Old 01-02-2013, 07:09 AM   #126
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: D60 Front Brake Upgrade
I have been receiving PMs asking if I will be selling the brackets.... I have no real answer yet. It will depend on a few key factors, mainly function and cost. I also have to think about liability. If I do sell anything, it will be a paper weight that happens to resemble a caliper bracket. It would not be welded. The cost will probably be high as I am paying retail pricing for materaials. The other cost would be to sign up as a vendor on here....
For now, lest just see how this all plays out.... While I appreciate all the support, until the truck is running and driving I will not be responding to PMs about selling brackets.
Thanks.
Rich
1972 K5 Blazer CST Click HERE
Old 01-02-2013, 08:56 AM   #127
ryanroo
ryanroo's Avatar
Originally Posted by mcmlxix View Post
I did not measure the inside of the wheel. I know it tapers, gets smaller closer to the mounting pad. I seriously doubt it will fit in a 16.5" rim. It barely fits the 17" rim.... I may end up with 18's later...
mine are not exactly the same, but i know they wont fit a 16.5 i tried with my rollers. i had to keep the calipers off to mount my rollers.
mine are 03-09 dodge brakes and have the same size rotor, slightly different caliper
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-02-2013, 12:49 PM   #128
WillemV8
Alright, good to know! I'll try something different then.
WillemV8 is offline   Reply With Quote
Old 01-04-2013, 09:58 PM   #129
83GMCK2500
I am very very interested in this upgrade. I would like to perform a similar upgrade but I would like it to fit in the factory 16" steel wheels. Any recommendations?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-04-2013, 10:02 PM   #130
ryanroo
ryanroo's Avatar
I would try the later model chevy HD brakes. they are sized for 16" wheels
Ryan
72 K20 12v build
Old 03-07-2013, 07:59 AM   #131
70custom20
70custom20's Avatar
Rich, I saw in your "new to me 1972 K5" thread a couple of changes that you were making regarding the front hubs and possibly the caliper brackets. How are you doing with this?
70custom20 is offline   Reply With Quote
Old 03-13-2013, 04:03 PM   #132
Jungle jim
That is one sweet build on the D60 brakes!!!!! Could you please PM me on the availability?
Jim
Jungle jim is offline   Reply With Quote
Old 03-14-2013, 04:37 PM   #133
Jungle jim
I reread everything from the beginning & see you used 2009 Dodge rotors but I don't see what they come off of or should I say what there for? I also see you used a Dodge caliper but I don't see what's from. Can you please let me know what truck there from?
Thanks,
Jim
Old 03-14-2013, 08:56 PM   #134
ryanroo
ryanroo's Avatar
They are from a 2500 4x4 truck
72 K20 12v build
Old 03-15-2013, 04:58 AM   #135
Jungle jim
Ryan,
Thank you!
Jim
Old 03-20-2013, 04:45 PM   #136
Jungle jim
PM sent.
Jim
Old 03-21-2013, 01:00 AM   #137
mcmlxix
mcmlxix's Avatar
Originally Posted by Jungle jim View Post
PM sent.
Jim
Jim,
My project is moving slowly and I'm not offering brackets till I'm sure everything works... When the truck is up an running I'll post here and my build thread...
The parts were 2009-2010 Dodge Ram 2500 / 3500 pickup rotors and calipers. They barely fit a 17" rim and I will eventually upgrade to some 18" aftermarket rims...
Rich
Old 03-21-2013, 03:35 PM   #138
Jungle jim
Thank you for the reply!!!
Jim
Old 04-05-2013, 10:37 AM   #139
kiszka6911
Rich, slow moving over here in Michigan, its warm enough to work outside now. Started axle dissasembly yesterday. As I thought new lockouts will be required. King pins are wasted. Rim question, I have set of 2005 17" Dodge Powerwagon wheels sitting on my garage floor. They are supposed to be a forged rim. I can get some measurements if needed?
http://www.dieseltruckresource.com/c...130301_004.jpg
kiszka6911 is offline   Reply With Quote
Old 04-19-2013, 04:09 PM   #140
kiszka6911
If you go on Raybestos website and look various Dodge rotors for 3/4 and 1 tons, model years 2005-2009 there are (4) different rotors that cover this time period. The all have different diameters, thickness's and heights. This could allow you to move the caliper more inboard or outboard to help with wheel fitment.
