Old 05-29-2017, 09:05 PM   #126
dennislbrooks
dennislbrooks's Avatar
Re: 67-72 BigBlock 4x4s! Pos pics info here.
One more to add.
http://67-72chevytrucks.com/vboard/s...d.php?t=615038
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 05-30-2017, 11:04 AM   #127
hotsam
hotsam's Avatar
Well, ill add mine here.. its not detailed yet so ill only post a couple pics but I love the outcome... 1972 swb 4x4....was orig. 350 3 spd on column, now 454 with sm465 4 spd
hotsam is offline   Reply With Quote
Old 06-05-2017, 02:06 PM   #128
jbarron
Anybody know off hand if the K5 blazer frame is the same as the swb truck frame.
Body/bed mounts in the same locations?
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 06-06-2017, 07:37 AM   #129
hotsam
hotsam's Avatar
They are different. The wheelbase is shorter
Old 06-12-2017, 10:02 AM   #130
Luvinit
Luvinit's Avatar
Just got my 72 Cheyenne longhorn 4x4 402 running. A quick question while I may here I have to add about a 3 inch block under the rear spring to level the truck how do I find the angle to cut it at to keep the driveshaft straight.
1972 Cheyenne Longhorn k20, 402, A/C
Luvinit is offline   Reply With Quote
Old 06-12-2017, 04:12 PM   #131
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Luvinit, very nice truck. I always like to see more 4x4 swapped longhorns! On your rear block question, you need to see what your pinion angle is to determine that. You don't want it to high or low. Around 3* up should work. I can't remember what stock is but I have a HO52 in a 72 I can check.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-12-2017, 05:10 PM   #132
Luvinit
Luvinit's Avatar
Thanks for that I'll do trial and error to get it close.
Old 06-11-2018, 12:16 PM   #133
71veronica
71veronica's Avatar
[QUOTE=Gobuffalo;6779045]I guess I should pay attention to what I'm typing!
The right header comes out at a 45* angle. The left side points straight down. When I was done, I had I extra 90* bend and was short 1 45.
The big block stands won't bolt onto the factory small block 4x4 crossmember without modifying them.
I used all small block mounts and cross members to bolt my big block, TH400/NP205 in. I used the forward most mounting holes in the frame (I compared a 2 wheel drive, big block truck frame to mine). Even though I moved the engine forward to the factory big block position, I had to move the trans cross member back 1". Which means the t-case shifter didn't line up in the original hole, so it got a "custom" bend.[/QUOTE. Are you running a mechanical fan or electric?
71veronica is offline   Reply With Quote
