01-25-2013, 07:18 PM | #126 | |
67-72 parts collector,…
Re: New to me 72 Sub
Super clean. (I can see this stuff on a blue "newly converted" 2wd blazer!) What's the wheel and tire specs? This is my favorite build on the board right now!
01-25-2013, 07:19 PM | #127 |
A guy with a truck
More to come in a bit, I gotta get clean. I think there might even be some videos
Posted via Mobile Device Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-25-2013, 07:22 PM | #128 |
1972 Suburban 2wd - Accuair, Mob steel 20". 2011 Range Rover HSE 2010 E 63 AMG 2013 GL 63 AMG |
01-25-2013, 07:24 PM | #129 |
I see a new avartar in your future,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-25-2013 at 07:51 PM. |
01-25-2013, 07:25 PM | #130 | |
NO!!!! That truck is too nice to hack up.
01-25-2013, 07:51 PM | #131 | |
A guy with a truck
You know, I no longer have anything bagged, but after the AccuAir install, I may have to change my mind. Wheels/tires are non-conventional sizes, but worked out PERFECTLY. He wanted to stuff some meaty tires, and I talked him into a little rubber rake. Front: 20x9, 275/40-20, I'd guess around 4.5" BS Rear: 20x9, 295/45-20, guessing about 4" BS Guessing, 'cause we never verified w/ tape measure, just the fit to the truck, which is spot-on. Stock wide axle rear and CPP modulars up front.
01-25-2013, 07:52 PM | #132 |
A guy with a truck
01-25-2013, 07:57 PM | #133 |
Junior Member
Great job guys! Looks great. Congrats.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-25-2013, 08:07 PM | #134 |
A guy with a truck
good angle
01-25-2013, 08:12 PM | #135 |
C10 Club Tennessee
Caps?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
01-25-2013, 08:13 PM | #136 |
Junior Member
How is clearance on the inside of the rear tires and body?
01-25-2013, 08:23 PM | #137 |
Thanks. I had a great time. Chris actually accused me of giggling not once, but twice while I was working the e-control. The install was fun and I will say Chris is OCD like me. I'm in the car business and he has more knowledge than I could ever think about.
01-25-2013, 08:29 PM | #138 |
Any plans to add a lowering block to the rear to help keep the "ride height" low?
01-25-2013, 08:45 PM | #139 |
A guy with a truck
Not yet. Waiting for a proper removal tool before they go on. There is no way to get them off without scratching the powder...
Excellent. About 1/2" on either side. I'm not sure it needs it. The pre-programmed ride height is a little low in the rear right now, compared to the front. It needs some tweaking to fine tune the owner's preferences. It is just the 'factory' pre-set (10%-down/50%-ride/90%-up) settings right now...
01-25-2013, 09:19 PM | #140 |
A guy with a truck
01-25-2013, 11:13 PM | #141 |
Looks perfect!
Posted via Mobile Device |
01-26-2013, 12:15 AM | #142 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-26-2013, 08:46 AM | #143 |
So I'm guessing the same wheel and tire combo would rub in the rear on an earlier narrow rear end? Looks great by the way!
------------ Scott |
01-26-2013, 10:52 AM | #144 |
I'm assuming the front will go lower if you remove the upper a-arm bumpstops?
(and inner fenders)
01-26-2013, 10:59 AM | #145 | ||
A guy with a truck
01-26-2013, 11:49 AM | #146 |
I think this is as low as I'm going. I have to haul my kids around in this thing and I want it to be low, but simple to deal with day to day.
01-27-2013, 09:25 AM | #147 |
I'm just glad to be here!
Great job. I think it has a great stance given the everyday use it will get hauling the family around.
Are the Mob Steel wheels available in other widths beside the 9" you have? Posted via Mobile Device
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-27-2013, 12:54 PM | #148 | |
01-27-2013, 01:39 PM | #149 |
Tot Roddin'
Man this thing is cool!
I would love to have it in my garage. So what's next? BTW... which center caps are you wanting to run?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-27-2013, 08:21 PM | #150 |
Looks cool !!!!
