Old 02-03-2015, 01:57 PM   #126
jkeating1
jkeating1's Avatar
Re: Project "Leon "
Great work--had to get sub'd! I'm in the Central Expwy at Walnut Hill area-if you are anywhere close to me I'd be glad to come "lift" when you get ready to mount the cab, bed, etc.; or other non-skilled tasks.
Also will pass on a tip I saw in a thread here. It was mentioned that the band clamps tended to leak after a while. A member suggested wrapping the pipe with aluminum foil before clamping it--said it solved his leak. I can't say whether it works or not, but you can file that away.
JK
jkeating1 is offline   Reply With Quote
Old 02-03-2015, 04:30 PM   #127
texasld
texasld's Avatar
Re: Project "Leon "
I'm actually in Royse City. Not too far away. Do you have a link to that? Sounds interesting. I hear it's the best type of clamp there is.
Glad you like the truck.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 02-03-2015, 05:38 PM   #128
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Project "Leon "
should be a fun ride
Justin@EntropyRad is offline   Reply With Quote
Old 02-03-2015, 10:27 PM   #129
jkeating1
jkeating1's Avatar
Re: Project "Leon "
Don't have a link on it, but it was mentioned in post 698 of "The Hillbilly Deluxe dually build." I think this is the extent of the conversation, from GCncsuHD:
Not that it matters now that you have it welded up nice, but for future use, when using those band clamps, first take a bit of aluminum foil, double it over then wrap the joint before putting the band clamp on. The foil will act as packing, and will completely seal the joint. The first time I used those band clamps it leaked, I pulled them both and did that, have never had a leak since.
JK
Old 02-03-2015, 11:47 PM   #130
nuke1
nuke1's Avatar
Re: Project "Leon "
great project you have there. and that wood work you do is stellar!!!! migh have to get something from you in the future made up. Can you do a canuck flag one? hehe
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-04-2015, 10:00 AM   #131
calvin78612
calvin78612's Avatar
Re: Project "Leon "
When installing a band clamp if you will tap it w/ a rubber mallet as you tighten it , it will usually seal.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 02-04-2015, 10:12 AM   #132
Vic1947
Vic1947's Avatar
Re: Project "Leon "
...when using those band clamps, first take a bit of aluminum foil, double it over then wrap the joint before putting the band clamp on. The foil will act as packing, and will completely seal the joint. The first time I used those band clamps it leaked, I pulled them both and did that, have never had a leak since.
Mine came with a small sealant patch that goes across the tube parting line where the clamp flanges meet. As you draw them together the sealant extrudes into the gaps where the greatest chance of a leak would be. That won't do anything for the rest of the circumference, however, so the foil trick may be a better approach.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 02-04-2015, 10:06 PM   #133
texasld
texasld's Avatar
Re: Project "Leon "
Thanks, man. I have read through the Swiss Cheese build. That's is some awesome work. I love it!!! I wish you were in Texas to show me the ways of body work.
Excuse my hockey ignorance, are you talking about the flag with the shark looking thing? If that's the case. I sure can!!!
Thank you for all the tips. I still haven't ordered the silly things yet. Calvin hooked me up today. I'll get to that in a couple of days.
1999 Jeep TJ
Old 02-17-2015, 01:28 PM   #134
texasld
texasld's Avatar
Re: Project "Leon "
Well, 2 weeks later and not a whole lot has been done... I have been laying floor as a side job, that's always a fun gig. But, spent some time last night working on getting the radiator all buttoned up. Thank you to user calvin78612 for the upper brackets. They were perfect. He even delivered them to work for me. Can't ask for better than that.
Name:  Upper Brackets.jpg
Used 4 3/8 x 18 Stainless socket cap head bolts and they are in.
I pulled the rad back out to put the fans on it. I ordered these from amazon for $18.00 each. the shipping was a bit high, but it's still a better deal than if i had ordered another model.
Amazon.com: PROCOMP 14" INCH ELECTRIC... Amazon.com: PROCOMP 14" INCH ELECTRIC...
If you order the fans, they come with mounting hardware. I didn't know that so I ordered the mounting kit too. I'm glad I did, I ended up needing them, because I broke one of the disks.
Amazon.com: Derale 13001 Plastic Rod Mounting... Amazon.com: Derale 13001 Plastic Rod Mounting...
I had to trim just a bit off the side of one fan where the shrouds interfered. Just ground them down about 3/4 of an inch and they fit "like a glove" in a staggered pattern. Really happy with the way they fit in the truck too.
