Old 02-27-2013, 12:43 PM   #126
petergun
Re: rear disc brake templates and drawings
Hi guy, I'm new to this site. I'm just starting a 71 short bed project and would like a copy of your drawings, I do have a pay pal acount if you take that, thanks Pete
petergun is offline   Reply With Quote
Old 02-27-2013, 01:39 PM   #127
hilljob26
hilljob26's Avatar
sure do.pm sent
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-28-2013, 03:42 PM   #128
McKenna
These are very detailed and very well done, I'm just curious if anyone has priced out the calipers and rotors lately, I went in after I recieved my prints and for example
Calipers 126$ + core of 25 x2
Rotor 22$ x2
Pads 24$
Maybe parts are cheaper in the states but in Canada I was looking at over 400$ plus sales tax. once I paid sales tax and fabbed up the plates itd be cheaper for me to buy a kit. what are these parts going for states side?
This is not bashing you hilljob, your drafts are very well done, and without a doubt work well. I'm just curious if this is ballpark or if this gear is going cheaper for you guys?
McKenna is offline   Reply With Quote
Old 02-28-2013, 05:18 PM   #129
hilljob26
hilljob26's Avatar
last time i bought calipers here they were 36 bucks, and i was able to use any old caliper for a core,,not sure what others have done
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-28-2013, 05:27 PM   #130
McKenna
That would be nice! Got to love Canadian inflation, maybe ill check out rock auto.com or look at getting a set from Maine
Old 02-28-2013, 05:39 PM   #131
hilljob26
hilljob26's Avatar
i also didnt buy ebrake calipers, i wasnt worried about that,however i think those were 55 each,i think i just purchased front rotors off of a s10 if i remember right.having an automatic i wasnt worried about it on the last one i built, but i did use the ebrake ones on the first couple kits i made up for people
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 03-19-2013, 03:24 PM   #132
robs71k5
K5drive
robs71k5's Avatar
I just sent you a pm with payment for a 6 bolt templates and drawings kit with srpenner@hotmail.com as my return Thanks
robs71k5 is offline   Reply With Quote
Old 03-20-2013, 12:01 AM   #133
c1069
c1069's Avatar
Any chance you have a templates for seville ebrake calipers? Or can you design some for it 71 rear end? Those are easy to come by.
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 03-20-2013, 12:20 AM   #134
HotRod C/10
HotRod C/10's Avatar
No Core here.
http://www.ebay.com/itm/REAR-DISC-BR...item4cf9abd395
Rotor 22$ x2
Pads 24$
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-20-2013, 08:27 PM   #135
HotRod C/10
I tried the same rotors for a 77 deVille and they wont slide over my axle the Rotor Hat is like 6 1/4" and the axle is 6 13/16".....what does the NAPA brand hat measure inside?
Answered my own question.
Originally Posted by ihssalky View Post
i was able to use these plans and a pair of 1977 deville rotors to make a 5 lug setup. My axle is a 5x5 pattern with a 3.062 center hub. The 6 lug rotor has a 3.100 center so it is loose and you have to still drill pattern. I spoke to hilljob about this. I guess some axles have a different center hub od. Really the only difference in the setup is that you have to turn down the OD of the axle to 6.190. the only other difference is that the rotor od is .500 smaller so the caliper mounting holes move down aprox .250 on the bracket.
LS SWAPPED
-1976 SILVERADO
Old 03-20-2013, 08:33 PM   #136
hilljob26
hilljob26's Avatar
pm sent
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 10-14-2014, 02:10 PM   #137
Dale_Brown
Hilljob you still around with these templates?
Dale_Brown is offline   Reply With Quote
Old 10-14-2014, 09:42 PM   #138
hilljob26
hilljob26's Avatar
Yep..still got some
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 11-25-2014, 10:22 PM   #139
GMCJOE
GMCJOE's Avatar
If you still got some of these ready to go, send me a pm with your info. Thanks.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 11-26-2014, 07:21 AM   #140
hilljob26
hilljob26's Avatar
yes,, i just send em electronicly now,,
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 11-26-2014, 01:15 PM   #141
javelinmania
Has anyone successfully used the Eldorado Rear Calipers with the Emergency Brake Successfully? These are cheap on Ebay. If so, what did you use for Rotors and pads?
javelinmania is offline   Reply With Quote
Old 11-26-2014, 05:41 PM   #142
GMCJOE
GMCJOE's Avatar
Pm sent
Joseph
Joe's 69 GMC
Old 11-26-2014, 06:56 PM   #143
engairuph
What are you charging for the prints and will they work on four wheel drive? What master cylinder and can the self adjusting proportioning valve be used?
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 11-27-2014, 07:43 AM   #144
hilljob26
hilljob26's Avatar
20 bucks,,i used em on my 4x4, u can use whatever master cylinder and proportioning valve that u can afford,,i personally used a vette master and pro valve
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
