Old 04-15-2012, 06:14 PM   #126
Car'n'Guitars
Car'n'Guitars's Avatar
Re: My crewcab 4x4 cummins project
Cool truck, quick question for you, what motor mounts did you use to put in this motor? And what transmission are you using with it?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 04-15-2012, 06:22 PM   #127
Pullin81
Pullin81's Avatar
the motor mounts are what avalanch engineering sent which i believe there not open anymore. another place you can get cummins conversion parts is autoworldmt. transmission is a 2wd dodge nv4500 with a divorced np205... heres a picture of the mounts i used
86 gmc short box..461bbc/th400 12.95@106mph
85 gmc crew cab 4x4 8"lift cummins conversion
Pullin81 is offline   Reply With Quote
Old 04-15-2012, 06:29 PM   #128
Car'n'Guitars
Okay thanks, like the truck a lot hope to do this someday? With a Cummins no GM transmissions will work right?
Old 04-15-2012, 06:34 PM   #129
Pullin81
Pullin81's Avatar
i honestly couldnt tell you... i know you can do an allison conversion but im not interested in automatics... but thanks for checkin out the truck... n good luck n hopefuly you can put one together sooner than later
Old 04-15-2012, 06:38 PM   #130
Car'n'Guitars
Okay yeah that's what I thought, I'll be keeping an eye on this thread it's very interesting. Good luck.
Old 04-15-2012, 09:10 PM   #131
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
There are plenty of adapters out there to use a GM auto or manual trans.
--Josh
Old 04-16-2012, 04:25 PM   #132
stepside83
stepside83's Avatar
awesome build man keep up the great fab work, and the pics coming
stepside83 is offline   Reply With Quote
Old 06-10-2012, 10:02 AM   #133
Pullin81
Pullin81's Avatar
finally been able to get back to working on my truck, the vette is finished... got the passenger side of the cab and passenger front fender rough blocked ready for epoxy primer. then my ADD kicked in and i decided to start putting a 2001 chevy dash in as well as the heater box and ac equipment. i have the complete harness for the dash and all switches, vents, and cluster which the cluster probable wont be uses. i aslo got my traction bar ends machined for the truck aswell .
Old 08-05-2012, 09:12 AM   #134
Pullin81
Pullin81's Avatar
well ive been slowly trying to get back to work on my truck dealing with building the house is taking up alot of my time and the heat we have had here the last while makes it to hot for me to work on it... i got all the cab stripped and epoxy primed, all the seam sealer is out, holes in the fenders for the emblems are shaved and smoothed ...the traction bars are welded up just working on the mounts, decided to change the trans cross member and t case mount...
Old 08-05-2012, 10:41 AM   #135
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! It has been a rough summer!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-05-2012, 11:01 AM   #136
Pullin81
Pullin81's Avatar
Yes really hot hard to keep an igloo up here with this heat lol... I guess also ordered a vintage a/c the other day so I hope to see that by the end of the month so I can get the fire wall finished up
Old 08-08-2012, 01:41 AM   #137
hick
How do you like the dash?
Is it much deeper then the original? I REALLY want do an 04+ dash but i am not sure if it would stick out to much or not
And which vintage a/c did you order, the original one for the truck? You can't use the one that come witht he dash?
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 08-08-2012, 08:33 AM   #138
Pullin81
Pullin81's Avatar
i "liked" the dash, my only problem with it was how tall it is... for that reason i look it out, i had it all trimmed and fitted to the front windshield which ment i would have to put a different style defrost vents in it... but the bottom of the dash came down to low and when i run the pedals mainly the clutch my shins come about 2 inches from the dash so i decided to go back to factory dash... i will just try n customize the factory dash a bit instead.
for the vintage air system i went with with VA Gen IV sure fit system and also went with the control panel kit so everything should be electric
Old 08-09-2012, 01:14 AM   #139
hick
Damn... Thats what I was afraid of
Its a shame cause it looks like it was meant to be...
I kinda found my self leaning to that when it comes, custom build a nice intergrated console into the dash to hold all the toys
Truck looks good
Old 08-09-2012, 01:43 AM   #140
hamad
hamad's Avatar
nice project =) good luck
hamad is offline   Reply With Quote
Old 08-13-2012, 09:39 PM   #141
Pullin81
Pullin81's Avatar
managed to get a 4wd shifter in and the doors mounted and adjusted before i carry on with body work, just waiting till tomorrow to get one door pin and bushing kit... also ordered a a/c and alternator relocation kit ill be running a ac compressor off a early 90s chevy and a powermaster one wire 140A alternator... should be plenty of juice for the electrical accessories i plan to run...also decided to try a little spraying so i decided to tint the roof lights today
Old 08-13-2012, 10:16 PM   #142
Dieselwrencher
Looking good man!
Ryan
Old 08-19-2012, 02:32 PM   #143
Pullin81
Pullin81's Avatar
got the rest of the front end on... wow are new panels a poor fit now comaired to my last truck i did 6 years ago... so lots of trimming and grinding will be needed for a better fit... not looking for the perfect gaps but close to... also built one frame mount for my traction bars turned out pretty good...
Old 08-20-2012, 01:21 AM   #144
Dieselwrencher
Looking good and nice fab work!
Ryan
Old 08-22-2012, 09:20 AM   #145
splehigh
splehigh's Avatar
Looking good! Keep it up!
splehigh is offline   Reply With Quote
Old 10-25-2012, 02:57 PM   #146
Pullin81
Pullin81's Avatar
Well the truck is on hold till summer time the last few months has been hectic with the house were finally moved in but unfortunately old man winter hit before I got my man cave pad poured... So I give up my shop and put everything in storage till spring .... Unless the weather smartens up for a few weeks....
My vintage ac unit finally showed up but will stay in boxes till next year and all my brackets to mount a Harrison ac compressor and gm one wire alternator... All fit fairly nice... I have pictures to come but I don't have Internet at home ...
Old 10-25-2012, 02:59 PM   #147
Pullin81
Pullin81's Avatar
Old 10-25-2012, 03:02 PM   #148
Pullin81
Pullin81's Avatar
Vintage air kit
Old 10-25-2012, 03:44 PM   #149
Dieselwrencher
Very nice. Sucks to hear about your pad, but you have to do what you have to do man. Auto world does a nice job on the brackets and such. I like their pulleys too.
Ryan
Old 11-10-2012, 02:16 PM   #150
gtdownonit
Where did you get the dual fan hub pulley?
Originally Posted by Pullin81 View Post
gtdownonit is offline   Reply With Quote