Name:  Rad w. fans on bench.jpg
Name:  Rad mounted.jpg
Name:  Rad mounted D side.jpg
I left the hoses hanging because I ordered some sleeving for them that should be in in the next couple of days. It feels nice to see all of this coming together. I just hope i did it all correctly.
NOW on to the Drive Shaft... This thing has been a pain in my @## If you have read though my build, you know I can be very "frugal" Sometimes it works, Sometimes it bites me in the tush. This time wasn't so great. So... I started off by thinking, "Hey, I have a 2 piece shaft that I can reuse. I have the parts and just need the work done." So I bought $100 worth of U-joints and a Carrier Bearing. The shortening and total balance will cost me $80. That leaves me at $120 cheaper than a new single piece shaft. If I ever decide to go lower, I already have the shaft taken care of too!
Cool, Great, Awesome. Here is where it gets fun. I picked up the shaft from the shop and it looked great, I was very happy. Get it home... and its the wrong length. I Gave the shop the right length, but I got mixed up on the reference points. The front shaft ended up being 7" to long!!!
So I took it back and they took the 7 inches out and re balanced it. This time they had to replace the weld in peace "connects u-joint to actual shaft" so this time it was $100. Now I'm up to $280 and I still have the original shaft.... Oh well, you live and learn.
Name:  Back Shaft.jpg
Here is the back shaft painted. Hanging on my high tech, high dollar, spray rack. I'll finish the painting and hopefully get it installed tonight. We shall see. Yes, I test fitted it this time to make sure it fit before I painted it.
1999 Jeep TJ
Old 02-17-2015, 02:55 PM   #135
Vic1947
Vic1947's Avatar
Re: Project "Leon "
For not having a lot of time to spend on the project, it's coming along nicely. Keep up the good work!
Victor
Old 02-18-2015, 10:46 AM   #136
texasld
texasld's Avatar
Re: Project "Leon "
I usually work on it every night and most weekends, So it seems slow to me, But thank you Vic! Glad to see the Ford is coming along!
Name:  Front shaft in paint.jpg
Name:  D shaft installed.jpg
Got the Drive shaft in. THank the lord. Hopefully everything works correctly.
Don't mind the dust on the frame. It been raining and I can't push it out in the rain after all of this work I have done. Once I get all the lines and such plugged for good, I'll wash her down real good like!
1999 Jeep TJ
Old 02-26-2015, 11:49 AM   #137
texasld
texasld's Avatar
Re: Project "Leon "
Well, I as in OKC Sunday through yesterday afternoon so I missed yet another couple of days of evening work. Started on the battery mounting tray, decided to mount it on the pass side under the bed. I'm thinking I am going to put a 200A inline fuse or circuit breaker on the positive side close to the battery. I saw a post on here of a guys truck that caught fire because of the relocated battery shorted or something.
I used 1/0 cable for the lead directly to the starter and all the ground leads. I still have a couple of grounds to build, but I went Ground to frame, Trans x member to tail stock, trans to DS head. I cleaned every connection and applied dielectric grease to keep the rust and corrosion at bay. All the connections are soldered, crimped, and heat shrinked. I really like wiring. I know, I'm a strange cat. I just love making the wires pretty!
I'm reusing the battery from the burb for multiple reasons,
1. I have it
2. It's in good shape.
3. I can go to any parts store and pick up a replacement.
The tray and strap came from summit. It was originally a weld on type, but once I got it I realized that I couldn't use the weld on style, I chopped it up and welded on tabs to make it bolt on. I shortened the strap by about 2" to make it more compact and re-drilled the holes. One side has a "kicked out" tab because the frame isn't a straight shot where it's mounted.
I cut the tab out of a piece of 1 1/4" angle I had laying around, and trimmed one side down a bit. You can't really see it in the last picture. I'll try to get s shot from top down.
Welded it up, drilled the holes, test fit, pulled, painted...etc. Paint dried and slapped that joker back on!
Name:  Batt in tray2.jpg
After I finished that all up, I tied all the electrical together and ran a jumper wire from the battery to the starter, with a quick tap of the wire. SHE ROTATES!!!! Not a strange sound to be made. That makes me happy!
Started working on the air intake and then gave up for the evening. Maybe I can get it started soon.
