12-01-2010, 12:47 PM | #126 |
Re: Post Your Straight Six Pics!
Take the plug with you so you get the right size. Any auto parts store should have one.
I know Napa does. |
12-01-2010, 03:33 PM | #127 |
thanks. bought the hose, fitting and clamps. brakes work great now!
12-01-2010, 03:44 PM | #128 |
Made2drag - As the thread states....You gotta take some pics!
Lets see the setup with the new booster! |
01-21-2011, 07:17 PM | #129 |
I am pulling my 230 out of my 65 now. Where do you guys recommend placing the chain?
01-21-2011, 08:30 PM | #130 |
you can try replacing the chain but I think they are gears in there.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
01-21-2011, 09:26 PM | #131 |
I usually pull the engine with the intake and exhaust off. I use one of the rear intake studs on the left rear and there is a pad on the right front with two bolt holes.
The heads usually had two short locating pins, one on each end, two studs, one in the third hole in from each end and the rest were just bolts. I have pulled the pins and installed studs in every hole. Eight studs in all, instead of just the original two. It makes it a lot easier to replace the gasket, intake and exhaust at the same time.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 01-21-2011 at 09:27 PM. |
01-21-2011, 11:51 PM | #132 |
Thanks for the info. I got it out.
Posted via Mobile Device |
01-22-2011, 12:07 AM | #133 |
Second Chance Program
Subscribed so i can fond more on the hybrid head motor!
01-22-2011, 02:10 AM | #134 |
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
01-22-2011, 05:31 AM | #135 |
If you do decide to R&R the timing gears go with metal. Plastic gears could suck, even on a 230.
05-09-2011, 01:42 AM | #136 |
cleaning/repainting mine! here's before, I'll post after shortly I hope. Still peicing it back together!
Don't let this thread die! I love inline sixes!!!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
05-09-2011, 02:38 PM | #137 |
Ok, heres mine.....
I'm gonna watch to see how yours does. Might try it myself. |
05-09-2011, 03:40 PM | #138 | |
Full story at my web page : http://www.autoblueprint.com/1961_pa...61_apache.html |
05-09-2011, 10:46 PM | #139 |
Hey 68 IRON-what carb is that you have? I have the same one, but I don't think it's stock.
At least, it's different from every other 1bbl I have laying around here.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
05-11-2011, 10:09 AM | #140 |
I'll check it out and see if I can get a number off it. The truck came with maintenance records back to the original sale.
05-12-2011, 11:29 AM | #141 |
Pritch, haven't check the paper work that came with truck but on the front bowl it says Rochester Monojet made in USA GM
05-12-2011, 09:18 PM | #142 |
My 292, don't know if I should put this in my Jimmy or rebuild the 250 it came with.
The 250 might get a little weak driving all my accessories
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
05-12-2011, 09:29 PM | #143 | |
My carb has those same markings, but I haven't taken it off yet to see if there are others somewhere else. I think I'm running a tad rich so I'd like to find out about tuning it. I only see 1 screw to mess with though, except for the idle adjust, so how tough could it be? These seem to sit up a little higher than the stock carbs, and the throttle linkage geometry seems a little off, on mine anyway. Do you notice that too?
05-12-2011, 10:10 PM | #144 |
Cruzin
Great thread guys, i love the inlines now i've had two and sadly they were pulled for a small block i still have one i plan on useing for a project.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
05-13-2011, 02:05 AM | #145 | |
The 292 in a K/ series truck requires a special [diagonal] crossmember.
05-13-2011, 12:28 PM | #146 | |
No record of carb change. But I can tell ya the dealer was dealing with maniflold leaks early in its service.....like I am now |
05-13-2011, 01:21 PM | #147 | |
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-13-2011, 06:38 PM | #148 | |
Tot Roddin'
That will be nice running in something.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-13-2011, 08:43 PM | #149 |
INLINE SIX'S ALL THE WAY
Some progress is better then no progress |
05-14-2011, 11:13 AM | #150 |
That setup is gonna be fun for sure....nice lookin' build!
