Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-30-2012, 12:05 PM   #126
cmax87v3500
cmax87v3500's Avatar
Re: How about some pics of custom stereos
Thanks! My dad and i built, and installed the whole stereo! the box is 55.5 inches wide, 4.5 deep at the top, and 6.5 at the bottom. make it as tall as you can behind your seat, that one is 15 high, but i think you could squeak another half inch out of it. you loose a click on your seat, but is still comfortable. i am actually in the process of putting a seat out of a late 90's Chevy in it which takes up more space and would put me into the steering wheel too much, so a new box is needed, and if you buy the new kenwood xr-w12f you can build a box that is 2 inches at the top, and 7 at the bottom. im going to make the one for my truck 2.25 at the top just to get that little extra cubes in it,but you could make it work. here's a pic of a diagram i made with the real small box. with the small box the new style seat can be all the way back with the top touching the cab, so i imagine if you built that box for a old style seat it would be really comfortable, like there was no box there at all. its a little low on cu ft for the subs, but you these ol standard cabs either like you to be crammed forward, with lots of boom, or completely comfortable and have a little boom. ha i believe the 2-2.5inches at the top box is the perfect ammount, with a little relief cut in the back of the box the subs i have now, kenwood xw1200f's, will fit in the 2.5 inch top box. i just got to thinking, that 7 in. may not work on the bottom with the old seat. at 6.5 i can still get the seat all the way back, the seat back just wont stay with it, it flips forward, so that may be an option. pm me if you need more help.
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
Old 05-03-2012, 08:34 PM   #127
DVD87V10
I appreciate all your help. I have a few people telling me I should go with the sub below the seat. I'm really debating now. I wish I could hear both lol
DVD87V10 is offline   Reply With Quote
Old 05-04-2012, 02:49 PM   #128
cmax87v3500
to be honest with ya, i dont know how you could put a sub under the seat, i have my kicker zx700.5 under the seat, its a pretty big amp, and if you ride in the middle your sitting on it, and im sure on the passenger side if you hit a big bump you hit it over there. as of now i just dont let people ride in the middle, and try to not hit any big bumps with someone on the passenger side. im going to fix it when i have something else to drive for a couple of days. i can see no way of fitting a sub bigger than maybe a 6 or 8 in the middle where it dips down around the transmission hump, theres no way i could fit the kenwoods under the seat. if ur willing to wait, ill be buying the new kenwood shallows in the next few weeks(hopefully) and building the smaller box at 2-2.25 at the top and 7 at the bottom and will let you know how it works out. but as of now, with the factory seat and the sub box i have, its very comfortable, im 6 foot tall, and just a big guy and i have no problems at all. id say that behind the seat is the way to go, because even if you put the subs under the seat i also dont see how you could get enough space to build a big enough box to make the subs perform good. unless they are 6 or 8's. hope this info helps
Old 05-07-2012, 10:31 PM   #129
DVD87V10
That's also what I was thinking. Is there now way to fit it right under the actual driver and passenger seat? I am also a big guy, 6'4", so I would like to be comfortable of course. I can hold out for a while so maybe you will have everything and be the guinea pig
Old 05-07-2012, 10:53 PM   #130
cmax87v3500
ive never tried under the seat, so i dont know but i do know that the box with the dimension of 2 at the top and 7 at the bottom will fit behind the new seat all the way back. so if you measured the bottom depth with your seat all the way back, and could settle for a good set of tens, it would probably fit behind the old seat like there is nothing there. as of now i have other things for college and just paying for gas with the 454 in ol grey so i sadly inmagine it will be quite a while before i can afford the new subs maybe not though. i have too many projects, evh frankenstein guitar, my truck, guns, and weight lifting, its all just too much and too expensive
Old 05-07-2012, 11:04 PM   #131
DVD87V10
Maybe I will have to do a little more research. Good to know about the seat and dimensions though. I feel you on the money issue though. Paying my damn college now myself and now the new truck I'm trying to fix up
Old 01-03-2013, 01:31 PM   #132
cajondrummer89
cajondrummer89's Avatar
Here's a custom box we build for my dad's '71 C10. I'll be doing something very similar for my '77 K10. We wanted to make it fit as well as possible with the curve of the back wall just under the window. It's all MDF for the center box. The sides we made out of MDF and fiberglass. The 6x9's are recessed into the box to be covered with some hardware cloth (still looking for the right kind). It'll be upholstered soon in a black marine type vinyl with a very low grain.
