#126 |
Re: 1970 C10 LWB "Blu"
Awesome! Good to see an update
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579 |
#127 |
Thanks Chuck. I'm trying to do what I can while the block and heads are out getting their magic. I'm very, VERY anxious to at least get the engine and transmission back in for good so I can reassemble the interior, get the front clip back on and do my underbed fuel tank.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#128 |
I got my vintage air main section assembled and installed in the truck.
![]() ![]() Turns out I installed the blower motor (round) cap on backwards... Didn't notice until I was looking at hardware assembly on the big flat cover. Painted and caulked so its too late now. I used a stainless button head screw on it too which now I wish I didn't (since everything else is black). I'll have to use some black touch up paint on it. I eliminated all the self-tapping screws on the flat cover and replaced them with flat black button head 1/2-20 bolts. Painted the two 1/2-20 bolts that support the unit inside to tone them down a bit. The hardware vintage air supplies just looks cheap. My firewall is completely full of holes not from original equipment/harnesses that are no longer there. Its going to have to wait to get cleaned up and smoothed properly for another time. I hate to think of the can of worms I will open up if I start spiffing it up now. The dang cab will probably come off the frame and I'll get sucked into doing a full frame off. ![]()
#129 |
![]() Join Date: Jun 2009
Looks great John, with the necessary working liquid the install went smoothly
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#130 |
Thanks Larry. It took two beers and one cup of coffee to finish (the beer was making me sleepy so I needed the coffee..... it was kind of chilly in the garage once I turned off the heat too).
#131 | |
#132 |
Didn't want to turn on the heat in the garage for just a little bit of work so brought some stuff inside. Converted my control panel over to the vintage air controls. Went OK but I hope it will be more durable than it looks.
#133 |
You running your fan controls off ls pcm or what?
#134 |
Not sure yet. Going to jump into the harness and controls after I have the engine build sorted out. I don't think my brain can handle much more right now.
#135 |
Painless makes nice relay kits for stuff like that if you don't want to build your own. Something like this will make it pretty easy. This way you can have tuner still keep AC rpm adjustment on and things like that so it's drives nice and idles nice with AC on and also will have the high rpm shut off feature to protect your compressor.
http://www.painlessperformance.com/webcat/30109
#136 | |
#137 |
Following. Great work!
#138 |
You can have your ecm reflashed for fan controls. Mine was also a mechanical fan with clutch and I converted to 2 electric fans controlled by ecm .
#139 |
Yup.
#140 | |
#141 |
#142 |
![]() Join Date: Apr 2005
That came out nice! You can change the DBW pedal pad to a 71/72 pad fairly easily. Here's one with the CST trim on it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#143 | |
Where did you mount the TAC module on your hot-rod bus?
#144 |
I talked with Lt1.com about ac request also. I was told on dbw setup ac request doesn't need to be setup only dbc need that. My neighbor has dbw with no ac request.
#145 |
I know that the pcm will automatically bump up the idle when it senses the load change but I think I need the AC request to turn the fans on and off. Your neighbor might have controls for his fans independent of the PCM?
#146 |
Thanks John. Due to the way my harness was laid out (Speartech), I mounted my tach module underneath my computer on the core support.
#147 |
The TAC (throttle control module?) way up there? Dang... that's a long wire extension...
#148 | |
#149 |
I can't wait to see how this turns out. Subscribed
#150 |
that makes two of us!
