10-27-2013, 11:35 PM | #126 |
Post Whore
Re: Pristine engine bay in '66 Chevy C10 with 327 & factory A/C
Stock 1964 292....painted blue.....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-28-2013, 01:02 AM | #127 |
Here's my 1965 Fremont built orig paint/sticker 283. Never seen a drivers side valve cover sticker before.
10-28-2013, 01:06 AM | #128 |
Maybe my valve covers are on backwards, my decal is on the one with the 2 clips to hold the wire.
10-28-2013, 01:17 AM | #129 |
I don't remember seeing one on the drivers side of the pickups at Lambrechts. My photos are everywhere but short of the center lower of the valve cover on the two 283 V8 65's at Pierce. Ask me about them not having 2 alternator braces, using a tower clamp on the one 3/4" water pump end fitting only, or the hose clamp positions and the heater hose markings and I can document that. Even have the pull back spring picture from the blue 65 but not the angle for a possible decal. I honestly have not seen one used on the drivers side of a factory line installed V8 truck engine but the cars did. Someone must have some shots of the Lambrecht valve DS cover.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
10-28-2013, 01:19 AM | #130 |
The valve cover with the 2 tabs and decal is installed on the passenger side on a pickup. The wire crosses over behind the thermostat housing and onto the temp sender behind the oil fill tube.
10-28-2013, 01:38 AM | #131 |
This is some shots from Pierce. Second picture shows the temp wire running down the passenger side held by the two tabs and then across the manifold behind thermostat.
10-28-2013, 09:13 AM | #132 |
My valve covers are on backwards then, info like this is great, thx. Although with my AC bracket you won't be able to see it.
10-28-2013, 10:01 AM | #133 |
My engine builder had installed the valve covers backwords too and I noticed it while I was painting the engine. So I had to stop and change that back. I thought the same thing about the AC compressor hogging up the view of the passenger side decal!
10-28-2013, 02:31 PM | #134 |
Yup. Mine has the decal on the passenger side, too. Never seen a Hi Torque decal on the drivers side.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
02-06-2015, 01:34 AM | #135 | |
02-06-2015, 01:51 AM | #136 | |
02-06-2015, 03:05 PM | #137 |
I just read thru this thread and noticed that single and double alternator adjusting brackets were brought up.
Last year I bought P/S brackets, pulleys and alt. brackets from Lyle in Bonners Ferry. He stated that they were off a 283, 1967 Chev car. The alt. brackets were double, so I asked him about it and was told that he had seen several that were double. A friend of mine thought that if it came with the high output alt. it was double. Can anyone confirm this ? |
02-06-2015, 03:53 PM | #138 |
I have several of the early Impalas around here and most if not all had the double bracket 65 66 67 68 , same as the trucks. Its guite common to see regardless of what alternator was given. I believe they were having trouble with one brace cracking so they doubled them up.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-06-2015, 04:11 PM | #139 | |
What color and paint type did you use on the Transmission? That looks really good.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
02-06-2015, 07:20 PM | #140 | |
It's one of the closest looking paints to bare cast iron that I've found. But it's just a rattle can spray paint so it's not super durable. It seems to hold up okay if used over a good primer though. |
02-07-2015, 04:30 PM | #141 |
So with all the talk about green and blue I guess there is no doubt about the grey color for 283's...I bought a built 283 from a car restorer who worked out of a house I purchased.
He said it was out of a 50's corvette and built by a well know engine builder out of Phoenix who's name I have forgotten. Are corvette 283's grey as well? I stupidly waited till I moved in to verify that I had a corvette engine since he seemed very reputable. Although it had Corvette valve covers the heads are not from a corvette I quickly determined. I am now holding a little hope up that the block may be from a corvette but research brings up nothing. He included a Corvette transmission too but I haven't confirmed that its corvette either which would be nice. Anybody got a quick way of determining if I got a Chevy or Corvette block if there is a difference? The block casting numbers are 8896948, I also found G216 above that and a CONV-1...
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
02-07-2015, 07:34 PM | #142 |
Anyone know if the 327 and the 283 valve covers are the same size/ interchangeable?
02-07-2015, 08:14 PM | #143 | ||
I'm not a Corvette expert, but I think the V8 Vette engines were painted the same as passenger car engines ... typically Chevy orange.
Unless the deck surface of the block was machined down during the rebuild, there should be some letters & numbers stamped into the deck surface just ahead of the passenger side cylinder head. Those tell you the engine assembly plant, assembly date, and some information about the original application. Quote:
And I'm pretty sure all of the small block Chevy V8 valve covers will physically interchange from 1960 up until they went to the center bolt style in the later 80's. The earlier 55-59 valve covers have a staggered bolt pattern that will only fit the 55-59 heads though. |
02-07-2015, 09:59 PM | #144 |
Yes, when all I could find for 283's casting numbers started with a "3" I went out and double checked to make sure it was an "8"...it is definitely and "8", Identical to the other 8's in the sequence...that is why I was stymied. It is 7 numbers instead of 6 or 8 if that identifies a block of years.
You might want to double check the casting number ... I think the 1st digit might be a 3 instead of an 8, making it 3896948. If so, that (according to mortec.com) corresponds to a 1966 or 1967 283. And I believe the G216 is a date code ... July 21, 1966.
02-08-2015, 02:04 PM | #145 |
no sbc block in all the listings none started with a #-8
1961 chevy K10 my build is------------61K10 build |
02-08-2015, 02:49 PM | #146 |
Here is a shot...It looks like an 8 but as I rubbed my fingers across the first 8 there is a slight indentation in the middle of the raise number so I guess it is a three after all. Bummer, This means I got took by this builder guy.
Another bummer is that while I was inspecting the block I found that I have a leak in my roof just above the corner of the garage where I have this engine stored and has been dripping on the engine for a couple of years, so the whole thing may be toast at this point.
09-30-2017, 01:36 PM | #147 |
Old thread, but, still open, has anyone came up with a correct unique paint formula for the 327, or do we still have to choose between the Ford Green or the Detroit Diesel green?
09-30-2017, 01:40 PM | #148 | |
Rollin' Old Skool
http://67-72chevytrucks.com/vboard/s...d.php?t=682554
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
09-30-2017, 04:25 PM | #149 | |
09-30-2017, 05:02 PM | #150 |
Rollin' Old Skool
During my research, nowhere have I seen anybody that has the original formula. His pics are messed up, but he had his original paint matched. It's the closest I think anybody will get. After a lengthy back & forth, I was finally able to get a match to his paint. He said there was no formula info on the can he used for the repaint, so it had to be matched again at the paint shop. My resto guy has my quart, but the engine hasn't been painted yet. If he would chime back in & fix the pics, it would be a great benefit to folks!
His engine original paint & repaint is the best representation I've seen. That's why I was so adamant in trying to duplicate what he achieved.