Name:  Air intake part.jpg
1999 Jeep TJ
Old 02-26-2015, 12:02 PM   #138
KMC3420
KMC3420's Avatar
Re: Project "Leon "
Looks great, I like the battery tray. Congrats on it turning over, bet that is an awesome feeling.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 03-02-2015, 04:44 PM   #139
texasld
texasld's Avatar
Re: Project "Leon "
Thank you! Pretty exciting. I would like to get it to start this weekend, but I have a lot of things to do before then. Don't think it's going to happen...
Got some more stuff done. Little stuff, but its progress.
Name:  Air Filter.jpg
Name:  Wiring Harness.jpg
1999 Jeep TJ
Old 03-02-2015, 05:46 PM   #140
Molberg
Molberg's Avatar
Re: Project "Leon "
Looks real nice. I too like the wiring part. Just cranked my new engine over on the starter for the first time. Anxiety and fear followed by relief, beer and staring at it. Good times.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 03-02-2015, 05:47 PM   #141
Molberg
Molberg's Avatar
Re: Project "Leon "
I was running out of hiding spots for all the relays.
-Project Nitemare-
Old 03-03-2015, 10:01 AM   #142
texasld
texasld's Avatar
Re: Project "Leon "
It's a great feeling! I was in the same boat you were in. Fear, then relief!
Sent my ECU off to Brendon at LT1swap.com to be reflashed last thursday evening. Got the shipping info this morning, it's on it way back home! Trying to get to a point I can start it this weekend. Nerve racking week I tell you. Hope I put it all back together correctly. We will know soon enough, I suppose!
Taking my Power steering line to a hose shop today to get the end made up so I can hopefully get that back together this evening.
1999 Jeep TJ
Old 03-04-2015, 02:04 PM   #143
Low Elco
Re: Project "Leon "
Good lookin' work so far! In!
Low Elco is offline   Reply With Quote
Old 03-04-2015, 03:01 PM   #144
Xeen
Xeen's Avatar
Re: Project "Leon "
Hey Mike I was going through your build from the beginning because I wanted to refresh my memory on your build and I noticed something I thought you might want brought to your attention.
As of post #50 your upper control arms are on backwards and need to be switched, a pain in the butt I know but it's better you know now before you are all done and the steering won't align.
If you have already noticed and switched them then great but if not then I'm glad I could help you out.
Sorry I didn't catch it earlier, I normally do but for some reason I missed it earlier.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-04-2015, 05:22 PM   #145
texasld
texasld's Avatar
Re: Project "Leon "
I sure dad-gum did!
Man, Nice eye! Thank you for the heads up. I'm glad you caught that. I would have been pulling my (lack of) hair out come alignment time!
1999 Jeep TJ
Old 03-04-2015, 05:48 PM   #146
Xeen
Xeen's Avatar
Re: Project "Leon "
Originally Posted by texasld View Post
I sure dad-gum did!
LoL no problem, I'm just glad I could help.
Old 03-04-2015, 09:59 PM   #147
trkfrk
trkfrk's Avatar
Re: Project "Leon "
I'm subscribing to follow along... You have made alot of nice progress in such a short time. Keep up the good work
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 03-05-2015, 11:06 AM   #148
texasld
texasld's Avatar
Re: Project "Leon "
Thank you, Sir Mark!
1999 Jeep TJ
Old 03-06-2015, 12:26 PM   #149
texasld
texasld's Avatar
Re: Project "Leon "
Sometimes I spend 3 hours in the garage and really feel like I have accomplished something.... Sometimes I spend 3 hours in the garage and think to myself "That's all I got done?"... Last night was one of those nights, although I am really happy with the way it turned out. The is in the details, right?
Wrapped most of my hoses in flex braiding and used heat shrink for the ends. Cut the flex about 2 inches shorter than the hose and had about 2 inches of heat shrink on each end. The radiator hoses got a little bit longer heat shrink to make them look right. Make sure you put the flex on the hose to get your measurement. As the flex expands it gets shorter in length, so you may end up short.
Had to get a PS hose made due to the lack of hoses options I had locally and a number of other issues, but I got it done. The return line will be remade and replaced because the bend is to high, I'm going to try the pack it with sand to bend it tighter.
Also played around with my phone and my valve covers. Came up with this...
1999 Jeep TJ
Old 03-06-2015, 12:33 PM   #150
boynton
boynton's Avatar
Re: Project "Leon "
I think I will immediately borrow your phone idea with my grill. That is amazing!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
