Old 10-03-2012, 07:17 AM   #126
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Project Roxy
Sweet!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 10-03-2012, 09:46 AM   #127
longbed67
longbed67's Avatar
Re: Project Roxy
If it seems like your binding and it wont drop out the rest of the way check your steering center link/bar to make sure it is not flipped. I had mine flipped by accident and didnt know because it installs just fine flipped, and that is about how much it kept from laying crossmember and as soon as I flipped it to the correct direction, it sat right on the garage floor!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 10-03-2012, 10:01 AM   #128
screaminchevypickup
Laid Back
Re: Project Roxy
I don't think that's going to cause his problem!! He's running a rack and pinion on the dropmember..
72 chevy swb
Kyle
Old 10-03-2012, 10:37 AM   #129
Rochlow
Re: Project Roxy
I am running a PB dropmember with a rack and pinion. I thought it might be the tie rods hitting the frame, but after sending Nate a picture, he said that wasn't it.
I'm thinking it might be the wrong balljoints or maybe the shocks are bottoming out.. I need to investigate it more.
Rochlow is offline   Reply With Quote
Old 10-03-2012, 11:43 AM   #130
Last_Paladin
Re: Project Roxy
Nate said that?
I do have longer shock towers. Disconnecting the shocks is an easy test.
Last_Paladin is offline   Reply With Quote
Old 10-03-2012, 12:22 PM   #131
PBFAB.COM
PBFAB.COM's Avatar
Re: Project Roxy
From the pic you sent over, it didn't appear to be contacting and binding where the rack passes through the frame notch.
Best route is to start using the process of elimination. Take one thing off at a time and see if it makes a difference.
I would remove the shock first, then if that doesn't change anything, unhook the tie rod end at the spindle... and follow that route until she lays down all the way.
Should be something simple.... it always is! We will get it figured out!
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-03-2012, 12:45 PM   #132
Rochlow
Re: Project Roxy
Thanks Nate.. I will give that stuff a try tonight and see what happens.
Old 10-03-2012, 09:17 PM   #133
Rochlow
Re: Project Roxy
Whew! Just the shocks holding it up
Old 10-03-2012, 09:41 PM   #134
longbed67
longbed67's Avatar
Re: Project Roxy
guess im the dummy who should have read more of the build and looked to see what you were running! oh well... glad you figured it out!
Adam
(608) 214-8706
Old 10-03-2012, 10:53 PM   #135
Rochlow
Re: Project Roxy
Not a dummy at all, buddy. Your idea and theory makes since when running a stock crossmember and steering.
Old 10-04-2012, 11:38 AM   #136
scotts72heavyhalf
scotts72heavyhalf's Avatar
Re: Project Roxy
Beautiful build, love the contrast engine color and wheels.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 10-04-2012, 12:34 PM   #137
Rochlow
Re: Project Roxy
Alittle something you owned is going into the build, Soon..
Old 10-08-2012, 07:40 PM   #138
Rochlow
Re: Project Roxy
Just waiting to hear back about how to fix my front shock issue
Old 10-08-2012, 07:54 PM   #139
PBFAB.COM
PBFAB.COM's Avatar
Re: Project Roxy
Hoping to get back to you this evening before I head out. Had a crazy and short week last week and playing some catch up!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-09-2012, 02:04 AM   #140
NewType72
NewType72's Avatar
Re: Project Roxy
wow now thats just sexy laid out
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-21-2012, 03:58 PM   #141
Rochlow
Re: Project Roxy
Starting rust repair on a cab that is in better shape, than the original. That pile of stuff is what fell out of the rocker when I cut it off!
Old 10-23-2012, 11:45 PM   #142
Rochlow
Re: Project Roxy
First time welding sheetmetal..
Old 11-04-2012, 04:20 PM   #143
Rochlow
Re: Project Roxy
Used a patch from another cab to fix the rust hole in the upper passenger windshield post
Old 11-04-2012, 06:14 PM   #144
Rochlow
Re: Project Roxy
Redneck ingenuity is winning out on this truck. A muffler clamp welded to a frame tube will work just fine for an air tank mount..
Old 11-07-2012, 09:00 PM   #145
Rochlow
Re: Project Roxy
New sheetmetal from Bill at Atheys..
Old 11-07-2012, 09:47 PM   #146
67cheby
67cheby
67cheby's Avatar
Re: Project Roxy
Nice work !
67cheby is offline   Reply With Quote
Old 11-08-2012, 09:58 PM   #147
Rochlow
Re: Project Roxy
Less than $10 to mount everything..
Old 11-10-2012, 09:03 PM   #148
Rochlow
Re: Project Roxy
To say the least, I was intimidated by these. Install of passenger side went smoothly, hope the drivers side goes as well.
Old 11-10-2012, 11:22 PM   #149
longbed67
longbed67's Avatar
Re: Project Roxy
Those hinges look awesome, Props to ya, I didnt have the guts to try them... maybe on the next build
Adam
(608) 214-8706
Old 11-10-2012, 11:34 PM   #150
Delmo
Delmo's Avatar
Re: Project Roxy
Lookin good man
Delmo is offline   Reply With Quote
