Old 08-08-2011, 01:00 AM   #126
laid_out_70
laid_out_70's Avatar
Re: building my first lowered truck
todays progress, alot of sanding. lol
shaved all the holes except for the rear cab mounts since i haven't transferred the measurements yet
the tranny crossmember
the ridiculous pile i had after sanding all day
and my buddy started on the front crossmember
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob?
http://67-72chevytrucks.com/vboard/s...d.php?t=438132
laid_out_70 is offline   Reply With Quote
Old 08-08-2011, 01:22 AM   #127
jbclassix
Junk Yartist
jbclassix's Avatar
Subscribing!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-08-2011, 04:04 PM   #128
Cameron 1137
Cameron 1137's Avatar
Originally Posted by laid_out_70 View Post
thanks guys, it is scary that this is my first build and ive only been fabbing for about a year now? lol
Well i guess you were born to fab!
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 08-09-2011, 01:55 AM   #129
laid_out_70
Originally Posted by jbclassix View Post
Subscribing!
thanks!
i hope so. if i can make a living doing this ill be a happy camper.
Old 08-09-2011, 01:56 AM   #130
laid_out_70
buddy got a bit further on the crossmember today, i got the cab mounts tacked on, practiced some welding and shortened a friends down-pipe.
and a random
Old 08-09-2011, 02:35 AM   #131
offlimts502
offlimts502's Avatar
If nobody can find inspiration from this last pic then well....you might as well be dead.
offlimts502 is offline   Reply With Quote
Old 08-09-2011, 02:50 AM   #132
Krooked Kustoms
Krooked Kustoms's Avatar
Front crossmember looks killer mate! Ya chippin away nicely! And +1 ^
Krooked Kustoms is offline   Reply With Quote
Old 10-04-2011, 03:29 AM   #133
laid_out_70
BUMP! finally made some progress on the truck. welded up the rest of the body drop, welded up the cab mounts, and cut the front end off. lol
got it back in first,
time for the Z! couldn't afford to do the crossmember.
3" up, 1" forward.
oops!
just a rough line up.
Old 10-04-2011, 07:24 AM   #134
502ms
502ms's Avatar
Very impressive! Subscribed
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-04-2011, 11:03 PM   #135
bird68
bird68's Avatar
you are putting some time in that truck,
mike twitty
05 chevy silverado
68 chevy short step
74 gmc jimmy 4x4
77 gmc short wide 4x4
bird68 is offline   Reply With Quote
Old 10-05-2011, 01:31 AM   #136
laid_out_70
got a few hours in today.
first i got the Z tacked up, thats Fry BTW.
then i cut off the top of the c channel
some 2x2 to make a new consistant slope.
both tacked in
looks even. lol
Old 10-05-2011, 01:33 AM   #137
laid_out_70
thanks for the kind words guys
Old 10-06-2011, 10:08 PM   #138
bird68
bird68's Avatar
your going lot of hard work, more than i can do on mine
mike twitty
05 chevy silverado
68 chevy short step
74 gmc jimmy 4x4
Old 10-07-2011, 02:17 AM   #139
Krooked Kustoms
Mate been waiting for an update on this rig and a good one it is! nice work!
Old 10-09-2011, 11:25 PM   #140
laid_out_70
did some work on the Z today. ran a 2x2 on the bottom to make the slope consistant.
welded up
some notching and sanding to make the surface even.
tacked in the frame cap.
more progress tomorrow
Old 10-10-2011, 10:22 AM   #141
67cheby
67cheby
67cheby's Avatar
nice work....and nice helper
67cheby is offline   Reply With Quote
Old 10-10-2011, 11:32 PM   #142
laid_out_70
thanks sloshy. :P
did a litte bit today.
inner plate for the Z cut
then did a little patch pannel
mocked up
more clamps the better
tacked in, fits like a glove
also moved a o2 sensor bung for a buddy
Old 10-11-2011, 07:55 AM   #143
98crewcab
holy "getting **** done" batman!!!! moving right along, and even while distracted by all the other rides..........
98crewcab is offline   Reply With Quote
Old 10-11-2011, 10:55 AM   #144
67cheby
67cheby
67cheby's Avatar
Sloshy...LOL, SLOSH was my nickname in high school !! deff one of the cleanest , well braced Z's i have seen , nice work
Old 10-11-2011, 11:07 PM   #145
laid_out_70
thanks sloshy :P
got about 8 hours in today on the Z
first i cut out the other plate and got em welded up
then i started sanding, only had one sanding disc left so i didnt get far.
looks beast, now i want to redo the back half. lol
then i cut all the uneven stuff off on the outside of the Z. going to plate it like the inside.
Old 10-16-2011, 07:10 PM   #146
laid_out_70
got the Z just about finished up, just need to do some more forming.
here im curious what the solution is, my frame horns needs to go down 5" and back an 1". that would put the steering box in my radiator.
buddy built this sweet cover, he also did the bag job months ago.
Old 10-16-2011, 08:09 PM   #147
67cheby
67cheby
67cheby's Avatar
nice
Old 10-16-2011, 10:58 PM   #148
jbclassix
Junk Yartist
jbclassix's Avatar
...here im curious what the solution is, my frame horns needs to go down 5" and back an 1". that would put the steering box in my radiator...
Do you want to drop your radiator? Your engine wont be moving unless you drop the mounts too, so technically, your radiator may be in your fan too, and your shroud wont work. What about doing the Z the way you are already 5 down and 1 back, then once you have the body on and the core support in, build your radiator mounts to fit? Would that work?
-Jeremy
Rebuilding an NP205
Old 10-17-2011, 01:17 AM   #149
laid_out_70
yep, that my plan if i must, engine is going back in 1" also and going to drop it as far as i can. was just hoping i didnt have to mod my core support and radiator mounts but if i must. lol
Old 10-17-2011, 05:36 PM   #150
L&L70
I have been snooping allot of posts before pulling the trigger on my truck and I have a question about your sfbd. What made you decide on chopping the top of your frame off rather than the bottom? I would assume cutting the bottom would allow you to leave the body mounts alone. Also what would be your guess on the amount your frame hangs below the rockers when all body mounts are solid and new bushings? My mounts and bushings are shot so I can't get an accurate measurement.
Matt
L&L70 is offline   Reply With Quote
