Old 05-23-2014, 06:08 PM   #126
vannatta20
vannatta20's Avatar
Re: 1968 C10 5.3 swap, the easy way.
Originally Posted by mcmlxix View Post
I just noticed you're in Vegas... You should come by the weekly car show/meet on Sundays. There are a couple 67/72 trucks that show up, one is a member here and has an LS1 swap.
Car show on Sundays? I only knew about cars and coffee on Sundays. Can you pm me your#?
vannatta20 is offline   Reply With Quote
Old 05-23-2014, 06:09 PM   #127
vannatta20
vannatta20's Avatar
Originally Posted by bryce1010 View Post
I just found your post. I have a 1971 c10 and thinking about doing the conversion . I can get the engine and transmission and all acc. and harness and computer . all i would need to do is give the fuse box from the donar engine 12v and everything should work. Ware are the speedo and tach taken from?
Just delete vats first and it should run. I used autometer gauges.
Old 05-26-2014, 11:40 AM   #128
bryce1010
How did you delete the vats
bryce1010 is offline   Reply With Quote
Old 05-26-2014, 12:40 PM   #129
vannatta20
vannatta20's Avatar
I did it myself using Hptuners. It cost over 500$ for it. You can have a local tuner reprogram it for you for around 100$ If you cant find anyone you can mail the PCM to me to reprogram it. PM if you are interested in that.
Old 05-26-2014, 04:26 PM   #130
claytonisbob
That's weird that you're getting such bad mileage with the LQ4. My LQ4 Chevelle with 315 tires, gm hot cam, t56 and 3.90 gears gets 23mpg on the highway/ ~17 in town. I know it's a car and it's lower, but those wide tires don't do me any favors. No AC though.
Nice truck man. Im planning out my 71 GMC for my newly acquired 5.3/auto swap and I really like the way you did the mounts and AC.
claytonisbob is offline   Reply With Quote
Old 05-26-2014, 05:41 PM   #131
vannatta20
vannatta20's Avatar
My 68 firebird with 4.10's, t56 and the 6.0 in that got 24 on the highway. These trucks are not aerodynamic in any way. My firebird would cruise at 90mph no problem. My truck needs a lot more gas input to maintain the higher speeds. I changed cams in the truck and got 17mpg on my last trip though.
Old 06-06-2014, 04:43 PM   #132
chevy72blu
chevy72blu's Avatar
x2! I'd love to see this truck in person
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 06-11-2014, 07:54 PM   #133
claytonisbob
You said you ran dirty dingo engine mounts. Did you just use a dingo 1973+ mount on the driver side with the clam shell isolator and a different one on the passenger side? Did you have to get 2 sets of plates to do this? Curious since I cant really make it out in the pictures. Thanks.
Old 06-22-2014, 09:18 PM   #134
kvn1011
Kvn1011
kvn1011's Avatar
love the swap
post pics of your car when you get time
kvn1011 is offline   Reply With Quote
Old 06-22-2014, 10:33 PM   #135
vannatta20
vannatta20's Avatar
i used dingo plates on both sides. that pic was to show how the 73 mount is different.
Old 07-06-2014, 05:28 PM   #136
franky69c10
chevy runs deep
franky69c10's Avatar
Came out real nice bro thanks for all the info
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 07-09-2014, 07:37 PM   #137
'68 Short Step
'68 Short Step's Avatar
Very cool! I plan on doing the same swap very soon the same way. Nice work!
'68 Short Step is offline   Reply With Quote
Old 07-10-2014, 01:31 PM   #138
encasedmetal
My fuel tank is a hot mess. I tried a LS1 camaro fuel tank and that did not fit at all underneath my bed. The tank is now im my bed tool box... Going to get a custom tank and house the LS1 fuel pump assembly.
what was the issue? - I've seen pics of people using them and want to use one with my 63' if at all possible.
encasedmetal is offline   Reply With Quote
Old 07-15-2014, 01:07 PM   #139
lowlyfec10
my inspiration thread! the 350 i just put in my 69 a few months ago is starting to smoke at warm idle now...time to find a 5.3 and do a mild build but i plan on keeping it hooked up to my th400 unless i score a trans cheap as well. so dingo mounts and 73+ mounts and im guessin the factory driveshaft will work as long as the mounts are adjusted accordingly. lookin into the car intake and manifolds since im dropped 3" but plan to lay frame in the near future. *thumbs up*
lowlyfec10 is offline   Reply With Quote
Old 07-18-2014, 08:00 AM   #140
68Stepbed
68Stepbed's Avatar
I would go ahead and find a 5.3/4L60E combo and change them both.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-18-2014, 02:32 PM   #141
vannatta20
vannatta20's Avatar
A LS1 tank will not fit between the frame rails unless you hack it up the frame up. Not worth it at all in my opinion. Also its not a flat tank on the bottom and will hang down.
Old 07-18-2014, 02:49 PM   #142
vannatta20
vannatta20's Avatar
Originally Posted by 68GMCCustom View Post
ahhh.......cam is stock then. That would be a limiting factor. That said...your dyno numbers are good. Wouldn't think you'd be getting valve float with those springs in the low 5000rpm range but I'm not familiar with their specs.
put a .550 to .600 lift cam in it with duration in 210-220/220-230@.050 range...along with a nice set of .650 lift dual springs and some c-moly p-rods to keep it together and watch it wake up!
I did exactly this and 68GMCCustom is exactly right! Has so much more power and driveability is still great.
Old 07-20-2014, 03:44 PM   #143
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Thanks....glad to here I'm not putting bad information out there!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-13-2014, 07:44 PM   #144
vannatta20
vannatta20's Avatar
New updates. Installed a 8.8 ford rear end for cheap but strong limited slip. Also upgraded to a better flowing intake manifold out off a TBSS. Upgraded to 90mm dbw throttle body off a gto as well. Much more responsive and wants to spin the tires all the time.
Old 09-13-2014, 10:26 PM   #145
Houston Ben
Houston Ben's Avatar
What is the difference between the stock manifold vs the TBSS manifold? Also, what year is the GTO TB and did you have to re-tune?
Houston Ben is offline   Reply With Quote
Old 09-13-2014, 10:42 PM   #146
vannatta20
vannatta20's Avatar
Well its kinda confusing. My new intake is a GEN IV cathedral style head intake. Used on TBSS and all 5.3 and 4.8's. They look much different from the gen3 style and some testing has shown them to make more power than a LS6 intake. Ive read many conflicting tests though. I got mine cheap and wanted to upgrade to the 90mm DBW. It was easy to put a GTO DBW throttle body on mine due to the old style dbw I used(00-02). Same as the corvette. newer 2003-2007 DBW you need a 250$ signal modifer to get a gto throttle body to use.
Old 09-13-2014, 10:47 PM   #147
Houston Ben
Ah, got ya. I have 2011 dbw. Thanks!
Old 09-23-2014, 12:38 PM   #148
bryce1010
How did you do the wiring on the compressor . Got a vintage air system going to start install
Old 09-23-2014, 07:04 PM   #149
vannatta20
vannatta20's Avatar
I just followed the vintage air instructions. Your just using a different compressor but the wiring is the same.
Old 09-29-2014, 09:50 AM   #150
w00dst0ck
w00dst0ck's Avatar
Did you narrow/widen the 8.8 to center the pumpkin (explorer)? Or did you use a Mustang 8.8?
I'm about to do the same and ditch the 12 bolt boat anchor.
w00dst0ck is offline   Reply With Quote
