Old 04-15-2010, 04:42 PM   #126
wholio
wholio's Avatar
Re: Project 50th C5 Blazer
Originally Posted by Twisted78SS View Post
I do, it was the one we painted some silver over.
If you look over these pic, you can see one of the original holes lined up perfect
I believe it was the middle hole of the three on the frame. I can go a take a cloer look if you need me to.
Hope this helps a bit
Drew
thanks bro, ok well here's the thing i took the suspension off of a 1967 c10 like the front cross member and the rear coil suspension , and im in the middle of installing it on my 1969 k5 blazer 4x4 frame to convert it to 2wd, well i keep measuring and it keeps making me land on the first hole not the middle hole, im thinking i measured wrong maybe from the front cross member
but idk im someone stuck on this step, the other thing is home of my homeboys already drilled the front crossmember holes =/ he said hes is 100% sure he measured right but i dont think he did, but yeaha if i was to move the trailin arm crossmemeber to the middlehole i wouldnt come close to a 104 wheel base (i measure front the middle of the rear axle to the from crossmember like the back)
wholio is offline   Reply With Quote
Old 04-15-2010, 04:58 PM   #127
wholio
wholio's Avatar
heres some pictures to better describe what im talking bout, the pictures show the from cross member mounted to a persistent hole on my 1969 frame and they also show the trailing arm cross member mounted to the first hole as i stated before, and it shows where the rear axle would be if bolted down to the first hole on the stock bump stop on the 4x4 frame...http://67-72chevytrucks.com/vboard/i...vil.gif:smoke:
Old 04-15-2010, 05:13 PM   #128
wholio
wholio's Avatar
i attached the wrong picture for the front hole
heres the right ones
Old 04-19-2010, 12:43 PM   #129
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Well, here is what I will do,
I'll make some measurements on my frame and post them here. It will be a day or two since I have some work things going on the first half of the week. Hopefully it will clear up your questions and concerns, and mine too!
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-20-2010, 02:09 PM   #130
wholio
wholio's Avatar
thanks bro
nice looking out
Old 08-31-2010, 10:31 PM   #131
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Updates?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-01-2010, 12:36 PM   #132
Twisted78SS
Wide n'Low
Some updates finally..
I ordered the rest of my suspension components.. I got the Accuair goodies from Jason and some of it has already arrived. (pics soon) I also sourced all the parts for my Tach, Vac, Speed Warning, Choke Delete dash. The Choke Delete plate came in on Monday after waiting on backorder since April. I guess since the original source being used dried up, they took it upon themselves to produce new one's on their own. I'll add pictures of it tonight. My priority changed a bit over the past few months. My son is nearing driving age, and has twisted my arm to build him a 68 SWB. I had just bought a second 2wd Blazer for him in the spring, and had been working on it a little but he changed his mind. anyway, that has put the project off for some time. I also had engine issues on my 78, so it has been in the shop getting an engine swap. It's almost done, and that will free up a bay to get the tub off the frame and allow me to work on the suspension mock up and fitments. I'm itching to get back on this thing.....
pics to follow as I unpack more goodies..
Air Force Retired
Old 09-01-2010, 07:55 PM   #133
VA72C10
VA72C10
VA72C10's Avatar
cool! Looking forward to the updates!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-01-2010, 11:08 PM   #134
Twisted78SS
Wide n'Low
Here are the Choke Delete plates
Too many shadows but you get the idea
Time to unpack some Accuair goodies!
Air Force Retired
Old 09-02-2010, 09:41 AM   #135
smbrouss70
smbrouss70's Avatar
Where did the choke delete come from?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-02-2010, 11:14 PM   #136
Twisted78SS
Wide n'Low
Here is the link
America Classic Truck Parts part # CKH7
http://www.americanclassic.com/asp/d...ype=to&exyear=
Air Force Retired
Old 09-03-2010, 09:06 AM   #137
smbrouss70
smbrouss70's Avatar
Thanks!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-20-2010, 11:53 PM   #138
Twisted78SS
Wide n'Low
Got the remaining parts in from Accuair, but of course I can't seem to find any batteries for my camera. I'll get things posted ASAP. Seems what free time I have has been to work on Project Zachamachi..formerly Calico. my sons 68 daily driver project. We have until February to get it on the road when he gets his license.
Lots to do on it as it started with just the frame..
Air Force Retired
Old 09-21-2010, 12:09 AM   #139
VA72C10
VA72C10
VA72C10's Avatar
Old 12-11-2010, 03:26 PM   #140
67chevy1series
67chevy1series's Avatar
well any updates
67chevy1series is offline   Reply With Quote
Old 09-03-2011, 06:47 AM   #141
smbrouss70
smbrouss70's Avatar
Have you made any progress on this one lately?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-03-2011, 02:25 PM   #142
HarrolLS1
HarrolLS1's Avatar
Originally Posted by 67_ShortFleet View Post
I like that color combo also. Ever since I found a picture of the crew cab with those colors I have liked it.
Do you know where a guy could find more pictures of this truck. The link does not work. Is the magazine no longer published? I wish I could see that issue.
Thanks Matt
Try this link to the pdf of the article:
http://www.2heeldrive.com/brochures/...dWhite68_2.pdf
Too much goofing off on a Saturday... I should be out in the garage
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline   Reply With Quote
