"
Old 11-15-2006, 05:46 PM   #135
Hart_Rod
Hart_Rod's Avatar
Check this out:
http://mar-k.com/54-87TAILGATEWHANDLEORIGBS.pdf
http://mar-k.com/41-53TAILGATEWHANDLEORIGINALBS.pdf
Old 11-15-2006, 06:12 PM   #136
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Rod, Thanks...I was looking for that for my stepside.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-15-2006, 06:16 PM   #137
Hart_Rod
Hart_Rod's Avatar
I built mine for my 48 about 4-5 years ago. Not to long after that, Mar-K came out with their kit . So, I bought one for my 52. Actually I bought the complete bed kit with reversed tailgate. Very high quality, Mar-K does it right.
Rob
Old 11-15-2006, 08:46 PM   #138
Rokcrln
Rokcrln's Avatar
Yep it is always fun what you run accross. Thanks for all the info, I went out side after this mornings post and played with my fleet side gate abit and figuresd it all out. But hect if K-mark makes a full kit for this than that sounds like the way to go. So have any of you guys welded your step side bed together? Pro's or Con's?
Kevin
LFD Inc.
Old 11-15-2006, 09:19 PM   #139
Hart_Rod
Hart_Rod's Avatar
"So have any of you guys welded your step side bed together? Pro's or Con's?"
Kevin, I welded the one together in my 48. I really like the way it came out, a very clean look and extremely sturdy. I put a steel floor in it also, which made my decision easier. The only con I see, is if you had an accident to one of the panels, it would be harder to fix. I also welded studs on for the fenders so you don't see any bolts in the bed. Check out this link and you can click on the bed pictures:
http://www.stripmasterspor15.com/car015.html
Old 11-15-2006, 09:57 PM   #140
Hart_Rod
Hart_Rod's Avatar
Here's a picture of the Mar-K setup (minus the tubs ):
Old 11-15-2006, 10:08 PM   #141
Rokcrln
Rokcrln's Avatar
Nice Job! The main reason I am thinking about doing it is not so much to eliminate the bolts but to hold it all together while it is being painted. Jugernot has all SS hardware and he wants it this way for some added contrast to the yellow but I am worried about pulling the whole bed apart, painting everything and then getting it all back together without and damage. Plus it would make it real sturdy and rigid. I hear you on if it got in a wreck but that is what Ins. is for and damage is damage so what ever it takes to fix it is what they need to pay for. I would only stich weld it in a few not to visible areas, I am not trying to smooth it out or anything like that.
Jugernot what are your thoughts?
Kevin
LFD Inc.
Old 11-16-2006, 02:07 PM   #142
jugernot
Life, Be In It.....
jugernot's Avatar
That will not effect the installation of the wood floor, will it? If it won't welding it up is okay with me.
I will call Mar K about the tail gate check links.
Can anyone tell me what year tail light these are?
Old 11-16-2006, 02:19 PM   #143
jugernot
Life, Be In It.....
jugernot's Avatar
I called Mar K and ordered the tail gate check links.
Old 11-16-2006, 04:41 PM   #144
meathead95
computer illiterate
meathead95's Avatar
the owner of that trucks board name is firstgen try sending him a pm
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-16-2006, 06:42 PM   #145
smbrouss70
smbrouss70's Avatar
IIRC, they are 55-59 chevy truck lights. Tim Christian has them also.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-16-2006, 07:03 PM   #146
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Tim's?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-16-2006, 09:32 PM   #147
Rokcrln
Rokcrln's Avatar
Originally Posted by glock35ipsc View Post
Tim's?
That is one nice 67! I just never got used to the look of the small back window. They also made back window's in 67 right? But I love that color and the stance looks great as well.
Kevin
LFD Inc.
Old 11-17-2006, 01:00 AM   #148
smbrouss70
smbrouss70's Avatar
Tim's?
Yep, same lights just mounted lower.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-17-2006, 09:09 AM   #149
Gerwin
Gerwin's Avatar
me like a lot so far!
keep the pictures coming...
that way i can round up some ideas to do to my 69.....after i`m done with my current project
`69 C/10 350 stepside
`78 caprice 2dr coupe
Gerwin is offline   Reply With Quote
Old 11-18-2006, 03:55 PM   #150
jugernot
Life, Be In It.....
jugernot's Avatar
Thanks for all the input with the lights. I received more parts in the mail today. Should be nice cold in the cab now. My daughter was a great help she was very egar to open the boxes.
Things are moving right along, hopefully soon it will be done. HOPEFULLY!!!!!!!
