Old 05-06-2012, 06:09 PM   #126
JRANGER
JRANGER's Avatar
Re: Project 78 High Sierra
Well since I cant let things go i went ahead and took the cluster apart again and hit the needles with some Torch Red Scratch Pen/brush paint. I did all the needles on the extra gauges and the speedo since you cant remove it on the actual cluster wrapped in a paper towel....I like the torch red...
Here pics of comparison...The torch red on the extras, and the towel paint
Now hopefully i didnt screw up the needles by removing them all...I tried to put them back in the same place
JRANGER is offline   Reply With Quote
Old 05-07-2012, 02:22 PM   #127
UPNADM
UPNADM's Avatar
Nice work. Attention to detail...
UPNADM is offline   Reply With Quote
Old 05-07-2012, 03:05 PM   #128
trout
nice love it
Edited by staff
trout is offline   Reply With Quote
Old 05-07-2012, 03:34 PM   #129
JRANGER
JRANGER's Avatar
DAMNIT ALLL!!! Even with the new speedo cable all greased up the speedo still starts floating at 60..ON top of that I have the needles wrong on the volts and oil pressure as it now reads 18v instead of 13 and oil pressure is beyond 60 when i hit the gas...I think the gas gauge is right though.....ugh..
Anyone know how to fix the speedo if its greased with lithium grease? Any other ideas?
Old 05-07-2012, 06:12 PM   #130
JRANGER
JRANGER's Avatar
Still clueless on what to do with the speedo after trolling the forum other then dealing with it.....
Took the lens off and while started adjusted the Volt meter needle and Oil Pressure...So now when i hit the gas it goes just to 60PSI and the Volts stay around 13...
Also replace the temp needle as it had an orange spot....
And installed a blue LED bulb in the wiper switch
Hit the hood with 2 more cans of primer and sanded the whole thing down with 320 grit paper...She is ready for some paint...
Now to wait until payday and go buy the ACE Enamel paint color match to cardinal red...Have to get my paint chip first too though
Old 05-07-2012, 08:26 PM   #131
UPNADM
UPNADM's Avatar
Where did you get that steering wheel. Looks nice.
Also is that a special bracket you mounted your radio in?
Old 05-07-2012, 09:21 PM   #132
grayharville
^^who I am^^ what I say>
grayharville's Avatar
What's up with the Speedo?
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 05-07-2012, 09:59 PM   #133
JRANGER
JRANGER's Avatar
I got the steering wheel off ebay from spider performance
http://www.ebay.com/itm/1974-1994-GM...e9a8c5&vxp=mtr.
The stereo is mounted on the back half of a metra kit....I decided to set the cd player bracket as far back as it could and use that metal bracket to secure it in place with out the bezel. I screwed it into to the bezel holes to hold it in place and then used self taping screws to give it its own screws to hold it in. Then I removed the bracket screws so the bezel could be screwed back in.... With that in place I cut the bezel to go around the hole cd player and once in place I just pop the ring around it and its in place..
Grayharville....The speedo is jumping once it hits 0 mph....It floats between 60 - 100 mph constantly and i dont know why...I greased the speedo cable which was installed a few month ago brand new and jsut greased last week..So i dont know
Old 05-07-2012, 10:02 PM   #134
JRANGER
JRANGER's Avatar
took some night shots of the dash and then started painting the high sierra badge for the dash pad...Spilled some paint on the insert could remove it so i painted the whole center section...I plan on sanding it down even to give it a black red look since its not a smooth surface...O and the drip was on the last stroke after using the pen... me not thinking about how the stem was covered ERG!!!