The 6x9's are temporary. Hopefully we'll get some new ones in there this summer. It sounds awesome though! I couldn't be more happy with the way it turned out. Turned out nice for both sound quality AND volume!
If you notice the amp is mounted IN the box. Same idea as the 6x9's there. It'll be covered with some hardware cloth later on. There's a 12v DC fan down below which runs off the remote power to the amp. It pulls cool air in and pushes warm air out the vent holes I left in the top of the box. It pushes air into the cavity under the back window and the air disburses from there. It runs nice and cool!
cajondrummer89 is offline   Reply With Quote
Old 01-08-2013, 06:15 PM   #133
81Scottsdale520
81Scottsdale520's Avatar
Originally Posted by 1986swb View Post
Just finished installing the Infinity Reference 6"x9" rear speakers and Pioneer subwoofer and the two Kicker amps. Front speakers are Infinity Reference 3.5" that are mounted in the stock dash area. A new Pioneer head unit also installed with a new Optima battery. Lots of grounding to deter engine whine. Here are a few pics of the install. More info. and pics coming soon.
did you build those corner speaker housings or did you buy them somewhere? if you bought them where did you get em?
-Ricky
81Scottsdale520 is offline   Reply With Quote
Old 02-13-2013, 03:13 PM   #134
TexasSteve
TexasSteve's Avatar
A vfiend of mines 2001 Tahoe & his stealth subs. Can't recall if they are 12"s or 15"s, but there are 2 Alpine Type Rs. Can you find them?
TexasSteve is offline   Reply With Quote
Old 02-14-2013, 01:49 AM   #135
Devillusion
Devillusion's Avatar
very nicely done.....gorgeous install.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 02-14-2013, 12:13 PM   #136
TexasSteve
TexasSteve's Avatar
And here is how they were hidden:
And yes...The speakers are off center. That was due to obstruction below the floor. I think it was the fuel lines or something that weren't simple o move out of the way.
The Lexan widow is 3/4" thick so not much change of damaging the speakers below by carrying anything on top of them.
Old 02-19-2013, 03:11 PM   #137
kikkegek
kikkegek's Avatar
that is one supernice sick setup....wow!
kikkegek is offline   Reply With Quote
Old 02-20-2013, 10:10 PM   #138
1986swb
1986swb's Avatar
-Ricky
I bought them from member Bigbock73. CNC cut and perfect bends. And perfect fit in the cab corners.
Check him out at http://67-72chevytrucks.com/vboard/s....php?p=5581342
You won't be disappointed.
