Old 09-09-2009, 11:01 PM   #126
joe231
joe231's Avatar
Re: 1964 Suburban Pics
Originally Posted by Woogeroo View Post
I was wondering when the local pizza parlor was going to call and demand that protrash return their baking pans.
-W
CHEVY ONLY
Old 09-10-2009, 07:03 PM   #127
protrash64
Resistance is Futile
protrash64's Avatar
Originally Posted by srsummers View Post
What did you do with the Centerlines?
Did you get my PM a while back?
Scott
I put them in my laundry room. Yes I did get the PM and totally forgot to respond......apologies. I must have started reading some other stuff and forgotten.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-10-2009, 11:24 PM   #128
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
It's funny how that happens.
Alan's Classic is offline   Reply With Quote
Old 09-13-2009, 01:37 AM   #129
protrash64
protrash64's Avatar
I'm still working on cleaning up the airride. I was planning on slamming this out, but as it usually goes I come up with some ideas and have to see them thru. I work with all types of electrical equipment at work and it gave me a cool idea to help make this system nicer.
The first pic is a couple electrical items. There is a buss and 2 ground bars. You can get this stuff at Home Depot. The ground bars are Square D. I mounted all this underneath the truck so I can neatly route my switch legs to the valves. It also allows me to take it apart with out messing with all the 'control' side of the system.
The other pics are the items mounted and the switches terminated on the buss. I still have to put in my other 2 valve assemblies and then ground out the valves in the bars on the side of the frame. I wouldn't use this stuff on a vehicle driven daily or in crappy weather....but this truck isnt.
Check it!!!
Old 09-13-2009, 12:39 PM   #130
protrash64
protrash64's Avatar
Just another teaser pic for all of ya interested.......
Old 09-13-2009, 02:49 PM   #131
joe231
joe231's Avatar
Nice!!!!
I can't wait to see it!!
CHEVY ONLY
Old 09-13-2009, 02:57 PM   #132
creep
Registered Loser
creep's Avatar
Ugh, that is absolutly hideous! You should just park that ugly beast in my backyard and forget about it. Be sure to leave the keys in it though
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 09-13-2009, 10:49 PM   #133
protrash64
protrash64's Avatar
Sure, no problem.........
Here's a pic of the valves wired up....ready to go as soon as I plumb the rear bags and button some stuff down. The junction block and ground bars worked really well. You can see the ground bar on the drivers side rail with the valve grounds lugged in the top. I used the mount bolt to ground the tailights and the air compressor; ditto for the other side.
Old 09-13-2009, 11:01 PM   #134
joe231
joe231's Avatar
Right on Jeff!
nice work
did you guys get a break from the heat?
CHEVY ONLY
Old 09-13-2009, 11:42 PM   #135
protrash64
protrash64's Avatar
Originally Posted by joe231 View Post
Right on Jeff!
nice work
Thanx man! Yeah, a little bit better and not a bad August IMO. It's been around 80* in the morning and peaking at 100* give or take a bit. I know it sounds hot, but it's a relief from what was going on. I think anything feels cool after being on tile roofs all day.
Old 09-14-2009, 08:16 AM   #136
joe231
joe231's Avatar
CHEVY ONLY
Old 09-14-2009, 11:02 AM   #137
creep
Registered Loser
creep's Avatar
I do commercial/industrial roofing and my friends think I'm exaggerating when I tell them just how much hotter it is on a roof.
Old 09-14-2009, 02:00 PM   #138
MacAttack
283 Drama Queen
MacAttack's Avatar
Beautiful valve plumbing, electrical connector and engineering work!
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-14-2009, 10:30 PM   #139
protrash64
protrash64's Avatar
It is, cuz yer getting cooked on both sides!!
Thank you!.....spent about 2 hours laying under the truck trying to come up with ideas over Labor Day weekend. I almost fell asleep......but I did finally come up with a nice system and I'm very happy with the result( sounds like a plastic surgeon....)
Old 09-15-2009, 10:16 AM   #140
MacAttack
283 Drama Queen
MacAttack's Avatar
This one's most definitely not going to turn out to be a Frankenstein.
Old 09-15-2009, 10:47 AM   #141
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
the wiring looks good. But one thing I would change if you can is the pressure switch from the bottom of the tanks to the top if you can. you just dont want any water in the tank to mess it up. Maybe get a bung and weld it to the tank so you can move it. Do you have a draincock?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-15-2009, 06:26 PM   #142
protrash64
protrash64's Avatar
I didnt like that either. I thought about putting it on the end but its buried in the frame rail. I dont have a drain. It's dry out here and I dont think that much water builds up. My last tank didnt have anything in it when removed. I mostly was worried about road debris ripping it off the tank even though its really high up in there.
If I mounted the tank with that port on top there was not enough clearance for the switch. I'm not welding on it 'cuz its aluminum.
Old 09-15-2009, 09:27 PM   #143
ruffrida2005
maybe you could get someone to do it for you. It would be well worth it in the long run, the bungs dont cost much, and I'm sure getting it welded would only be like $20-30.
I thought we wouldn't ever get water in ours in Iraq either but we always had to drain the tanks because of it. I was just commenting because I saw a thread from Viar stating that, and the tank needs to be tilted towards the draincock.
Paul
Old 09-15-2009, 10:30 PM   #144
protrash64
protrash64's Avatar
It bugs me that you brought this up.....I was laying under there thinking about this stuff and should have done it. I think I will probably move it to the side. The tank has 4 ports on the ends and I used the ones that lined up for the compressors the best. I will pick whatever side looks like it will work with the wiring and put it there. I appreciate the heads up....
Old 09-15-2009, 11:25 PM   #145
ruffrida2005
Just trying to give some meds for the headach you would have later down the road. It's amazing how much we learn every day on these sites.
Paul
Old 09-20-2009, 09:56 PM   #146
protrash64
protrash64's Avatar
Small update: moved the pressure switch to the side of the tank and it was a breeze. No pics, but now ruffrida can sleep at nite.
Worked on another creation for my truck as the juices are flowing now. I have an air gauge to add and a trans temp gauge that I havent installed. I thought I mite as well get both of them in there right now. Started with some exhaust reducers to fit the gauges and a piece of angle iron I found somewhere. Got all the pieces roughed out and will tack them together at a later date. I will match them to the tach with some chrome paint, which I just saw my buddy use and couldnt tell where it was. Here are the pics.....
Old 09-20-2009, 10:02 PM   #147
joe231
joe231's Avatar
NICE work Man!!!
CHEVY ONLY
Old 09-20-2009, 10:12 PM   #148
protrash64
protrash64's Avatar
.....thanks!!! Not bad for another 'ghetto-garage' creation.
Old 09-21-2009, 12:23 AM   #149
ruffrida2005
I'm glad that I can atleast sleep now, looking good.
Paul
Old 09-21-2009, 08:16 AM   #150
joe231
joe231's Avatar
CHEVY ONLY