Old 05-08-2012, 09:14 AM   #135
motornut
78K & 79C Jimmys
motornut's Avatar
great details,lights up good
no chance a gauge connection got loose?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-08-2012, 09:34 AM   #136
JRANGER
JRANGER's Avatar
all the gauges work i just didnt calibrate the needles. Once I took them off while the truck was running and put them where they usually are it started running fine...Only prob now is the speedo jumping even after lubing the cable
Old 05-08-2012, 09:29 PM   #137
grayharville
Try hitting it with a hammer
On a real note, I have no idea bud. Might go grab another out of the junkyard
East Tx Squares
Old 05-08-2012, 10:31 PM   #138
JRANGER
JRANGER's Avatar
Hit the center with red, hit the out side with black..Then edges it with silver and red the high sierra logo in silver and red
Gonna have to redo the black as i tarnished it a little with masking it and got some silver on it too....
Old 05-08-2012, 10:37 PM   #139
JRANGER
JRANGER's Avatar
wrong high sierra...I sanding the black back on to the edges
After I redo the black im thinking about hitting the whole thing with clear
Old 05-08-2012, 10:39 PM   #140
UPNADM
UPNADM's Avatar
That is a job that takes patience.... What's your shipping address and I will send my trim down!
Old 05-08-2012, 10:54 PM   #141
JRANGER
JRANGER's Avatar
LOL!!! Yeah, if it was as nice as it looks in the picture i would do that no problem...But its not.....Have to wait for it to dry and the only reason this was done was because of a paint drip lol
Old 05-10-2012, 09:51 AM   #142
JRANGER
JRANGER's Avatar
The 9-5 is really holding me back...Im day dreaming about the work i want to be doing to the truck right now...Damn it sucks having to work lol
Old 05-12-2012, 09:31 PM   #143
JRANGER
JRANGER's Avatar
Well with on and off rain all day I wasnt able to do the fender work i wanted to but I was able to work on finishing the dash insert and then worked on the cluster bezel
I got it in my head that changing the tarnished silver to the red would be awesome! Well in theory it was and it look ok but the red didnt go on as well and ended up blotchy in some areas and in general looked like it was just too much! So 4 hours down the drain I took the bezel back out back and hit it with VHT night shades, then re-painted all the trim by hand in red and silver....So I just finished and spent the entire day finishing those 2 piece..On the bright side its almost ready to be installed and im happy with the final results
Old 05-13-2012, 02:04 AM   #144
JRANGER
JRANGER's Avatar
Put the bezel on the dash panel just to see...
Looks better in person for sure...
Old 05-13-2012, 11:37 AM   #145
grayharville
Damn dude I like that
East Tx Squares
Old 05-13-2012, 12:48 PM   #146
JRANGER
JRANGER's Avatar
Wish I would of thought it through in the beginning and didnt take all day on it.
Old 05-13-2012, 03:18 PM   #147
Dalaigh
Canadian Trucker
Dalaigh's Avatar
It looks good, only thing I would do, is put a semi gloss or matte clear on the paint. It'll get rid of the glossy or shiny look, which I personally don't like, shiny interiors can cause the sun to glare and make it hard to see.
But, if thats the look you were going for leave it.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 05-13-2012, 06:29 PM   #148
JRANGER
JRANGER's Avatar
yeah if it wasnt vinyl too i would but i dont want to risk it with the vinyl dash pad
Old 05-13-2012, 10:48 PM   #149
butch86
butch86's Avatar
Man i would kill to go back to work................... medically retired at 35 sucks. on good days i do believe i could work circles around 2 men my age. on the other hand on my average days and bad days i couldnt make a dent in an idiots work ethic.
i like the work on the bezel and dash mat. i agree that some matte clear would make it look even better ( for my taste)
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 05-23-2012, 09:41 PM   #150
JRANGER
JRANGER's Avatar
Ok well i bought a can of Aerosol Semi Gloss Black Rust-Oleum Professional Enamel and hit half my old grill with it....I did a quick sand and clean and no primer but im just wanting to get a slight idea what semi gloss will look like..
Other then that Im fighting with the wiring of the door jamb switches trying to figure out why the fuse blows instantly....Going to replace both switches and hope that does the trick..