RB_P/N_______DIA"_______Thick"______Height"
780143R______13.89"_____1.339"______4.01"
780139R______13.855"____1.118"______5.15"
780736R______14.175"____1.472"______4.021"***used for this conversion
780733R______14.094"____1.276"______4.913
Old 11-23-2013, 03:25 PM   #141
gtdownonit
Does anybody know where to buy drilled rotors for a d60? What are peoples thoughts on drilled vs slotted vs drilled and slotted?
gtdownonit is offline   Reply With Quote
Old 11-23-2013, 05:23 PM   #142
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I'm not a fan, as the drilled holes allow a place for cracks to start and I see it as more of a gimmick and form over function for street vehicles. Also, a D60 rotor has a lot of mass to absorb and dissipate heat. I would put a set of good pads (not sure if EBC makes them for a D60) on a set of stock rotors for better braking.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 11-23-2013, 06:12 PM   #143
ryanroo
ryanroo's Avatar
the concept is sound. it allows the escape of gasses that build up under the pad from braking. thus allowing the pad better engagement of the rotor. but i dont have any side by side testing that proves it. i wouldnt be to scared of a crack starting in a round hole. if you get a rotor hot enough to crack, it probably wont matter much if it had holes or not. but i agree, i would start with performance pads if you can find them. i bet your options are pretty limited with oem stuff. you can get different hubs for a d60 and use wilwood rotors and calipers if you wanted but that would be a significant investment.
72 K20 12v build
Old 11-23-2013, 09:21 PM   #144
Mr. 250r
Mr. 250r's Avatar
When i was on rockauto looking at rotors they had a listing for drilled and slotted rotors, i have researched the cracking issues and what not and i decided stock rotors have worked more than okay so i went with stock and i believe ebc makes pads called yellowstuff as i saw it on a 60 build then i went to summit and asked them and they gave me a part # but it was over 100$ so i was like nope and went with the original pads
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 11-23-2013, 10:40 PM   #145
kiszka6911
Stainless steel brakes has some.
http://ssbrakes.com/c-624171-vehicle...-products.html
Old 11-23-2013, 10:48 PM   #146
jbclassix
Junk Yartist
jbclassix's Avatar
I have installed several sets on various vehicles (no Dana fronts though) of owner provided drilled, slotted, drilled and slotted rotors, and I have to say the metallurgy of these aftermarket rotors are far inferior to what OE and even parts store quality.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-24-2013, 12:22 PM   #147
ryanroo
ryanroo's Avatar
Jeremy, how do you quantify that? ive never noticed anything OEM that i would claim to be of great quality. i personally have nothing with aftermarket brakes, but i have ridden in a few vehicles before and after with EBC pads and one with the rotors. the cts we put the rotors and redstuff pads on isnt driven enough to have any longevity reports on the rotors. the yellowstuff pads make a significant improvement over parts store pads. i am interested in running the rotors and pads on my truck but i wouldnt want to spend the cash on bunk parts.
i have actually gone back and forth on using just the pads vs the rotors and pads. the slots and holes actually have a purpose, but for most street driving i dont think the pads would gas off much unless you are making repeated stops or slowing down from pretty high speeds. otherwise its just for looks. my reasoning for wanting better brakes was noticable fade in the brakes on a 03 dodge cummins truck driving in city freeway conditions. going fast but having to slow down frequently, i could smell the pads cooking and feel distinct fade. so, given a heavy truck with the power to accelerate and need to slow down aggressively the stock brakes were gassing off enough to fade. but, id hate to spend the money on parts of lower quality and higher cost.
72 K20 12v build
Old 11-24-2013, 08:06 PM   #148
jbclassix
Junk Yartist
jbclassix's Avatar
Ryan, what I should have said in reference to aftermarket was eBay "quality" aftermarket... EBC are schweet from what I hear, and when it comes to brakes, you get what you pay for.
-Jeremy
Rebuilding an NP205
Old 12-03-2013, 02:23 PM   #149
70custom20
70custom20's Avatar
Rich, any progress on the disc brake upgrade? I'm sure you've been busy with other stuff as well.
Old 12-03-2013, 04:44 PM   #150
mcmlxix
mcmlxix's Avatar
Not yet. Had a bunch of rust repair done. Turned into a frame off resto-mod... Body work should be finished this week and Line-X next week. After that all the mechanicals will start going back together. I'm guessing January at the earliest...
Rich
calipers, d60, hydroboost
