Old 05-10-2011, 07:03 PM   #126
Frizzle Fry
Frizzle Fry's Avatar
Re: intro + 66 black bagged long fleet
I like what you've done so far for sure. Two observations/suggestions:
  1. Give yourself more clearance than you think you'll ever need on the front rear tubs. You'll end up going lower, running taller wheels/tires, or both.
  2. Toss that Torker intake. That was the worste intake I ever ran on my BBC. Far better to run a dual plane on a truck/cruiser.
Frizzle Fry is offline   Reply With Quote
Old 05-10-2011, 11:14 PM   #127
defgone
Following this build closely...going to do something similar to my 63...your truck is currently my role model...great job and pics...couple questions
1-the cupping of the lowers seems to have brought it down quite a bit from your first attempt...how much do you think it helped lower it? and kind of curious as to why it helped since the cup doesn't seem to put the bag that much lower?
2-what size/type of shocks are you running on front and rear?
3-where are you mounting the rear shocks?
defgone is offline   Reply With Quote
Old 05-11-2011, 08:16 AM   #128
coulter
coulter's Avatar
what setup were u running on your bbc? it rob too much power down low or somthing?
Originally Posted by low 90 View Post
nice truck for sure! if you dont mind me asking where did you get the motor mounts from?
i cant get the link to work for some reason but i bought them on ebay from performance online parts. just search for username performo on ebay and check out his store.. i got the tranny crossmember and engine mounts with bolts and rubber mounts for 210 i think
well i was using the suicidedoors cups on the bottom and they just sit down in the spring pocket to give the bag somthing flat to sit on..it was just too tall and the bag would fully compress (compressed height of 3 inches on my bags) way before it would go all the way down... and also when i raised it all the way up the bag was only like half way inflated before the upper controll arm would hit on the crossmember.. i think at the deepest point on my lower control arms since i modified them is 2 1/2 inches.. and before with the suicide doors cups the bag would sit above the control arm just a bit.. so i basically lowered the bag almost 3 inches which was the perfect amount to make it fit right
just noticed i never got a good pic of the shock mounts.. u can see them in this pic... still havent made some shock relocaters for the front yet... o btw they are just stock monroe shocks.. gonna upgrade later
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 05-11-2011, 07:32 PM   #129
Frizzle Fry
The name "Torker" is misleading. They produce less bottom end torque than the performer and they make less bottom end and less top end than the Performer RPM.
They were designed for low hood clearance vehicles like corvettes. You don't have that constraint with the truck. I'd swap for a performer RPM in a heartbeat. Do a little google on the Torker and Torker II to see what others have to say about it.
Old 05-12-2011, 01:16 AM   #130
coulter
coulter's Avatar
cool man thanx for the info!!! ill check it out
Old 05-13-2011, 06:32 PM   #131
coulter
coulter's Avatar
installed my sway bar and made a new radiator support/better jack point
i still gotta make the u shaped brackets for the rad to sit in.. then gonna paint it
i think it looks cool.. it will be way easier to jack my truck up now since it is right behind the bumper and i got a flat plate welded on the bottom.. also you wont see the rad support in the engine bay any more!!!!!!!
Old 05-13-2011, 07:27 PM   #132
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Looks good man! Makes me want to bag mine
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 05-19-2011, 07:00 PM   #133
daverod
SSN 706
daverod's Avatar
Must be gitting some OT. No updates. bought a radatior like yours just wondering how you going to mount the top? It's no quite as tall as the old one.or are you going to lift it up ? Might be a good idea. I have the same problem when I jack it up.
daverod is offline   Reply With Quote
Old 05-19-2011, 11:48 PM   #134
coulter
coulter's Avatar
ya ive been a little busy.. gonna work on it some the next couple of days.. still not quite sure how im gonna mount the top of the rad.. i want it to sit flush with the top of the core support instead of sticking up above like the stock one
Old 05-20-2011, 04:07 PM   #135
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I had a Torker II on my Z28, and all I can say is that it was the single worse intake I have ever run. Sawpped for a Performer RPM and have been happy ever since.
Coulter: That is a pretty sick build you've got going on, and I really dig your approach to the front end. I've often wondered about making the air bags lift higher like you have done, living in a small mountain town myself ground clearance is a must for anything (even the main drag). Also I've never seen much of a point in spending all that money to only get a couple inches of lift for driving. Again, I like your approach and you've given me some ideas to chew on for my roller. Sweet set up you've got there too bud. No doubt subscribing.
fryer1979 is offline   Reply With Quote
Old 05-21-2011, 12:11 AM   #136
coulter
coulter's Avatar
thanx man.. ya ive got a really steep driveway and i dont know if a dropmember truck would make it without dragging real bad
btw guess im gonna have to start looking for a different intake mani.. i wonder if anyone has tried welding a divider plate in there to make it a dual plane manifold?
Old 05-23-2011, 10:34 AM   #137
coulter
coulter's Avatar
well not too much progress but at least its something
got my crossmember finished and painted
Old 05-23-2011, 11:00 AM   #138
66redw/white
made in america
66redw/white's Avatar
it looks so good!
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 05-23-2011, 11:09 AM   #139
coulter
coulter's Avatar
thanx
Old 06-04-2011, 05:30 AM   #140
determined1
whats up man, no updates? i really wanna see how this bada$$ turns out.
determined1 is offline   Reply With Quote
Old 06-05-2011, 12:06 AM   #141
coulter
coulter's Avatar
nah not really... ive done a couple little things but no pics.. ive been really busy the last few weeks
ill get some new pics up pretty soon
Old 06-05-2011, 02:46 PM   #142
CdM
CdM's Avatar
I second that sick truck
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 07-07-2011, 06:10 PM   #143
daverod
SSN 706
daverod's Avatar
Tell me your not in jail. We want more pictures.
Old 07-09-2011, 11:56 AM   #144
coulter
coulter's Avatar
nah havent been in jail... a buddy of mine started building a go kart track and talked me into building one... so this is what i have been doin for the past month!! bout time to get back to work on the truck now that the kart is running
Old 07-09-2011, 10:53 PM   #145
Mechanic77
Now that looks like fun Like the bagger too, I've got an '04 just like that...just no 21" front wheel....spokes are the only way to go
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 07-10-2011, 04:54 AM   #146
coulter
coulter's Avatar
thanx man!! ya u cant beat the classic look of spokes on these bikes..hear pretty soon im gonna stretch my stock rear fender so it will match the length of my extended bags then repaint it.. i hate the graphics that are on it
btw mine is an 01
Old 07-29-2011, 12:41 PM   #147
coulter
coulter's Avatar
well not much of an update but at least its something
i got all the bed floor supports all welded up and painted
started working on my rear brake lines today... hopefully i wont be lazy this evening and i will get some more done
Old 07-29-2011, 09:17 PM   #148
creep
Registered Loser
creep's Avatar
Good to see some progress! A lot of builds I was following have kinda come to a halt or they just stopped posting.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-29-2011, 09:56 PM   #149
coulter
coulter's Avatar
ya 107 degree temps outside right now arent helping..lol
Old 07-29-2011, 11:23 PM   #150
daverod
SSN 706
daverod's Avatar
Nice. Least it something. I'll take the cold anyday. Least you can put more clothes on.