1986 GMC Sierra Classic C1500 SWB
2006 GMC Yukon Denali
http://67-72chevytrucks.com/vboard/a...hp?albumid=977
1986swb is offline   Reply With Quote
Old 03-13-2013, 04:19 PM   #139
scrappy
scrappy's Avatar
This isn't a super custom install by any means but it's something that could easily be done in any vehicle. I wanted a new head unit in my 91 vw gti with cd player & usb hook up for my i-pod but didn't want the usb connector on the face of the unit because I didn't like the idea of having cord's hanging down from my dash. I got a fairly nice & inexpensive alpine unit that had a usb cord adapter on the back of it than I went down to norvac(a computer parts store) & got a 6" usb adapter cord for a pc hard drive that has 2 screw flanges on it for screwing it to the hard drive frame. I removed the glove box insert from my car & found an out of the way place to cut a rectangle hole for the male usb cord, drilled 2 small holes on each side of the rectangle hole & screwd the usb adapter to the top back side of the glove box insert. Now I can plug my i-pod into the glove box & keep it out of sight. By the way, the alpine unit I have controls the i-pod so I don't have to change songs on the i-pod itself. It's done from the head unit:
scrappy is offline   Reply With Quote
Old 06-10-2013, 02:45 AM   #140
kimike2
Everything is good except the in-dash dvd. I got this one. $328. 7 inch In-dash Single Din GPS Navigation Car DVD Player with Detachable Panel. It goes well with my car. http://www.justcardvd.com/products/I...C7inch%29.html
kimike2 is offline   Reply With Quote
Old 11-07-2013, 06:39 PM   #141
57chevyman
57chevyman's Avatar
Kenwood makes a powered subwoofer that's meant to fit under a seat. I have one in my truck, it sounds really good
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 12-05-2013, 06:11 PM   #142
K10 STEPSIDE
K10 STEPSIDE's Avatar
I am pretty happy with the sound from my truck. I have 2 12" shallows, 2 6" components in the back and 2 6" coaxials under the dash, with an amp under the passenger seat for the speakers and another behind the middle for for the subs. The best part is I can still fit 3 people. I moved the gas tank out back, and put in newer seats ( they take up more room so they don't help add space for the box). then built two boxes and a section to hold other electronics. I'm 6'2 and don't feel short on room.
I know the hyfonics is a cheapy but it works good and if I didn't stop somewhere the truck would have more in it than I make.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 01-06-2014, 08:37 PM   #143
btd71
very nice beatcoaster! i have a 68 that i wanted to put a system in and wasnt sure how to go about it without relocating the gas tank. very good job!!
btd71 is offline   Reply With Quote
Old 01-07-2014, 02:44 PM   #144
btd71
heres some shots of a system i installed in a 92 SWB, 4800 watts, standard cab, 170DB!! enjoy!! 200 amp alternator, 2 optima yellow top batteries, kenwood excellon head unit and clarion EQ
Old 03-28-2014, 02:40 PM   #145
unique760
Originally Posted by AceX View Post
Not sure if this is the right area or not. I wanted to see custom stereo installs from all the different year trucks and figured this was the best place to post.
Please post Make/Model/Year/Stereo Specs
Mine:
Chevrolet/Silverado/1985
Pioneer DEH880-PRS Headunit
MB Quart 5.25" Premium Components in the kick panels; MB Quart 6.5" Q-series components in the doors
10" Pioneer shallow mount subwoofers (2); ARC Audio FD4100 Amplifier hidden under bowtie (which is a removable panel)
Still to come is an ARC Audio FD600.1 Amplifier and Kinetik Cap Killer battery.
unique760 is offline   Reply With Quote
Old 03-31-2014, 11:33 AM   #146
Fan2zee
Fan2zee's Avatar
Originally Posted by unique760 View Post
Looks Awesome!
87' R10
Fan2zee is offline   Reply With Quote
Old 04-01-2014, 06:56 PM   #147
unique760
Originally Posted by jimmydean View Post
Got my center channel done, just need to wrap it in screen and paint the dash.
how are You mounting it? are u going to drill through the dash or is it being held from a different place
Old 04-01-2014, 11:32 PM   #148
ca90ss
Originally Posted by btd71 View Post
170DB!!
If that's a 170db stereo I'll eat your dirty underwear.
ca90ss is offline   Reply With Quote
Old 04-02-2014, 12:08 AM   #149
bagged74
its just $$$$$
bagged74's Avatar
Lol. I agree
bagged74 is offline   Reply With Quote
Old 04-15-2014, 04:24 PM   #150
gramps77
especially with that kind of wattage and ONE 200 amp alternator.
Theres a Tahoe out in the parking lot at work RIGHT now with 4 320 amp alternators, 4 15s and a WHOLE bunch more speakers than in that truck and HE'S not hitting 170.
gramps77 is offline   Reply With Quote
