Old 11-12-2010, 01:07 AM   #126
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1972 Cheyenne Restoration
Nice progress! The truck is looking good! Just an FYI on those rivets, I don't care what rivets were in there when you removed them, if you don't put rosette style back in there, you will regret it later. They all came with them from the factory. If they were plain old rivets, someone has had the tag off before you acquired the truck. I know where you can get replacements and I will send you a PM shortly.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-15-2010, 11:31 PM   #127
CUSHE63
CUSHE63's Avatar
More pics...
CUSHE63 is offline   Reply With Quote
Old 11-15-2010, 11:45 PM   #128
VA72C10
VA72C10
VA72C10's Avatar
Very nice!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-15-2010, 11:47 PM   #129
CUSHE63
CUSHE63's Avatar
Originally Posted by VA72C10 View Post
Very nice!!!
Thanks. Jon and I polished the old stainless trim...new slider.. new rubber..about 20 minutes and it was installed.
Steve
Old 11-15-2010, 11:50 PM   #130
spike38
spike38's Avatar
Very nice!!!
I second that!
It's coming along great.
Spike
spike38 is offline   Reply With Quote
Old 11-16-2010, 12:39 AM   #131
70LonghornCST
Moderator
70LonghornCST's Avatar
I'm loving it! Keep up the great progress.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 11-17-2010, 02:10 PM   #132
CUSHE63
CUSHE63's Avatar
More pics... New back slider...
Old 11-17-2010, 02:41 PM   #133
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!!
mcbassin is offline   Reply With Quote
Old 11-20-2010, 10:44 PM   #134
CUSHE63
CUSHE63's Avatar
Well, we have been busy this week refreshing some of the old parts from the truck. We also decided that the paint on top the dash was not up to par either..so..... we did something about that. We are also making progress on the engine. More measuring than Jon thought he would EVER do !!!!! But worth every second.
Old 11-22-2010, 09:58 PM   #135
CUSHE63
CUSHE63's Avatar
Got the new seat cover today. Unbolted the seat frames and repaired the the lower frame, had a couple springs broken, then powerwashed it and baked it in the paint booth. Beadblasted the tracks, and painted them up. Lots to do while waiting to get the engine done.
Old 11-22-2010, 11:46 PM   #136
mcbassin
Still Learning
mcbassin's Avatar
That green paint is so cool! Bet it sucked to tape the whole truck of to paint the dash....man this is going to be a better than brand new truck when your done.
Old 11-23-2010, 12:46 AM   #137
CUSHE63
CUSHE63's Avatar
Yes, it took me about 4 hrs by myself to do that. It will be better than new, but we aren't going NOS with everything. We want to drive and use it. Also, it's kind of nice to use some of the old stuff along with new stuff.
It's getting closer. Jon was busy in the engine shop measuring his engine parts. It won't be too much longer....
Steve
Old 11-23-2010, 10:51 AM   #138
gcburdic
Restoration Virgin!
gcburdic's Avatar
Great build Steve and Jon....I look forward to seeing the finished product!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-23-2010, 03:17 PM   #139
Dieselwrencher
Man that looks awesome! Can you give some advice or tips on installing the rubber with the trim in it? I usually pay a guy I know to do it, but i might try it myself on the next one.
Ryan
Old 11-23-2010, 07:47 PM   #140
70LonghornCST
Moderator
Ryan, I just asked a friend who is a glass man the same question. He assured me that it's a two person job: one guy pushes on and guides the glass from the outside, the other pulls the string (string method) to seat the gasket from the inside.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 11-23-2010, 08:23 PM   #141
Dieselwrencher
I can pull the window in, but I'm really nervous about the trim. Don't you install the trim after the window and gasket are installed? Or do you install the trim in the gasket and then install it all together? I always thought the trim helps lock the gasket in place but on these IDK.
Ryan
Old 11-23-2010, 09:49 PM   #142
CUSHE63
CUSHE63's Avatar
The back window was pretty easy. The stainless goes in the rubber first, then install the rubber on the glass starting at the bottom, then work your way across the top. I will say that the back window went in real easy. I roped it and used window cleaner to make it easy to install. Again, start from the bottom inside the cab while someone holds the window in place from the outside while pressing down, then get your lower corners in and work your way to the top middle. Pop it with your open hand to set...
Steve
Old 11-24-2010, 12:18 AM   #143
CUSHE63
CUSHE63's Avatar
More of the little things done today. Cleaned the headers for re-paint, sanded and painted the seat frames, primed up the valve covers, oil pan and timing cover, wire wheeled the seat cover wires...the bed is not as full as it once was either. And we got some aftermarket front wheel wells. They will be test fit and then modified if needed.
Old 11-24-2010, 01:58 PM   #144
67chevy1series
67chevy1series's Avatar
oooooo that looks nice shes almost done how does it feel
67chevy1series is offline   Reply With Quote
Old 11-24-2010, 02:33 PM   #145
1956cameo
1956cameo's Avatar
Great work on the rebuild! I am glad to see other people not afraid to tackle some rust on a project.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 11-24-2010, 08:53 PM   #146
CUSHE63
CUSHE63's Avatar
It feels good... I know Jon is excited too !!!! I just finished up my 1959 VW Beetle in September, so getting this done will be great too.
More pics....
Old 11-24-2010, 09:12 PM   #147
CUSHE63
CUSHE63's Avatar
Coated the headers, and here's the seat frame. I had to do a little seat frame repair. the drivers side springs were broken. A little welding and its good to go..
Old 11-24-2010, 10:22 PM   #148
Dieselwrencher
Looking good! Man the dash looks great now! Thanks for the tips on installing the rubbers with trim. Although, you make it sound too easy.
Ryan
Old 11-29-2010, 10:34 PM   #149
CUSHE63
CUSHE63's Avatar
Here are some pix from today. I steamed the seat back pad and then installed the cover, Jon and I installed the windshield tonight also... only took 3 tries..
Old 11-29-2010, 10:46 PM   #150
Dieselwrencher
Looking very nice!
Ryan
