Old 07-29-2016, 09:52 PM   #126
ls1nova71
ls1nova71's Avatar
Re: Another way to skin the cat; the High Torque 292 LS swap
Haha, I always second guess myself when I take a perfectly good running vehicle apart too! Looks killer though, the stance is right on!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-30-2016, 09:56 AM   #127
smbrouss70
smbrouss70's Avatar
Ummm, Yeah, we definitely need a lot more info on that sweet little 68!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-03-2016, 09:32 AM   #128
ERASER5
ERASER5's Avatar
And a few more of engine mods, like that sweet oil fill tube!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-02-2016, 11:09 PM   #129
Red Foreman
Red Foreman's Avatar
I just stumbled across this build, awesome work on the LS!
The throttle body/air cleaner has given me ideas on my next future build.
Keep up the great work!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 09-05-2016, 08:45 PM   #130
65 c10 project
I'm very impressed with the truck, great job.
I have a few questions though.
How is the throttle set up? Throttle by wire or cable?
I am wanting the same swap but with a manual trans in my '65, since I'm going with a manual trans I won't need any speed sensors Etcettera so I'm thinking of going with a standalone ECU. Is that something you would recommend?
I think a standalone ECU would make it a lot easier to wire.
65 c10 project is offline   Reply With Quote
Old 09-07-2016, 12:09 AM   #131
dayj1
Thanks!
The throttle is DBW. On the ECU, I've never dealt with an aftermarket unit. Due to the sheer number of them out there, factory truck computers/harnesses are fairly cheap and they're very reliable. For those reasons, I've always used OEM parts.
dayj1 is offline   Reply With Quote
Old 09-07-2016, 05:33 PM   #132
65 c10 project
Originally Posted by dayj1 View Post
Thanks!
Ok, thank you for the info.
Old 09-12-2016, 09:26 AM   #133
Low Elco
That gold one is gonna be niiiiiice when you get it put together.
Low Elco is offline   Reply With Quote
Old 09-13-2016, 04:05 PM   #134
DarkKnightWong
Re: Gauges
I just stumbled across this build! Awesome build! I have a 69 Stepside Im trying to fix up when I have free time.
I was wondering how you did the lights on your gauges ? Looks like washer and some light socket ..
Could you explain a little more on what you are doing ?
Thanks!!
Allen
My gauges look stock, but I converted the speedometer to an S10 electric speedo similar to the way ls1nova does it and I used a volt and oil pressure gauge out of a square body ('86) cluster with the '72 faces on them.
DarkKnightWong is offline   Reply With Quote
Old 09-13-2016, 11:29 PM   #135
dayj1
Re: Gauges
Thanks!!
Allen
Thanks for the kudos.
You pretty much nailed what I did. The existing holes in the housing are made for the twist in sockets. You can get pigtails that fit, but they're about $3 each. Sockets like I used are $7 for 10 but they're just a bit to small to fit in the holes. So I used small machine screws to hold down some washers over the existing holes.
Old 09-13-2016, 11:31 PM   #136
dayj1
Thanks! I sure hope so. As we all know, it's a lot of work.
Old 09-14-2016, 07:27 AM   #137
DarkKnightWong
Re: Gauges
That sounds perfect, do you have a link to sockets or a picture of just them ? I need to order some before I put my gauges back in the truck.
Thanks for the quick response and info.
Old 09-14-2016, 07:40 AM   #138
dec010974
dec010974's Avatar
Dayj1, my hero, the smartest guy I know, I have a few questions. This pic looks shorter than your first set up. i want the sbc look. can you explain the reason why? I'm in the middle of this swap, on a 1980 gmc c15. i have a 4.8/4l60e, stock harness, and i have two options, the 4150 throttle body, or the thingy, figamabob, you created. my figamabob is an 1 inch thick, to compensate, for the tall fuel injectors. help me out and explain the madness. thanks in advance, Clark.
dec010974 is offline   Reply With Quote
Old 09-14-2016, 10:37 PM   #139
dayj1
Re: Gauges
This is what I used: http://www.ebay.com/itm/251416930819 They just pop into a round hole but they required the washers that you asked about to provide holes small enough for them to fit.
There are some other possibilities out there. Search for "194 pigtail" and you'll see sockets with various mounting arrangements. Maybe there is something that will work better.
