#126 |
dazed and confused
Re: 71 c10 Dropmembered Driver
Looks great!
members met: redbaron69, billsbowtie,nc67 |
#127 |
any updates?
#128 |
truck looks pretty sweet
Jay Barrhead,Alberta,Canada 1967 GMC 400sb Porterbuilt stage 2 front and rear suspension ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=419519 |
#129 |
Thanks guys! No updates yet. I'm getting ready to swap out the rack to power and I'm gonna put drop spindles on the front to get it lay out the rest of the way. I will be sure to post pics when I make some progress.
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 |
#130 |
67-72 parts collector,…
![]() Join Date: Nov 2002
You didn't like the manual rack with the Dropmember?
#131 |
I think its because he works to hard and doesn't have any strength left at the end of the day to drive home.
64 C10 Dropmember.... Sold 79 C10 Dropmember 97 Dually Airride (Shop Truck) |
#132 |
I love the way it feels on the highway but with a big block and 255 tires its a chore to move in parking lots. I have driven one with manual rack, small block and a 225 tire and it steers a lot nicer. I'm going to try to reduce the pressure on the pump to get rid of the twitchy feel with the power rack so I have the best of both worlds.
#133 |
67cheby
![]() Join Date: Sep 2008
how do you plan on reducing the pressure on the pump ??
#134 |
These are only for KRC pumps but some of the other vendors sell different sizes for the more common pumps. The are basically fittings with different size holes for the pressure side of the pump.
http://www.krcpower.com/flowvalves.html This is from detroit speed I'm not sure if some of the site supporters have them available also but its for the more common gm pumps. http://www.detroitspeed.com/1967-196...trng-vlve.html
#135 |
67cheby
thanks for the information i am going to order one today, i hate it when the power steering feels twitchy like that
#136 |
![]() Join Date: May 2007
I have a different question. I visited the RPM web site and didn't see a show schedule or anything about if you have a open house.
I am jealous of your dream job.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#137 |
Thanks! It's a lot of hard work and long hours but it's rewarding. The shows list should be up soon. We do most of the good guys shows on the east coast and some in the midwest. As far as an open house we usually don't have one but if you are ever in town stop by, we will be more than happy to show you around. On a side note your dually looks a lot like our old shop dually but I know it's not. This pic is when we blew the first motor on the way home from charlotte hauling a 48' trailer.
#138 |
Anything new?
#139 |
Nothing new.. I got side tracked on my Tundra project but now that its done I hope to start back on it.
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 Last edited by 5windowpickup; 08-13-2011 at 01:02 AM. |
#140 |
![]() Join Date: Nov 2008
anything new on the truck
#141 |
Not much to update. I'm in the middle of swapping to power steering thats about it.
On a side note I'm kicking myself for missing your suburban... that would've been a perfect start for me.
#142 |
Since I haven't had much info to share lately here's a few things I had to switch out when going from manual to power steering with the dropmember.
Rack: pretty obvious but I used a power, quick ratio out of a 90 mustang GT Steering Joint: 3/4-36 spline ... manual rack is 9/16-18 spline Rack fittings: 14mm-1.5 O-ring to 6AN 16mm-1.5 O-ring to 6AN Link to fittings from speedway motors: http://www.speedwaymotors.com/AN6-Fi...nion,7489.html Lines: Pressure side has to be high pressure.. either 6AN teflon or a crimp style hydraulic hose Return side can be a standard 6AN or rubber hose Pump: I used the stock pump from the truck big block set up with the remote resivore. I also got a pressure reducer valve to slow down the flow from the GM pump to the ford rack. This takes away the twitchy feeling that you sometimes get with this combo. I will post up some pics when I get it all together and it should explain my ramblings a little better.
#143 |
One thing to look out for... just confirm that the ports on the rack are in deed metric. The 79-93 rack housing should be a standard thread. The metric fitting will screw in, but won't seat properly on the pressure side.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#144 | |
Posted via Mobile Device |
#145 | |
I'm probably going to find out the hard way I'm wrong but I will let you know how it works out.
#146 | |
#147 |
I have a question. did you have to do anything to the rear crossmember drive line? what did u do with the exhaust? thanks...
#148 | |
#149 |
low n' slo
![]() Join Date: Mar 2009
ttt...anything new on this one?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#150 |
Last I heard he was working on the Hayden modification...
![]() Posted via Mobile Device
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