Old 09-14-2016, 10:54 PM   #140
dayj1
The difference in the setup on the blue '72 and the gold '68 is mostly in the air cleaner base. The base on the '72 started life as a stock '86 C10 air cleaner and is what I'll call a "flat" base because the bottom of the air cleaner element is vertically at the same height as the air cleaner flange on the throttle body. The '68 has a "drop base" air cleaner which is 1.5" below the flange. It doesn't sound like much, but it makes a big visual difference.
I'll probably end up using a taller element in the air cleaner (4" instead of 3") to provide enough room to squeeze a MAF in there like the setup on the '72. However, I do like the look of the shorter air cleaner and might just ditch the MAF and go with a speed density tune.
Also, the adapter that goes from the 4150 flange on the intake to the 3 bolt factory 5.3 TB is 1/2" tall in my case. That allows the plug on the TB to just barely clear the fuel rail with factory truck injectors (standard injectors and not taller flex fuel injectors). This would be a non issue if had the foresight to make the adapter in such a way that the TB was turned 90 degrees and the electrical connector pointed toward the rear of the engine. Hindsight is always 20/20
The TB that you pictured is by far the easiest way to do this if you can absorb the cost. A cheaper way would be to buy one of the readily available adapters for a GM TBI throttle body to 4150 flange and use a TBI unit with the injector pod removed. It won't flow as much air as the Holley unit, but that shouldn't be an issue with a stock 4.8/5.3/6.0.
I hope that helps to answer your questions.
Old 09-15-2016, 05:33 AM   #141
darkhorse970
darkhorse970's Avatar
Originally Posted by smbrouss70 View Post
Every time this thread pops up, it makes me want to rip the 5.3/4l60e out of my old '99 that is just sitting there and drop it in the Blazer looking similar to this. Unfortunately, I have too much money wrapped up in a new SBC to abandon that course. I just love the look and functionality of this, maybe on the next one.
I agree, this thread REALLY makes me want to go this route with my '63!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-09-2017, 11:17 PM   #142
Jkmyers84
I'm curious about keeping everything with the stock tank need pics reloaded!
Jkmyers84 is offline   Reply With Quote
Old 11-11-2017, 03:55 PM   #143
dayj1
I'm too lazy to go back through this thread and fix all the links after the photobucket boondogle, but here are the tank related pics.
Old 11-11-2017, 03:57 PM   #144
dayj1
and more...
Old 11-21-2017, 12:39 PM   #145
Blumenthal4
DayJ1, I'm in the process of a similar build. Trying to figure out how to run the pcv system. How did you run yours?
Blumenthal4 is offline   Reply With Quote
Old 11-21-2017, 12:42 PM   #146
OutlawDrifter
Easiest/fastest way is to use a breather in one of the valve covers and then use an LS6 valley cover for the PCV and run it back to the throttle body.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-21-2017, 04:19 PM   #147
scoot_mcgrute
I'm curious to know a little more about this. I put an LS1 intake on my 5.3 and didn't have any of the PCV hoses except from the passenger valve cover to the throttle body. I capped everything else off and am running a breather on the driver side valve cover. I'm getting some smoke out the tailpipe under hard acceleration and deceleration and I'm wondering if that could be a factor.
Sorry to hijack the thread but here's a picture of the smoke out the tailpipe.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 11-22-2017, 10:47 AM   #148
dayj1
The clean side of the PCV went from a fitting that I drilled and tapped in the side of the throttle body above the throttle blade in photo 1 to a fitting that I put in the rear of the passenger's side valve cover (photos 2 and 3).
The dirty side went from a vacuum fitting (the brass fitting in the intake just below and behind the carb mounting flange in photo 4) to a PCV valve in the driver's valve cover (photo 5). The PCV valve is the revised "fixed orifice" style for the early trucks and isn't really a valve. I have a vacuum tee fitting on it, because I ran the vacuum line over to the brake booster as well.
Old 11-22-2017, 10:50 AM   #149
dayj1
That'll work for a speed density system. But, if you're running a MAF, the air entering the PCV system should be metered. Otherwise, you essentially have a vacuum leak.
Old 11-22-2017, 11:36 AM   #150
OutlawDrifter
True statement. I am running speed density on my '49.
1991 Z/28, 6.0L/T56
